need help with my config please
Post Date: 2011-03-13
alock16 View Drop Down
  Quote alock16 Quote  Post ReplyReply bullet Topic: need help with my config please
    Posted: 13 Mar 2011 at 5:52pm
sadly, i only have around $1,200 to spend (maybe a little more) :( it's not much, but anything has to be better than my previous computer. i need something that will run WoW smoothly.
my brother set up this config for me, saved ticket number: 500233
but i'm not sure if that's what i should get. any suggestions ?
  Quote RiceEatin2000GT Quote  Post ReplyReply bullet Posted: 13 Mar 2011 at 6:01pm
The eltie 430 thats pre configured at $1238 would walk all over that build.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 14 Mar 2011 at 2:10am
or you can do this, get this system then go to newegg and get a 560 gtx, if that is not doable, then get a 460 gtx:
Here you go Ticket# 500501 --- $1091 (To see this build click here)
Chassis Model: Special Deal Hot Seller - Cooler Master Elite 430
Processor: Intel Core i5 2500K 3.30GHz (Unlocked CPU for Extreme Overclocking) (Quad Core)
Motherboard: ASUS P8P67 (Intel P67 Chipset) (New & Improved B3 Revision Without SATA 3G Issue)
Hard Drive Set 1: Operating System: 1x (500GB Western Digital/Seagate/Hitachi/Samsung (16MB Cache) (7200 RPM)
Video Card: - No Thanks, I will be installing my own video card(s)
Boost Processor: FREE: Overclock the processor between 3.6GHz to 3.9GHz
Edited by DST4ME - 14 Mar 2011 at 2:11am
