Need serious advice. Thanks in advance
Post Date: 2015-05-05
20NDIANS20 View Drop Down
  Quote 20NDIANS20 Quote  Post ReplyReply bullet Topic: Need serious advice. Thanks in advance
    Posted: 05 May 2015 at 9:40pm
Max $3000
I want a computer system that will last a few years without needing any major upgrades.
Essentially running games at the highest possible graphics and fps, with a small amount of video and photo editing.
Powerful enough to handle all of this with ease, and still be a powerful rig in a few years
Saved Ticket #: 1192995
Chassis Model: Special Deal Hot Seller - Digital Storm Apollo
Motherboard: GIGABYTE G1.Sniper Z97 (Intel Z97 Chipset) (Onboard Creative Sound) <br><strong></strong>
System Memory: 16GB DDR3 1866MHz Digital Storm Certified Performance Series (Highly Recommended) (Hand Tested) <br><strong></strong>
Power Supply: 850W EVGA SuperNOVA <br><strong></strong>
Storage Set 1: 1x SSD (250GB Samsung 850 EVO) <br><strong></strong>
Storage Set 2: 1x Storage (3TB Seagate) <br><strong></strong>
Graphics Card(s): 2x SLI Dual (NVIDIA GeForce GTX 970 4GB (Includes PhysX) <br><strong></strong>
Airflow Control: - No Thanks
Portable Gaming: - No Thanks
Branded Gear: - No Thanks
I do not really have a whole lot of experience with building computers so any advice you can provide me would be greatly appreciated. Google search is only so helpful I'm afraid.
BiohazardX-87 View Drop Down
  Quote BiohazardX-87 Quote  Post ReplyReply bullet Posted: 06 May 2015 at 5:40am
Welcome
Here is some advice I received when looking for the same thing you are.
First, they will need to know the resolution of your monitors to help with Graphics suggestions.
Second, here are some tips. Quoting from the advice people gave me -
MOBO: The Sabertooth MOBO has a longer warranty 5 year vs 3 years
MEMORY: 1600MHz would sufficiently get the job done and save you some cash.
PSU: The 750W SuperNova has the same 10 year warranty and will safely cover what you are running.
STORAGE 1: Switch the SSD for the Samsung PRO.
None of these are necessary changes, just suggestions to save money while maintaining performance, or to improve performance.
Good luck.
  Quote FrankW Quote  Post ReplyReply bullet Posted: 06 May 2015 at 9:44am
Hi 20NDIANS20,
You got some very good suggestions from BiohazardX-87. I agree with everyone of them.
One other thing to consider is to change your CPU cooler to The H20: Stage 2: Corsair H110i GT - 280mm Radiator Liquid CPU. The cost is $70. It gives you a closed loop cooler that works very well in the Apollo case. The cooler will be mounted at the top of the case instead of at the back like the one you chose.
Not to say the one you chose is not good, it is just that the 280mm is bigger with improved cooling. Not quite as important for a stage 1 OC.
  Quote 20NDIANS20 Quote  Post ReplyReply bullet Posted: 06 May 2015 at 9:50am
Thanks for the input guys.
As of right now my display will actually be a 40" HD Vizio tv that i currently have mounted for consoles. I have however heard that HD tvs of this size aren't as great for resolution, and if that is an annoyance i will be purchasing a different display after some research.
