Need Input on build
Post Date: 2008-09-20
KattsMeow View Drop Down
  Quote KattsMeow Quote  Post ReplyReply bullet Topic: Need Input on build
    Posted: 20 Sep 2008 at 12:37am
Dead Hello's to all, I'm new here and was wondering a few things ?
 Here is what I was thinking for a build :
Direct Load URL: http://www.digitalstormonline.com/comploadsaved.asp?id=184882
Chassis: Digital Storm 950Si
Exterior Finish: - EXOTIC StormBlack High-Gloss Automotive Paint Finish
Interior Finish: - EXOTIC StormBlack High-Gloss Automotive Paint Finish
Power Supply: 1200W Thermaltake (Triple and Quad SLI Compatible) (Toughpower Edition)
Processor: Intel Core 2 Quad QX9650 Extreme 3.00GHz (1333MHz FSB) (12MB Cache)
Motherboard: Asus P5E3 Premium WiFi-AP (Intel X48 Chipset) (Supports CrossFire)
System Memory: 4GB DDR3 1600MHz OCZ Platinum Edition
Card Reader: - No Thanks
Hard Drive 1: 750GB Western Digital (7200 RPM) (16MB Cache) (SATA) (Extreme Speed)
Hard Drive 2: 750GB Western Digital (7200 RPM) (16MB Cache) (SATA) (Extreme Speed)
Raid Option: - No Thanks
Hard Drive 3: - No Thanks
Video Card: 2x CrossFire Quad (ATI Radeon HD 4870X2 2GB)
TV Tuner: - No Thanks
Extreme Cooling: Liquid Chilled FrostBite CPU & Dual Video Cards
Modifications: NVIDIA Enthusiast System Architecture (ESA) System (Install, Test, Optimize Computer)
Windows OS: Dual Boot (Windows XP Professional & Windows Vista Ultimate)
Protection: - No Thanks
LCD Display: - No Thanks
Warranty: 4 Year Platinum Care Extended Parts & Labor Warranty (Highly Recommended)
Regards,
Digital Storm Sales Department
Website: http://www.digitalstormonline.com
Toll-Free: 1-866-81-STORM
Email: [email protected]
What is the diff between single and double looped ?
Is there any other Motherboards then thses 3  or is what I have good enuff ? I really don't need WiFi
HD really what I want to do here is on the C: drive i'll be split it in half with XP on 1/2 and Vista on 2nd 1/2 and the other Drive I put Images for backup, I use ShadowProtect from StroageCraft which I think is much better than Ghost, but If you have a better sugg. let me know amd i'll ponder it !
What youe opinion on the GPU's ? Sound card ? and Dual boots ?
 Thanks for your input ! LOL
Have you had a good MEOW today ?
  Quote KattsMeow Quote  Post ReplyReply bullet Posted: 20 Sep 2008 at 12:38am
oops should have this too sry:
brandon92591 View Drop Down
  Quote brandon92591 Quote  Post ReplyReply bullet Posted: 20 Sep 2008 at 12:41am
Edited by brandon92591 - 20 Aug 2018 at 1:35pm
  Quote KattsMeow Quote  Post ReplyReply bullet Posted: 20 Sep 2008 at 12:45am
I'll be dual booting, that would only give me 150gb - OS each
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 20 Sep 2008 at 1:00am
KM, welcome aboard
your system is loaded with certain thing that are not need and a waste
this is what it should be:
here you go Ticket# 184896 --- Price: $4991
now for dual boot, don't partition a drive, give each OS independence and so give each their own HDD.
for OS HDD go with 2 x 150GB digital Raptor or 2 x 300GB velociraptor.
if you gonna spend that much money, its a shame to cut out speed that the Raptor can add to your system.
Please think long and hard about this
I also recommend going with 790i mombo.
Edited by DST4ME - 20 Sep 2008 at 1:06am
  Quote brandon92591 Quote  Post ReplyReply bullet Posted: 20 Sep 2008 at 1:06am
  Quote KattsMeow Quote  Post ReplyReply bullet Posted: 20 Sep 2008 at 1:07am
is there any other pic's of the cases, I would lov to be able to see all the way around open and closed ? and ok I think ill go with the 300 rap x2 and the 750 for back up inages. anything ele i missed ?
  Quote KattsMeow Quote  Post ReplyReply bullet Posted: 20 Sep 2008 at 1:09am
and yes I was wondering about the MB thing? what is better about the 790i ?  I will think about it  oh  yea double and single loops  whats the diff?
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 20 Sep 2008 at 1:14am
yes I forgot to tell you that Acronis true image does a great job of cloning disks which is what I do so in case anything happens to my OS, I can
a. just pop in the clone and pick up were I left off
or
b. use the clone to make another clone and then use the 2nd clone as my current drive and maintain the original clone in the other drive, in case something goes wrong.
If you think you gonna fill up those 2 Raptor in the future then go with the 750GB for backup, but if you don't think thats gonna happen then go with the 500GB HDD.
If you got the money, if may suggest the best idea:
HDD1: RAPTOR OF YOUR CHOICE FOR VISTA 64BIT
HDD2: RAPTOR OF YOUR CHOICE FOR XP 32BIT
HDD3: 500GB HDD FOR MEDIA/PERSONAL FILES
HHD3: 750GB OR 500GB FOR BAKCING UP HDD1 & HDD2.
Your thoughts?
Edited by DST4ME - 20 Sep 2008 at 1:24am
widdlecat View Drop Down
  Quote widdlecat Quote  Post ReplyReply bullet Posted: 20 Sep 2008 at 1:22am
If you wanna go with ESA, you need an nVidia mobo, however, if you wanna have the ability to go with crossfireX, you need the X48 or a mobo with AMD chipsets. To find out what is compatible with ESA I would recommend calling DSO. To get a good overview of the DS 950Si case, it is the Silverstone TJ-09. You can either go to www.silverstonetek.com or check out newegg. Both sites will have good info and pics.
Edited by widdlecat - 20 Sep 2008 at 1:24am
  Quote KattsMeow Quote  Post ReplyReply bullet Posted: 20 Sep 2008 at 1:23am
Humm, now ya got my head spinning  lolWink this will be my 1st system with Vista and I'm really leary of to tell ya the truth, but I'm willing to take the plunge, ?? now days most everything runs good on Vista64??  and yes I'll really think hard about that HD set up  but sound good
  Quote KattsMeow Quote  Post ReplyReply bullet Posted: 20 Sep 2008 at 1:27am
Also I have used Ghost and Acrons both and I found Shadowprotect much faster and superior to those two,imo give her a try, you'll be suprised and no i don't work for them  lol
  Quote widdlecat Quote  Post ReplyReply bullet Posted: 20 Sep 2008 at 1:27am
I think those who are looking at new pcs and not willing to try Vista 64 will be disappointed later when they realise that Vista 64bit would have allowed for more ram usage and better graphics cards system compatibility.
Edited by widdlecat - 20 Sep 2008 at 1:28am
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 20 Sep 2008 at 1:30am
Yes vista 64 is good, unlike xp 64 we have been able to get many things working on there and we can help you disable a few thing in it if you like so you don't get the nags about your permission all the time
here is the pics for HAF case, its hell of a case:
have a look at it here
have you tried cloning?
with Acronis cloning you don't need Acronis to restore, with image shadow you need image shadow to restore right?
Edited by DST4ME - 20 Sep 2008 at 1:33am
  Quote KattsMeow Quote  Post ReplyReply bullet Posted: 20 Sep 2008 at 1:32am
Thanks guys and WCat thanks for the link for the 950Si does anybody know who makes the HAF 932? so i can get a good look at it?
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 20 Sep 2008 at 1:35am
I had it posted in my other post guess you missed it.
HAF is made by cool master and is much better case in both air flow and water cooling then the 950si
more pics:
Click image to enlarge
  Quote KattsMeow Quote  Post ReplyReply bullet Posted: 20 Sep 2008 at 1:40am
Yes, it does the same as Ghost and Acrons but much better imo
Yes now I'm sold on the HAF
How about the H2O whats the diff between 1 &2 looped?
  Quote KattsMeow Quote  Post ReplyReply bullet Posted: 20 Sep 2008 at 1:43am
Here is a new build :
Hard Drive 2: 300GB Western Digital VelociRaptor (10K RPM) (16MB Cache) (Extreme Speed)
Hard Drive 3: 750GB Western Digital (7200 RPM) (16MB Cache) (SATA) (Extreme Speed)
Modifications: - No Thanks
Tweak Windows: Yes, Disable and tweak all of the non-crucial services on the operating system
Windows OS: Dual Boot (Windows XP Home & Windows Vista Ultimate)
Any thing I missed?
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 20 Sep 2008 at 1:47am
single loop is one circulation so everything is running off the same line, thus more you have the higher the temp of the liquid
double loop is 2 circulation, say one for CPU and one for GPU.
double loop has its own radiator
overkill and waste of money:
not needed, to loud and much more heat for you.
too fast and over your fsb = waste and not used, match your ram with your cpu's fsb
not needed and waste of money, all you need is the single cpu liquid cooling I picked for you, teh rest is a waste of money, the haf has great fans and vents and will keep those cards cool.
you have liquid cooling, OC the cpu and OC the ram. if you don't you are wasting your pc's abilities. that qx9650 is made to be over clocked. "quad extreme 9650", all extreme chips are made to over clock by intel.
Edited by DST4ME - 20 Sep 2008 at 1:52am
  Quote KattsMeow Quote  Post ReplyReply bullet Posted: 20 Sep 2008 at 1:49am
kk, thanks for clearing that up for me..i'll get the dual loop then Dead
  Quote KattsMeow Quote  Post ReplyReply bullet Posted: 20 Sep 2008 at 1:52am
And another build :
Extreme Cooling: Liquid Chilled FrostBite Dual Loop System for CPU & Dual Video Cards
Modifications: LCD Temperature Display & Fan Controller
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 20 Sep 2008 at 1:53am
please go back and read my previous post, you want a single loop cpu. and the rest of the stuff I pointed out.
if you want to add something go from 9650 to qx9770
Edited by DST4ME - 20 Sep 2008 at 1:54am
  Quote KattsMeow Quote  Post ReplyReply bullet Posted: 20 Sep 2008 at 2:00am
oops I got ahead of myself, I went back and reread the replys and I missed a ton, lol Sry I'm really excited about this build and I drank a couple of rockstars boosters and i'm really wired sry i'll slow down, I want to get this rightBig%20smile
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 20 Sep 2008 at 2:02am
I can totally understand
why don't you just change teh config of teh HDD on this and if you like add the qx9770
I have to go for a couple hours when I come back we talk more if you like
OH and you need to remove the:
that is only nvidia mombo and gpu, you have chosen ati platform.
Edited by DST4ME - 20 Sep 2008 at 2:03am
  Quote KattsMeow Quote  Post ReplyReply bullet Posted: 20 Sep 2008 at 2:09am
ok I took my time this time here we go :
System Memory: 8GB DDR3 1333MHz OCZ (High-Performance)
Hard Drive 3: 500GB Western Digital (16MB Cache) (7200 RPM) (SATA)
Sound Card: Creative Sound Blaster X-Fi XtremeGamer (CLEARANCE PRICED)
  Quote KattsMeow Quote  Post ReplyReply bullet Posted: 20 Sep 2008 at 2:13am
Do I really need XP anymore ? by now I would think, but I don't know Vista or 64 bit yet ?
  Quote widdlecat Quote  Post ReplyReply bullet Posted: 20 Sep 2008 at 2:17am
Did you mean to bump your ram to 8GB? and if you wanna dual boot with XP and Vista, I'd recommend Vista 64bit. Regarding sound, I personally would stay clear of Creative x-fi cards. There support is spotty regarding compatibility issues with many customers and driver support is slow. The Razer Baraccuda sound card is a better product IMO. If you have the money, the ASUS Xonar D2X is the best pc sound card from an audio perspective. If you do a lot of FPS games where sound cues are important, the Razer is better for you. The Xonar doesn't support true EAX 5.0
  Quote KattsMeow Quote  Post ReplyReply bullet Posted: 20 Sep 2008 at 2:18am
One more question ? crossfire quad 4870x2 or the SLI 280 1gb ? what and why ? I want tons of input here, thanks
  Quote KattsMeow Quote  Post ReplyReply bullet Posted: 20 Sep 2008 at 2:20am
ok about the sound card, now days is one really needed with the MB sound ?
  Quote widdlecat Quote  Post ReplyReply bullet Posted: 20 Sep 2008 at 2:21am
Okay, if you wanna utilise more than about 1GB or so ram, you need to go with Vista 64. The vidram and ram share the bandwidth in XP or Vista... so, to get decent ram usage, you need Vista 64. If you ran XP, you would have to first disable crossfireX to get any kind of performance IMO, but it would allow you to run some of the very old games that might not be able to run on Vista. I don't have Vista yet, so I'm not sure how far back you would need to go.
  Quote widdlecat Quote  Post ReplyReply bullet Posted: 20 Sep 2008 at 2:23am
If you're a music lover, audiophile or have sensitive ears, yes. If you listen with high quality headphones, I would recommend a sound card. If you're looking for a place to save money. Drop the sound card hehehe.
  Quote KattsMeow Quote  Post ReplyReply bullet Posted: 20 Sep 2008 at 2:24am
oh the 8gb I was thinking about just dropping to just vista64 and lossing 1 rap
  Quote widdlecat Quote  Post ReplyReply bullet Posted: 20 Sep 2008 at 2:27am
Ram and HDD don't exactly exchange in that fashion. Data is initially stored in the HDD and transfers to the CPU where it processes and then the fsb determines where the data goes from there... to the RAM or back to the HDD or elsewhere. The RAM is more temporary data storage and really is constantly transferring data back and forth to the CPU. It requires a charge to maintain the data, while the HDD stores the data magnetically on discs for more permanant storage.
  Quote KattsMeow Quote  Post ReplyReply bullet Posted: 20 Sep 2008 at 2:34am
so then I'll ok with 4 gb on vista 64?
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 20 Sep 2008 at 3:02am
KattsMeow go with 4 GB of ram and make sure you go with ocz, corsair has been crapping out alot.
you keep picking liquid cooling for your card you dont' need that, you only need this:
I don't know why you want to go dual boot, just go with vista 64
as widdlecat said if you don't need a sound card then drop it, if you like one go with razer
Edited by DST4ME - 20 Sep 2008 at 3:04am
