Need help with Ram!
Post Date: 2013-11-05
Force View Drop Down
  Quote Force Quote  Post ReplyReply bullet Topic: Need help with Ram!
    Posted: 05 Nov 2013 at 9:47am
Hello guys, Call of Duty Ghost came out today and to my surprised my DS system does not have enough Ram to play Ghost. It's my fault of course since I have gotten used to not even bothering to check System requirements since I got my DS    . Anyways I'm not sure what ram is compatible with my system but I'm looking to buy these from Best Buy.
http://www.bestbuy.com/site/vengeance-2-pack-4gb-ddr3-dimm-desktop-memory-kit/2904596.p?id=1218361848253&skuId=2904596&st=categoryid$abcat0506000&cp=1&lp=13#tab=overview
Current Setup
CPU
     Intel Core i7 860 @ 2.80GHz     35 °C
     Lynnfield 45nm Technology
RAM
     4.0GB Dual-Channel DDR3 @ 723MHz (9-9-9-24)
Motherboard
     EVGA EVGA P55 SLI Micro E652 (CPU 1)
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 05 Nov 2013 at 10:19am
Hi Force.....  Memory can be tricky, but I do think those 2 x4gb DDR3 sticks will fit your mobo.  Your mobo takes DDR3 up to 1600mhz I believe.
Just don't mix them with the old memory sticks.  Swap out the old for new.   Sometimes when the ram sticks' speed( MHz ) and timing( 9-9-9-24 for example ) don't match issues can develop.  Not always but no way to tell until it happens.  Plus, 8gb total should do you just fine.
You could, to play it 100% safe, go to Corsair website and use their memory finder to auto check or put in the mobo specs, to find out for sure.
But, I do think you're good.
Edited by bprat22 - 05 Nov 2013 at 10:21am
  Quote Force Quote  Post ReplyReply bullet Posted: 05 Nov 2013 at 12:05pm
Ty bprat22, I am going to go buy it today or tomorrow!
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 05 Nov 2013 at 12:59pm
My pleasure.
  Quote fstcvc Quote  Post ReplyReply bullet Posted: 05 Nov 2013 at 8:55pm
Here are the varying different kits offered by Crucial that'll are specifically for your motherboard. Any of their 2x4GB kits should be sufficient (and bp22 is correct on mixing RAM ≠ good idea!). The memory from BB looks to be equivalent to what Crucial is specifying so you should be okay.
