Need som advice please!
Post Date: 2009-02-01
mordrick78 View Drop Down
  Quote mordrick78 Quote  Post ReplyReply bullet Topic: Need som advice please!
    Posted: 01 Feb 2009 at 6:49pm
I am in the market for a computer and I am going to buy a computer from DS. The only problem I keep running into is the build. I am looking for a HAF case, at least 6gb of ram, undecided about air or liquid cooled. Want to play at 1920-1200 resolution. Need a monitor, looking to spend about 4000. Any help would greatly be appreciated.
Sy
  Quote Onkel_Ken Quote  Post ReplyReply bullet Posted: 01 Feb 2009 at 6:52pm
Take a look at my sig. This is what I went with and it was about $3500 with monitor.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 01 Feb 2009 at 6:53pm
OK you looking for high-end or just what you need?
is the monitor price included in the $4000 budget?
  Quote mordrick78 Quote  Post ReplyReply bullet Posted: 01 Feb 2009 at 7:04pm
yes price included monitor, don't wanna break the bank
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 01 Feb 2009 at 7:17pm
here you go Ticket# 239664 --- Price: $3074 (To see this build click here)
System Memory: 6GB DDR3 1333MHz Corsair Dominator DHX (High-Performance)
Card Reader: - No Thanks
Hard Drive Set 2: Multimedia\Data: 500GB Western Digital (16MB Cache) (7200 RPM) (SATA)
Video Card: 1x NVIDIA GeForce GTX 280 1GB (Includes PhysX Technology)
Liquid Color:UV Redish Pink: Medium Glowing Non-conductive Fluid (Requires H20: Stage 3 & UV Lighting)
LCD Display: - No Thanks
Priority Build: - No Thanks
how is that? Get your monitor form newegg to same some moeny.
you get another $175 off the above price with the current promotions when you hit submit.
Edited by DST4ME - 01 Feb 2009 at 7:19pm
  Quote <8) slunK parade Quote  Post ReplyReply bullet Posted: 01 Feb 2009 at 7:32pm
why not SLI 280s? he could easily fit that into his budget
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 01 Feb 2009 at 7:33pm
oh sorry the gpu did not get changed or I didn't change it, its suppose to be this:
here you go Ticket# 239672 --- Price: $3199 (To see this build click here)
Video Card: 1x NVIDIA GeForce GTX 295 1.792GB (Includes PhysX Technology)
  Quote mordrick78 Quote  Post ReplyReply bullet Posted: 02 Feb 2009 at 6:54am
I know this is a stupid question to some...amd vs the i7? any comparison? and also which gpu is better.... the 295 or the 4570x2
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 02 Feb 2009 at 6:54am
i7 is better hands down, and the 295 is the better gpu.
  Quote mordrick78 Quote  Post ReplyReply bullet Posted: 02 Feb 2009 at 7:52am
thanks, do you really need liquid cooling for oc the cpu or would the v8 be ok with it? or is air cooled just for keeping everything stock?
Dsnewb210 View Drop Down
  Quote Dsnewb210 Quote  Post ReplyReply bullet Posted: 02 Feb 2009 at 9:03am
All depends on your budget.. The V8 cooler does just fine though, alot of people get 920s to 4.2 on air..
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 02 Feb 2009 at 5:34pm
liquid allows better OCing then does air. but the v8 is great too, if you can afford it, go with LC
