Need help with hard drive config
Post Date: 2013-08-19
eastpoint View Drop Down
  Quote eastpoint Quote  Post ReplyReply bullet Topic: Need help with hard drive config
    Posted: 19 Aug 2013 at 9:35am
Config # 861115  -  I though I was already to order a computer and now I am wondering if this is the best configuration. Planned to go with 512 GB Samsung Pro
because I only need 500 GB total storage (still have 290 GB free space on my 5 year old 500 GB drive) and I wanted to avoid multiple drives so I don't need to deal with multiple directories. To say the least I am no computer wiz.
Would it be a better idea going with a 256 GB Samsung and a 1 TB WD mechanical drive just for whatever reason??  I don't care all that much about the $170. difference. Just trying to get the configuration right the 1st time.
Computer is used for business/home office. No CAD, video games.
Thanks!!
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 19 Aug 2013 at 11:14am
The main reason for the HDD is lots of much cheaper storage.  If you don't have much and don't mind more $$ per GB then just go with the SSD.
Good luck. Big%20Smile
  Quote eastpoint Quote  Post ReplyReply bullet Posted: 19 Aug 2013 at 11:30am
Thank You   Thats what I really wanted to hear. Just a little unnerved about some of the reliability issues(Max read/write cycles and a few others) that I am hearing about SSD's
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 19 Aug 2013 at 11:36am
I trust HDD more than a SSD but they can both fail.   Kind of a crap-shoot I guess.
danjw1 View Drop Down
  Quote danjw1 Quote  Post ReplyReply bullet Posted: 20 Aug 2013 at 2:51pm
Samsung does good reliability testing, so I don't think it is that much of a crap shoot. But, as always, backup the data you can't afford to lose.
  Quote fstcvc Quote  Post ReplyReply bullet Posted: 20 Aug 2013 at 9:16pm
Data can be lost with either method... As danjw1 said, backup anything you have that's important (in multiple places if it's super important - like an online backup or cloud service).
I think that SSD's are more reliable as they are basically RAM with a more permanent on/off switch (data is held without power). And I've had way more HDD's fail than RAM...
  Quote danjw1 Quote  Post ReplyReply bullet Posted: 21 Aug 2013 at 12:13am
I do not believe that is actually true. RAM uses an entirely different technology since it isn't expected to persist without power. Flash memory does have a limited read/write life.
But, from what I have read in desktop usage, it should have life that is roughly comparable with a hard drive. Also, the SSDs controller and bios are designed to minimize ware. That said, die shrinks lead to less life, with current technologies.
Update: I just ran across this article: http://www.anandtech.com/show/7237/samsungs-vnand-hitting-the-reset-button-on-nand-scaling
To summarize it, Samsung's newest fab technology for flash memory is has flattened the curve on flash memory life.
Edited by danjw1 - 21 Aug 2013 at 12:41am
