Need Some Build Advice
Post Date: 2009-01-18
mlaug View Drop Down
  Quote mlaug Quote  Post ReplyReply bullet Topic: Need Some Build Advice
    Posted: 18 Jan 2009 at 2:12pm
Howdy!
I've been lurking for awhile and I'm impressed with Digital Storm and the forums.
Its past time for an upgrade, but I'm so far behind the learning curve when choosing a build system that I think I'll ask here for some advice.
I play the Call OF Duty series of shooters, but primarily I'm a combat flight sim player, Il-2 1946, Falcon 4AF, and so on.
I'd like to continue to use XP Pro as my OS.
My budget is around $1,500-1,800.   I don't need the monitor, keyboard, mouse, etc..,  just a box with all the speed and power I can afford.
I could really use some advice, please.
Edit: Kant spel
Edited by mlaug - 18 Jan 2009 at 2:14pm
JamesAstro View Drop Down
  Quote JamesAstro Quote  Post ReplyReply bullet Posted: 18 Jan 2009 at 2:36pm
What resolution do you plan on gaming at?
  Quote mlaug Quote  Post ReplyReply bullet Posted: 18 Jan 2009 at 3:39pm
Il-2 @ 1920x1200 would be nice.  I'm not sure about the COD settings.
  Quote JamesAstro Quote  Post ReplyReply bullet Posted: 18 Jan 2009 at 4:31pm
Here is a special that Digital Storm is running right now. It looks like it would meet your requirements, and it costs $1799.
Link to build 213239
That build comes with the Nvidia GTX 260+ video card. I'm pretty sure it would play your games at 1920 x 1200 just fine. However, maybe somebody else who has tried those games will chime in with more details.
Good luck!
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 18 Jan 2009 at 5:40pm
make your budget around $2000 and I can show you a system you can upgrade down the road to be a beast.
right now the biggest problem is the GPU, with your resolution you need 2 GPUs to play at high settings, but even with one GPU, the price goes over 2000
  Quote mlaug Quote  Post ReplyReply bullet Posted: 18 Jan 2009 at 7:27pm
Thanks for the replies.  This helps a lot.
DST4ME- Could you show me your suggestion build for the $2000 target?
The budget increase just meanms my order will be a little later as opposed to right now, but I can wait.
I'm a "only when I have to" system upgrader.  If I could get a machine that would be expandable later, that might be a better option.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 18 Jan 2009 at 10:31pm
well the beauty of it, is when next year you want more power and have to look at your system and see what it can do, the system I'm talking about will say,"bring it" so you are never gonna look at another pc and say I wish I had that.
If I were in your shoes I would wait, thats all I can say.
here you go Ticket# 231723 --- Price: $2208 (To see this build click here)
System Memory: 3GB DDR3 1333MHz Corsair Dominator DHX (High-Performance)
Card Reader: - No Thanks
Hard Drive Set 1: Operating System: 320GB Western Digital (16MB Cache) (7200 RPM) (SATA)
Video Card: 1x NVIDIA GeForce GTX 260+ 896MB (216 Streams) (Includes PhysX Technology)
LCD Display: - No Thanks
Priority Build: - No Thanks
you get another $125 off with the current promotions, but while it takes you to save money, the price of this GPU will go lower at the same time so this config might very well be a better price later.
  Quote mlaug Quote  Post ReplyReply bullet Posted: 19 Jan 2009 at 6:07pm
Thanks for the suggestions.  Looks like I'll be waiting awhile before I order.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 19 Jan 2009 at 6:44pm
its better that way, trust me, if you had a twin and your twin got one now and you waited and got one in say 4 or 5 month, you would end up with a much better PC and for a better price.
