Need help with gaming rig
Post Date: 2011-05-27
Anaahat View Drop Down
  Quote Anaahat Quote  Post ReplyReply bullet Topic: Need help with gaming rig
    Posted: 27 May 2011 at 1:30am
So I have decided to finally purchase a gaming computer from Digital storm within the next 3 days.
I require this computer to fly through every game with EASE
I have a $5000 budget (I have give about 300 dollars up or down if needed)
But I require a TOP of the line processor, (2600k Sandybridge or Intel I7 990x)
an SSD of about 160 GB
Good enough Liquid cooling for me to OC everything with good stability
Dual SLI nVidia video cards, (gtx580/590)
and just everything else to be really good
I will be gaming with a 1920 x 1080 res. monitor. that will have to be bought as well
If you could help me out by building me a config. I would greatly appreciate it,
thanks everyone Big%20Smile
Invader Mig View Drop Down
  Quote Invader Mig Quote  Post ReplyReply bullet Posted: 27 May 2011 at 4:43am
If you want everything liquid cooled, with the highest possible CPU overclock, and 580's in your machine, this is the build for you.
562447 $4507
Motherboard: ASUS Maximus IV Extreme (Intel P67 Chipset) (New & Improved B3 Revision Without SATA 3G Issue)
System Memory: 8GB DDR3 1600MHz Corsair Dominator DHX (High-Performance)
Hard Drive Set 1: Operating System: 1x (160GB Solid State (By: Intel) (Model: 320 Series SSDSA2CW160G3K5)
Video Card: 2x SLI Dual (NVIDIA GeForce GTX 580 1.5GB (PhysX) (Overclocked Edition)
Extreme Cooling: H20: Stage 6: Sub-Zero LCS Dual Loop: CPU & Dual SLI/CrossFire Video Cards
Boost Processor: Stage 3: Overclock CPU 4.9GHz to 5.2GHz (Requires Extreme Series Motherboard)
If you are willing to make a few concessions, but still keep your power, then I'd bump down the 580's to 570's. The performance difference between the two set ups at that resolution is negligible, but the price sure isn't.
Here is a more modest, but extremely powerful build that will still rip through games at your res.
562409 $3572
Extreme Cooling: H20: Stage 4: Sub-Zero LCS Cooling System: CPU Only
Keep in mind that the Maximus motherboard I chose is only there because it is required to get the stage 3 overclock. If you are willing to "settle" for the stage two OC (-$30), which is 4.5-4.8 ghz, you can save yourself $169 by dropping down to a deluxe mobo. At the point you can even drop the Liquid cooling. If you still want 580's you can add them to this build for an additional $238.
Here's what an Air cooled rig would look like.
562454 $3036
I know this may seem like penny pinching, and with your budget you may not be that worried about the price, but I just wanted to be thorough and give you as many options as possible. Hell, you might even want to check out the Ultimate ODE prebuilt system. That system gives you a Stage 3 OC, and 570 SLI, all for $2500. Options never hurt.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 27 May 2011 at 4:50am
Monitor:
Dell UltraSharp U2311H 23
or
Dell UltraSharp U2410
the u24 is 2010 model the u23 is 2011 model but the 24" has little better specs, overall pretty much the same.
at that res sli 580 is a waste, and we never recommend dual gpu cards like the 590/6990, cause they are a horrible idea and get beat by 2 single cards in sli.
Here you go Ticket# 562461 --- $4043 (To see this build click here)
H20 Tube Color:Green Tubing with High-Performance Fluid (UV Lighting Reactive)
Now this system has it all and at 1900 x 1200 you will not be able to tell the difference between it and sli 580 or 590.
this lc system is not quiet, if you want a quiet system we need to make custom changes to it.
Keep in mind there is the highend cpu for SB coming out Q4 of this year, the extreme 6 core will eat up other processors, the 2600K is the midrange SB cpu.
I don't recommend stage 3 oc as it wil have a high vcore and its ont good for 24/7 use, your cpu will die pretty quick with a high vcore.
Edited by DST4ME - 27 May 2011 at 4:52am
