Need help with new buildPost Date: 2014-06-08 |
| Author | |
MikeS
Joined: 15 Jul 2009 Online Status: Offline Posts: 5 |
Topic: Need help with new buildPosted: 08 Jun 2014 at 12:56pm |
To be used for gaming at 1920 x 1200, mostly FPS, a little RTS. Also to be used as my daily machine. Budget is about $2500 and I am at $2379 now.
I probably won't expand to SLI/crossfire in the future. Config number 989940 Chassis Chassis Model: Corsair Carbide Series Air 540 Core Components Processor: Intel Core i5 4690K 3.50 GHz (Codename Devils Canyon) (Unlocked CPU) (Quad Core) (ETA 6/25/14) Motherboard: ASUS SABERTOOTH Z97 MARK2 (Intel Z97 Chipset) (Military-Grade TUF Components) System Memory: 16GB DDR3 1866MHz Corsair Vengeance Pro (High-Performance) Power Supply: 760W Corsair AX760 Storage / Connectivity Optical Drive: DVD-R/RW/CD-R/RW (DVD Writer 24x / CD-Writer 48x) Storage Set 1: 1x SSD (256GB Samsung 840 PRO) Storage Set 2: 1x Storage (1TB Western Digital - Black Edition) Internet Access: High Speed Network Port (Supports High-Speed Cable / DSL / Network Connections) Graphics / Multimedia Graphics Card(s): 1x NVIDIA GeForce GTX 770 2GB (EVGA Superclocked ACX Cooler Edition) Sound Card: Integrated Motherboard Audio Digital Storm Engineering Extreme Cooling: H20: Stage 2: Corsair H100i 240mm Radiator Liquid CPU Cooler (Extreme-Performance Edition) H20 Tube Color: - Not Applicable, I do not have a FrostChill or Sub-Zero LCS Cooling System Selected Chassis Fans: Standard Factory Chassis Fans Internal Lighting: Internal Chassis Lighting System (Red) Digital Storm TwisterBoost Technology Boost Processor: Stage 2: Overclock CPU 4.5GHz to 4.8GHz (Requires High-End Motherboard Selection) Software Windows OS: Microsoft Windows 7 Home Premium (64-Bit Edition) Recovery Tools: Windows Recovery Toolkit (Bundled with Windows CD) Any suggestions? Anybody feel strongly about AMD over Nvidia? Is it worth $200 upgrading the video card? |
Posted: 08 Jun 2014 at 2:04pm |
Hi MikeS... Your build is all quality parts, from the Air540, my pick if I was buying right one, to the excellent Sabertooth mobo with its 5 year warranty and the psu, and drives. If possible, I would up to the gtx 780 if more games on max settings is important. The gtx 770 will play most games with your monitor at High to Max.
Hers a comparison..... http://www.anandtech.com/bench/product/1037?vs=1036 I prefer Nvidia over AMD mainly because of AMD's driver issues in the past. However, AMD does give you a card with similar performance for less money. I still like Nvidia. Good luck.
Nav
Joined: 15 Jan 2021 Online Status: Offline Posts: 1581 |
Posted: 08 Jun 2014 at 2:25pm |
I agree with bprat22 that upgrading to the 780 will give you an extra boost that you'll probably want in the future (considering you said you don't want to go SLI/CrossFire).
As far as AMD vs NVIDIA drivers, there may have been issues in the past but as of lately, we haven't seen any issues with the new drivers they have been putting out. It really comes down to which feature set you want (GSYC vs Mantle) etc. |
MikeS
Posted: 08 Jun 2014 at 3:51pm |
Thanks.
I picked the overclocked 770 because it was listed as an EVGA branded card. The others don't list a manufacturer. Are they just Nvidia reference cards? I think the third party vendors use more effective, quieter coolers in general and I would rather have an ASUS, EVGA or other manufacturer's card than a generic Nvidia. |
Nav
Posted: 08 Jun 2014 at 3:53pm |
There isn't really a reference 770 cooler. We will use a ASUS/EVGA/PNY card depending on what stock we have. They each have their own cooler.
MikeS
Thanks. That comparison is certainly compelling.
danjw1
Joined: 07 Jul 2013 Online Status: Offline Posts: 667 |
Posted: 08 Jun 2014 at 3:56pm |
Here is a link to a overview of the current graphics card market: http://www.anandtech.com/show/8072/best-video-cards-may-2014
