Need help with PC build
Post Date: 2018-01-06
pearsonsj1 View Drop Down
  Quote pearsonsj1 Quote  Post ReplyReply bullet Topic: Need help with PC build
    Posted: 06 Jan 2018 at 12:53am
Hello!
I have been researching Gaming PC's lately and have been looking into buying one and came to the conclusion that Digital Storm is the best place to buy one... but I still am not sure if I have a good enough build to game on a monitor that is 1080p and if it will be strong enough. I found this build on another form. Please tell me if this is a good build and any suggestions to make it better.
Thanks!
Chassis Model: Digital Storm Coridium
Processor: AMD Ryzen 3 1300X (4-Core) (Boost Up to 3.7 GHz)
Motherboard: MSI (AMD B350M Chipset) (Up to 2x PCI-E Devices) (No SLI Support)
System Memory: 16GB DDR4 3000MHz Digital Storm Performance Series
Power Supply: 600W EVGA (Supports up to an NVIDIA GTX 1080 Graphics Card)
Storage Set 1: 1x SSD (240GB Digital Storm Performance Series)
Storage Set 2: - No Thanks
Graphics Card(s): 1x GeForce GTX 1070 8GB (VR Ready)
Extreme Cooling: AMD Standard Factory Heat-sink and Fan
Airflow Control: - No Thanks
Recovery Tools: Windows 10 Installation CD Only (Clean Install with No Drivers)
Branded Gear: - No Thanks
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 06 Jan 2018 at 4:03am
What games are you playing on 1080p?
The gpu is good im not crazy about your cpu but should be ok, i recommend intel
Drop oc on gpu
  Quote Cretae Quote  Post ReplyReply bullet Posted: 06 Jan 2018 at 4:19am
Welcome to the forums, pearsonsj1!   Your budget for this PC would help us. Have you checked out the Vanquish level 2 or 3? might be right up your alley mebbe.
Come back with info, thoughts, questions.
  Quote pearsonsj1 Quote  Post ReplyReply bullet Posted: 06 Jan 2018 at 10:53am
Hello!
My budget is around 1,300 dollars
I want to play games like forza, Call of Duty, GTA 5, things like that
is there anything good that would be in that price range?
Thanks for the help!
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 06 Jan 2018 at 11:31am
The Vanquish level 2 matches your budget and plays great on a 1080p monitor.   Gives you everything you need.
If you could stretch the budget to $1500, the level 3 gives you a better stronger cpu and much stronger video card, and a better cpu cooler, all which I think are worth the extra money.
Either gives you excellent gaming.     Budget dictates.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 06 Jan 2018 at 3:50pm
Ditto to what bp said Buget dictates
Edited by DST4ME - 06 Jan 2018 at 3:50pm
