Need help with my config :)Post Date: 2009-07-16 |
| Author | |
Naraganeun
Joined: 16 Jul 2009 Online Status: Offline Posts: 19 |
Topic: Need help with my config :)Posted: 16 Jul 2009 at 9:38pm |
Here is my config http://www.digitalstormonline.com/comploadsaved.asp?id=308695 Yes it's my birthday is next week... please don't think im a spoiled 14 year old... i'll be making good use of the computer and my dad is willing to buy it.Aside from that, i'm a little confused on some things, since sending an email and i never got a reply i'll post it here. :)
Extreme Cooling : I have single loop system for 1 CPU (i7 975) and 2 GPUs (Sli GTX285) ALL THREE OVERCLOCKED. Do you recommend dual-loop? price will be $820X i checked.
Chassis Airflow : I'm really worried about the noise... I saw the video on youtube, and the guy's computer is really loud!!! As you can see i'm firon6 and i asked him about that and he said it's from the case fans.
Should I get LED blue light fan, or zalman (up to 6 fans) OR is it possible to put those HUGE case fans that make barely any noise and still cool the same, inside in 1050Si? can DS do that for me?
CPU Boost : I heard on many places, that they were able to OC the i7 975 to 4.5 GHz on a normal Stock fan, DS goes only to 4.2GHz and i'm on liquid cooling... is it possible for DS to go futher at the same price? (because of my processor)
Memory Boost : I'll have 6GB RAM Tri-channel at 2000MHz, is the OC going to make it fry? Is the memory fan kit loud?
Windows OS : I'll get Vista ultimate 64 bit with windows 7 coupon. But, is the windows 7 coupon necessary? Won't it decrease my performance if i reformat my whole SSD from vista into windows 7? Can i wait for my coupon for a long time until windows 7 gets better? Is windows 7 ALOT faster/better and vista ultiamte 64bit?
Displays & 3D : 30 inch... can 2 GTX 285 in sli handle that? Maybe not in games, but will i still have clear graphics, not jaggedy graphics like when your res. is lower than your monitor?
Surge Protector : The 1300VA one, for 1000 watt PSU is that fine? i might other things in there like a router, maybe TV, PS3... will it be sufficient?
Sorry for asking ALOT of questions... i fell kind of bad for asking too much but, im spending 8000+ dollars on a computer!! I really want the best out of it. :)
BTW, is anyone going to play Aion? :) I'm Chantin inbeta on the Siel server. My legion is Ashborne (sig)
Ty all! :)
Posted: 16 Jul 2009 at 9:47pm |
your cooling should be dual loop, one loop for cpu and one loop for gpus.
with LC you don't need upgraded airflow. oc is upto 4.2GHz memory boost is not needed nor can you tell the difference between 1333MHz vs 2000MHz in games. you don't need ulitmate, you have not use for it, premium has all the stuff you need for a 30" you need 3 gpus and that would be 3 x 275, you can't tell the difference between 3 x 275 and 3 x 285. your case is the worst case, don't think more moeny means better. your ram is pointless. your gpus are waste of money and pointless, 275 will give you the same performance. ocing the gpus is even more pointless, all you are doing is creating heat, there will be no performance for you to notice. ocing the ram is also pointless. this system is much better and what you need: Here you go Ticket# 308963 --- Price: $8645 (To see this build click here) Price after current promotion $8145 Copy of Specifications: Chassis Model: Cooler Master HAF 932 Exterior Finish: - Standard Factory Finish Interior Finish: - Standard Factory Finish Trim Accents: - Standard Factory Finish Processor: Intel Core i7 Extreme Edition 975 3.33GHz (Quad Core) (Extreme Performance) Motherboard: EVGA X58 Classified 3X SLI (Intel X58 Chipset) (Supports Triple SLI or CrossFire) System Memory: 6GB DDR3 1600MHz Digital Storm Certified by mushkin enhanced (Highly Recommended) (Hand Tested) Power Supply: 1000W Corsair HX (Dual/Triple/Quad SLI Compatible) (Silent Edition) Card Reader: Internal Digital Media Card Reader (Black) Hard Drive Set 1: Operating System: 1x (250GB Solid State (By: OCZ) Vertex Series (Model: OCZSSD2-1VTX250G) Set 1 Raid Options: - No Thanks Hard Drive Set 2: Multimedia\Data: - No Thanks Hard Drive Set 3: Backup\Misc.: - No Thanks Optical Drive 1: DVD±R/RW/CD-R/RW (DVD Writer 20x / CD-Writer 48x) (LightScribe Edition) Optical Drive 2: - No Thanks Internet Access: High Speed Network Port (Supports High-Speed Cable / DSL / Network Connections) Video Card: 3x SLI Triple (NVIDIA GeForce GTX 275 1792MB (Includes PhysX Technology) Add-on Card: - No Thanks Sound Card: Creative Labs X-Fi Titanium Fatal1ty Professional (PCI-Express Slot Based) Extreme Cooling: H20: Stage 3: Specialized FrostBite Separate Dual Loop System for CPU & Three Video Cards Liquid Color:UV Blue: Medium Glowing Non-conductive Fluid (Requires H20: Stage 3 & UV Lighting) Chassis Airflow: Standard Factory Chassis Fans Internal Lighting: Internal Chassis Lighting System (Blue) Enhancements: - No Thanks Chassis Mods: - No Thanks Boost Processor: Stage 2: Overclock the processor between 4.0GHz to 4.2GHz (Requires H20 Cooling Upgrade) Boost Video Card: - No Thanks, Please do not overclock my video card(s) Boost Memory: Memory Fan Kit Only (Does not include memory overclocking service) Tweak Windows: Yes, Disable and tweak all of the non-crucial services on the operating system Windows OS: Microsoft Windows Vista Ultimate (64-Bit Edition) With Windows 7 Upgrade Coupon Restore Kit: Digital Storm Specialized Recovery System (DVD Image Based) Virus Protection: - No Thanks Office: - No Thanks Benchmarking: - No Thanks Install/Test Game: - No Thanks LCD Display: Samsung 30 inch 305T (Widescreen) (Black) (High-Performance Gaming Display) Surge Shield: APC 1300VA Uninterruptible Backup Surge Conditioner (Recommended) Speakers: Logitech 5.1 System (Black Edition) (Model X540) (Includes Subwoofer) Keyboard: Razer Tarantula Gaming Keyboard Mouse: Razer Lachesis Gaming Mouse (High-Speed Gaming Grade) External Storage: - No Thanks Exclusive T-Shirt: - No Thanks Priority Build: - No Thanks, Ship Within 5-10 Business Days After Order Is Successfully Processed Warranty: 3 Year Platinum Care Extended Parts & Labor Warranty Edited by DST4ME - 16 Jul 2009 at 9:48pm |
Naraganeun
Posted: 17 Jul 2009 at 12:02am |
ty SOOO MUCH. :)
but how come the haf 932? i like how the 1050si looks but does it have to do with airflow? (excluding the fan upgrade)
how about tri 285? and 1333mhz vs 1600mhz? Edited by Naraganeun - 17 Jul 2009 at 12:09am |
Posted: 17 Jul 2009 at 4:14am |
the haf and 950si are the best cases they have here, the 1050si is plastic and has the worst performance, the haf stock has the best airflow so you don't even need the fan upgrade with that, specially since you are going LC on cpu and gpu.
you will never notice the difference between tri sli 285 vs tri sli 275. you will never notice the difference between 1333MHz and 1600MHz. however since you are going stage 2 and you are getting a highend system, you might as well get the 1600MHz, the difference is only like $70 bucks. also I just realized that I didnt' remove the windows tweak from my config, so please remove the windows tweak from that config before you order it it was a mistake
Zardoz8719
Joined: 04 Mar 2009 Online Status: Offline Posts: 543 |
Posted: 17 Jul 2009 at 9:12am |
Hey, Naraganeun...welcome aboard... Just a couple of questions...what got you interested in DS computers...
Naraganeun
Posted: 17 Jul 2009 at 12:54pm |
He wasn't such a "cool dad" in the past. Certain physocological problems i have, and the things he did in past to my family makes him feel regret now. But we all care for each other now and he's a nice person. My parent's are divorced and my dad only supported my sisters an never me. now he wants to help me out, and because ive always lived with the worser stuff, he wants me to have the good stuff.
a little dramatic here, i could more but, you know xD
Zardoz8719
Posted: 17 Jul 2009 at 1:46pm |
inferno23
Joined: 09 May 2009 Online Status: Offline Posts: 519 |
Posted: 17 Jul 2009 at 4:48pm |
theres a lot u need changed but heres the config thinks best 4 u for 6686 b4 discount
Chassis Model: Cooler Master HAF 932 Exterior Finish: - Standard Factory Finish Interior Finish: - Standard Factory Finish Trim Accents: - Standard Factory Finish Processor: Intel Core i7 Extreme Edition 975 3.33GHz (Quad Core) (Extreme Performance) Motherboard: EVGA X58 Classified 3X SLI (Intel X58 Chipset) (Supports Triple SLI or CrossFire) System Memory: 6GB DDR3 1600MHz Digital Storm Certified by mushkin enhanced (Highly Recommended) (Hand Tested) Power Supply: 1000W Corsair HX (Dual/Triple/Quad SLI Compatible) (Silent Edition) Card Reader: - No Thanks Hard Drive Set 1: Operating System: 1x (160GB Solid State (By: Intel) (Extreme Performance) (Model: SDSA2MH160G1C5) Set 1 Raid Options: - No Thanks Hard Drive Set 2: Multimedia\Data: 1x (320GB Western Digital (16MB Cache) (7200 RPM) (SATA) Hard Drive Set 3: Backup\Misc.: - No Thanks Optical Drive 1: DVD±R/RW/CD-R/RW (DVD Writer 20x / CD-Writer 48x) Optical Drive 2: - No Thanks Internet Access: High Speed Network Port (Supports High-Speed Cable / DSL / Network Connections) Video Card: 3x SLI Triple (NVIDIA GeForce GTX 275 1792MB (Includes PhysX Technology) Add-on Card: - No Thanks Sound Card: Creative Labs X-Fi Titanium Fatal1ty Champion (Includes Front I/O) (PCI-Express Slot Based) Extreme Cooling: H20: Stage 3: Specialized FrostBite Separate Dual Loop System for CPU & Three Video Cards Liquid Color:UV Green: High Glowing Non-conductive Fluid (Requires H20: Stage 3 & UV Lighting) Chassis Airflow: Standard Factory Chassis Fans Internal Lighting: Internal Chassis Lighting System (UV) (Creates Glowing Effect For H20: Stage 3 UV Fluid) Enhancements: - No Thanks Chassis Mods: - No Thanks Boost Processor: Stage 2: Overclock the processor between 4.0GHz to 4.2GHz (Requires H20 Cooling Upgrade) Boost Video Card: - No Thanks, Please do not overclock my video card(s) Boost Memory: - No Thanks, Please do not overclock my memory Tweak Windows: - No Thanks, Please do not tweak the services on the operating system Windows OS: Microsoft Windows Vista Home Premium (64-Bit Edition) With Windows 7 Upgrade Coupon Restore Kit: Digital Storm Specialized Recovery System (DVD Image Based) Virus Protection: - No Thanks Office: - No Thanks Benchmarking: - No Thanks Install/Test Game: - No Thanks LCD Display: - No Thanks Surge Shield: - No Thanks Speakers: - No Thanks Keyboard: - No Thanks Mouse: - No Thanks External Storage: - No Thanks Exclusive T-Shirt: - No Thanks Priority Build: - No Thanks, Ship Within 5-10 Business Days After Order Is Successfully Processed Warranty: 3 Year Platinum Care Extended Parts & Labor Warranty the haf has better temps than the raven so thats the way 2 go
u gonna need the classified b/c for a 30 in monitor u need 3 vid cards + u want a sound card
the 1600 mhz memory is the optimal ull need for gaming
skip ALL the extras DS wont cover it under warranty and u prob could get the monito and stuff cheaper form newegg.
LCing the video cards will elimnate most of your noise and give u better temps. if u do so its best to go dual loop. and ask fot the tripple single rad set up and the quick release valves.
b/c ure putting so much into your system its best to go with the 5 year warranty with all those high performance parts.
if ud like pics of Lced rigs post your email and il send u a link then u can delete your email post
the intel SSD drive will kill all those others but the 250GB vertex is not bad either.
Edited by inferno23 - 17 Jul 2009 at 4:50pm |
Naraganeun
Posted: 18 Jul 2009 at 8:02pm |
hmm... i'm concerned again, im going to be using the build you set up DST thats perfectly what i want now.
But concerned about the monitor.... it's native is like 2800xSomething and if i run crysis in that ill probably only get 30 fps ;( and on other games too, if i lower the resolution the graphics will look jaggedy, or screen will be blurry...
should i switch to a samsung 24 inch? i'm looking to get 50~72 fps in games (yes i know '60 is the limit')
and about the warranty he said... should i really buy it all at newegg? or the thing is that DS's warranty cover those, BUT it comes with its own warranty?
Edited by Naraganeun - 18 Jul 2009 at 8:38pm |
Posted: 18 Jul 2009 at 8:51pm |
with tri sli 275 you are going to ge more then 30 fps at 2560 x 1600, maybe like 40 to 45 not sure to be honest, don't max out the setttings
you get the same warranty no matter where you get it from but price it out at newegg I think you might be able to save so me money. |
Naraganeun
Posted: 20 Jul 2009 at 3:08am |
Hmmm... I think ill go with 24 inch...
do you recommend samsung or acer in the options?
or should i buy a better one at newegg[24 inch] ((might not be possible since dad has no usa credit and lives in taiwan [for pilot job] so he might not be able to make so much separate payments))
Posted: 20 Jul 2009 at 3:13am |
shop around newegg and see what you can come up with., I'm not great with monitors myself but the samsung seems to be a good one, see if you can find a better price from newegg for it
