Need review/ help with sub 2k gaming system
Post Date: 2010-07-17
doedoe View Drop Down
  Quote doedoe Quote  Post ReplyReply bullet Topic: Need review/ help with sub 2k gaming system
    Posted: 17 Jul 2010 at 2:54pm
Hi I'm new to the DS forum and ended up here after doing extensive comparisons of DS with ibuypower and cyberpower
I feel like buying from DS would be a wiser choice so I just need some help configuring a very capable gaming computer.
I'm going to be dorming with this computer so i guess i also wouldn't want it to be too loud or anything ><
heres the config:
ticket number: 422920
http://www.digitalstormonline.com/comploadsaved.asp?id=406199
Dragoonseal View Drop Down
  Quote Dragoonseal Quote  Post ReplyReply bullet Posted: 17 Jul 2010 at 2:57pm
What resolution does your monitor support up to?
Lilim
Intel Core i7 920 @4.2GHz
  Quote doedoe Quote  Post ReplyReply bullet Posted: 17 Jul 2010 at 3:31pm
*sigh* my monitor is a tiny 19 inch. It's currently at 1280 x 1024..
  Quote doedoe Quote  Post ReplyReply bullet Posted: 17 Jul 2010 at 3:39pm
I also don't know which mobo to go with... the x58 micro or LE??
and i heard the GTX 480 is loud/ hot so i went with a 460 SLI..
any thoughts?
  Quote Dragoonseal Quote  Post ReplyReply bullet Posted: 17 Jul 2010 at 4:13pm
Yikes, that's really bad. Perhaps allocate some of the budget to a new monitor?
Perhaps something like ticket #422939, and put the rest to get a 1920x1080 or 1920x1200 monitor. Don't worry about the 480 noise, its fans only rev up when gaming, but all video cards do the same.
Lilim
  Quote doedoe Quote  Post ReplyReply bullet Posted: 17 Jul 2010 at 5:15pm
I noticed a quite prevalent preference for the CM HAF's here on the forums.. I had initially set my eyes on the Storm sniper case and was wondering why the HAF is so commonly preferred over the Sniper or any other cases.
I was also wondering if i should go with stage 1 aircooling or 2 of the noctua coolers?
  Quote doedoe Quote  Post ReplyReply bullet Posted: 17 Jul 2010 at 5:22pm
Oh.. and one more thing.. what's the difference between the X58 LE and Micro?
S.R. View Drop Down
  Quote S.R. Quote  Post ReplyReply bullet Posted: 17 Jul 2010 at 5:42pm
The haf cases have better air flow as far as cooling goes the noctua coolers are very good
Edited by S.R. - 17 Jul 2010 at 5:45pm
  Quote Dragoonseal Quote  Post ReplyReply bullet Posted: 17 Jul 2010 at 5:53pm
Better air flow, lot of room, low cost.
When on a tighter budget, Stage 1 Noctua. With their default fans the larger Noctua NH-D14 does not cool significantly better than the smaller Noctua, just a few degree difference.
The Micro has two full PCIe x16 lanes, the LE has x16/x8/x8/x4 lanes. Even the monster 480 only loses about 2% performance on a x8 lane though, so the LE can do dual or triple SLI or CF just fine, and still has more lanes for any extra add on cards like sound cards, network cards, video capture cards, etc.
If you for sure don't need the extra lanes the Micro is great, but it doesn't have the expandability of the LE.
Lilim
  Quote !ender_ Quote  Post ReplyReply bullet Posted: 17 Jul 2010 at 6:47pm
i agree, save room in the budget and get a good monitor or its a waste in my opinion. if needed, drop to a 470 and get a 1980x1020 monitor
so if the monitor is included in the 2k or less,
consider this and an
dont forget though, that shipping your dso shipping will cost about $60 i believe
