Need some advice
Post Date: 2009-11-14
Fr4nc15 View Drop Down
  Quote Fr4nc15 Quote  Post ReplyReply bullet Topic: Need some advice
    Posted: 14 Nov 2009 at 10:37am
So I'm on a budget of around $1700 and I think I found a good computer, but I'm not sure if the power supply is what I want and I just want to make sure that all the other components will work together properly. Mainly I am going to use the comp for WoW BF2 and Operation Flashpoint so I wanted something that could run all of those on high settings. So any input would be very much appreciated thanks in advance.
Heres the build link
http://www.digitalstormonline.com/comploadsaved.asp?id=353431
Edited by Fr4nc15 - 14 Nov 2009 at 1:40pm
Sodius View Drop Down
  Quote Sodius Quote  Post ReplyReply bullet Posted: 14 Nov 2009 at 12:05pm
Yes that PSU is more than adequate for your build. I would add another 3gig ram as soon as you can it would help with everything like OC, app speed, etc. etc. If you could swing it I would add it before you buy it. That's just my opinion though. Nice rig by the way.
Edited by Sodius - 14 Nov 2009 at 12:07pm
  Quote Fr4nc15 Quote  Post ReplyReply bullet Posted: 14 Nov 2009 at 1:41pm
I accidentally put the wrong build link in my post...I meant to have a 750w PSU instead of the 1000w, is that still ok or should I stick with the 1000.
Build that I meant to link:
Edited by Fr4nc15 - 14 Nov 2009 at 1:41pm
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 14 Nov 2009 at 3:30pm
no this this what you want:
Here you go Ticket# 353471 --- Price: $1773 (To see this build click here) Price after current promotion $1773
Interior Finish: - Not Available
Trim Accents: - Not Available
Card Reader: - Not Available
Video Card: 1x NVIDIA GeForce GTX 275 896MB (Includes PhysX Technology)
Liquid Color:- Not Available
Enhancements: - Not Available
Chassis Mods: - Not Available
Boost Memory: - Not Available
Tweak Windows: - Not Available
Office: - Not Available
Benchmarking: - Not Available
LCD Display: - No Thanks
