Need monitor help
Post Date: 2012-12-03
44cmitchell View Drop Down
  Quote 44cmitchell Quote  Post ReplyReply bullet Topic: Need monitor help
    Posted: 03 Dec 2012 at 6:18am
I bought a yamakasi catleap 2307 which runs 2560*1440p . I currently own the x15e with the gtx 675m graphics card. I want to know can I run this monitor. I plan to use the display port.
would this cord work?
http://www.ebay.com/itm/GENUINE-HP-DISPLAY-PORT-to-DVI-ADAPTER-CABLE-481409-001-DVI-DP-LAPTOP-VIDEO-/181025110578?pt=US_Video_Cables_Adapters&hash=item2a25effa32
or do i need to use this one?
http://www.amazon.com/Accell-B087B-003J-UltraAV-miniDisplayPort-Dual-Link/dp/B0030XMREG/ref=sr_1_27?ie=UTF8&qid=1354543475&sr=8-27&keywords=display+port+to+dual+link+dvi
Finally what would happen if i tried to plug the monitor into the DVI-I dual link connector on the laptop?
  Quote 44cmitchell Quote  Post ReplyReply bullet Posted: 05 Dec 2012 at 12:00pm
Solved, what an outstanding monitor for how inexpensive it is.
needed an active display pot to DVI-DL adapter and she works like a beauty
