Need RAM help
Post Date: 2019-02-19
BravoActual View Drop Down
  Quote BravoActual Quote  Post ReplyReply bullet Topic: Need RAM help
    Posted: 19 Feb 2019 at 7:21pm
The rig I ordered comes with 16GB DDR4 3000MHz Digital Storm Performance Series. I also have another 16GB DDR4 3000MHz Trident Z laying around. My question is would I be able to throw those Trident Z's onto the MOBO (ASUS ROG Strix Z390-H Gaming) for a total of 32GB without any issues, as they aren't the same brand?
KartRacerNC View Drop Down
  Quote KartRacerNC Quote  Post ReplyReply bullet Posted: 19 Feb 2019 at 7:39pm
As long as the form factor DDR2, DDR3, DDR4, etc is the same. So you should be good.
  Quote BravoActual Quote  Post ReplyReply bullet Posted: 19 Feb 2019 at 7:56pm
Thanks!
  Quote Cretae Quote  Post ReplyReply bullet Posted: 20 Feb 2019 at 7:40am
Actually, it could be more complicated than that these days as I understand things. Speed and timings can come into play. But it wouldn't hurt just to try it out.
Psyoshi View Drop Down
  Quote Psyoshi Quote  Post ReplyReply bullet Posted: 20 Feb 2019 at 7:34pm
If the timijng is differentb etween the two kits you can make an XMP profile to override that and fix the issue. :)
