Need Help With Specs.
Post Date: 2012-09-11
Pizza117 View Drop Down
  Quote Pizza117 Quote  Post ReplyReply bullet Topic: Need Help With Specs.
    Posted: 11 Sep 2012 at 3:50pm
Must be under 2,000
A gaming computer with great graphics and runs smoothly.
For gaming on games such as Tf2, Gmod, Deus Ex: Human Revolution, Bf3 etc etc.
Good graphics, runs smoothly,and not too loud of a fan.
Saved Ticket #: 727900
Processor: Intel Core i5 3570K 3.40 GHz (Unlocked CPU) (Quad Core) (Requires Z77 Motherboard)
Motherboard: ASUS P8Z77-V LX (Intel Z77 Chipset) (Does Not Support SLI)
Hard Drive Set 1: Operating System: 1x (500GB Western Digital/Seagate/Hitachi/Samsung (7200 RPM) (16MB Cache)
Optical Drive 1: - No Thanks
Internet Access: Wireless PCI-E 802.11n Up to 300Mbps (Supports 802.11n/g/b) (Model: ASUS PCE-N15)
Video Card: !PROMOTION: 1x AMD Radeon HD 7950 3GB
Extreme Cooling: AIR: Stage 1: Corsair A50 120mm Fan High Performance Cooler
Chassis Airflow: Upgrade Chassis With LED Performance Fans (Red) (Up to 6 Fans)
Display: Acer 23 inch (Widescreen) (Black) (High-Performance Gaming Display)
Keyboard: Razer Arctosa Gaming Keyboard (USB) (RZ03-00260800-R3U1)
  Quote Alex Quote  Post ReplyReply bullet Posted: 11 Sep 2012 at 9:58pm
Looks good, however, you might want to consider our ODE line of pre-built desktops as they will give you better specs for your money.
  Quote Alex Quote  Post ReplyReply bullet Posted: 11 Sep 2012 at 9:59pm
P.S.
All of the levels 1-4 will play those games with zero issues.
marccody View Drop Down
  Quote marccody Quote  Post ReplyReply bullet Posted: 11 Sep 2012 at 10:44pm
Hey pizza,
I agree with what alex said. I would go with the odes because they are the best deal digital storm offers. I personally own a ode level 1 (which i think is the best deal out of the odes!) and it runs great! Most of the components you selected match the ode level 1 components!
In terms of what you have selected the i5 processor is perfect for gaming. There are very few games that will max out the processors capabilites and all the games you mentioned will not cause that.
When it comes to the graphics card, I personally would recommend the gtx 670 right now . I personally have one (comes with ode level 1) and it runs everything I have without any problems. You can check multiple review sites. THe gtx 670 is one of the best bang for your bucks right now. Thats not to say AMD cards are not great, but from what ive seen nvidia has a slight edge right now. For battlefield 3 nvidia cards run better as of right now
Heres a review of the gtx 670 showing battlefield 3 fps
http://www.anandtech.com/show/5818/nvidia-geforce-gtx-670-review-feat-evga/11
