Need some LC system advice....
Post Date: 2010-04-03
ablahblah View Drop Down
  Quote ablahblah Quote  Post ReplyReply bullet Topic: Need some LC system advice....
    Posted: 03 Apr 2010 at 2:09pm
I've convinced myself the reason of noise in my comp is probably because of my CPU's stock air cooler, since quieting down everything except that doesn't shut it up xD. Anyways, I'm looking around for vendors to construct my own LC system, I can't send it back to DS because I don't have a backup system. I've no clue how exactly to make one however, heh.
Preferably, I'd like to cool a CPU and two vid cards, though I can probably just make due with a CPU cooler. CPU's a i7 920, graphics are dual 9600 GTs. I've considered Asetek's system, which I found this
(can you seriously daisy chain multiple Asetek cooling plates to a single radiator? I've only seen people use a single radiator/cpu cooler combo, never multiple ones)
Anyways, I've heard a lot of backlash against Asetek coolers about it not really being a true LC solution, so I'm just gonna try to construct one of the conventional ones.
Mainly, I need to ask, what are the components you need to build a nice, reliable LC system? Any vendor suggestions?
(Also, some overclocking tips would be nice....since I'll be able to boost up my overclock. i7 920 currently runs at 3.33 Ghz using the stock cooler)
Edited by ablahblah - 14 Apr 2010 at 10:56pm
R4D4RPR00F
Core i7 920 @ 3.9Ghz
Asus Sabertooth X58
EVGA GTX 570
Mushkin 6GB 1414Mhz
  Quote ablahblah Quote  Post ReplyReply bullet Posted: 04 Apr 2010 at 2:19pm
Oh, one more thing, installing a LC system means installing a rad to the back of my system right? Sooo, I'd have to take off that nice backplate to my raven? (I know how to do it, yes)
View of Back Plate
(whoa, that's cool, i made the topic at 2:09 yesterday, and I did a rewrite of it today, at 2:09...)
R4D4RPR00F
Asus Sabertooth X58
EVGA GTX 570
Mushkin 6GB 1414Mhz
Marcus View Drop Down
  Quote Marcus Quote  Post ReplyReply bullet Posted: 05 Apr 2010 at 1:26pm
Here is kind of a tutorial on how to build a simple loop. http://www.maximumpc.com/article/howtos/howto_water_cool_your_pc
AndydViking View Drop Down
  Quote AndydViking Quote  Post ReplyReply bullet Posted: 05 Apr 2010 at 2:00pm
You prolly looking at $250 at least for legit H2O.  http://www.crazypc.com/products/cooling/watercooling.htm.  I  know next to nothing about it but have read those pc kits are ok.
I can tell you from experience that the asetek/corsair h50 isn't that much of an upgrade over stock cooling to make it worth it and i wouldn't use them to cool gpu's.  My temps went down 7*C with a noctua NH-12UP SE2 when i upgraded from the asetek and is quiet.  Almost everyone else will tell you the same thing about the asetek on this forum.  I don't dislike it as much as other members but they have good reason for their feelings.
Edit:  I meant kits like this http://www.crazypc.com/products/PX93800.html in the middle of the page on first link
EDIT 2: Sorry. I missed the bottom part of your post where you came to same conclusion about the asetek lol.  But those are some assembled H2O kits.  Maybe someone with more knowledge of parts and whats needed will chime in about those kits assembled on crazy pc.  I was looking at them myself for when I rebuild my DS pc.
If those kits aren't good know any that are?
Edited by AndydViking - 05 Apr 2010 at 3:12pm
  Quote ablahblah Quote  Post ReplyReply bullet Posted: 05 Apr 2010 at 6:14pm
Hmm, thanks for the link on water cooling 101. I've always wondered though, when "UV Lighting" is mentioned, is it seriously outputting UV radiation? Like, as in, if you're dumb enough to spend enough time near the light, you'll get skin cancer or something?
And I remember that to cool dual graphics cards you have to arrange the tubing for them in a special way, what exactly is that?
EDIT : Wow all these options are overwhelming, can someone just, like, build me a set of links of part recomendations so I can start somewhere... xD I've dual 9600 GTs and a i7 920 (obviously, LG1336 socket)
EDIT (Again) : Annd...how do you make a quick disconnect system....
EDIT #3 : Umm, since my case has my mobo rotated in such a way that the card's are oriented vertically, am I still gonna need to do any sort of special hold-downs for it, or, is it convieniently in an orientation where there's no possibility of my mobo warping in shape?
Herrrrre's a quick look of my internals if you've never seen my DS review post.
EDIT #4 : One more question, so, if I wanted to have a 3/8's system, I'd need tubing that's 3/8's ID right?
Edited by ablahblah - 05 Apr 2010 at 7:09pm
R4D4RPR00F
Asus Sabertooth X58
EVGA GTX 570
Mushkin 6GB 1414Mhz
  Quote ablahblah Quote  Post ReplyReply bullet Posted: 05 Apr 2010 at 8:04pm
Created a LC System on FrozenCPU.com, what do you guys think...
UPDATED
Reservoir - Thermaltake AquaBay M1 2U 5.25" Dual Reservoir / Flow Meter
http://www.frozencpu.com/products/2225/ex-res-79/Thermaltake_AquaBay_M1_2U_525_Dual_Reservoir_Flow_Meter_CL-W0032.html?tl=g30c97s168#blank
Pump - Swiftech MCP655-B™ 12v Water Pump w/ 3/8" Conversion Kit (317 GPH)
http://www.frozencpu.com/products/2128/ex-pmp-27/Swiftech_MCP655-B_12v_Water_Pump_w_38_Conversion_Kit_317_GPH.html?tl=g30c107s154
          - Additional 1/2" ID to 3/8" ID Leakproof Reducer
http://www.frozencpu.com/products/2258/ex-tub-105/12_ID_to_38_ID_Leakproof_Reducer_-_BLACK.html?tl=g30c427s459
Radiator - Black Ice Xtreme II Dual 120mm Radiator
http://www.frozencpu.com/products/2147/ex-rad-12/Black_Ice_Xtreme_II_Dual_120mm_Radiator_Black_w_Customizable_Fittings.html?tl=g30c95s160#blank
Radiator Fans - Cooler Master R4 Series 120x25mm Super Silent Fann (I was being dumb before, 14 CFM Smile, this one's 69 CFM, 2k RPM running amazingly at 19 dBa)
http://www.frozencpu.com/products/9300/fan-574/Cooler_Master_R4_Series_120x25mm_Super_Silent_Fan_-_Dark_Smoke_-_R4-C2R-20AC-GP.html?tl=g36c437s1125
Tubing - 2.5 Meter (8 feet) Feser Tube Active UV Blue Hose - Retail Packed - 3/8" ID (1/2"OD) Anti-Kink Tubing
http://www.frozencpu.com/products/8666/ex-tub-458/25_Meter_8_feet_Feser_Tube_Active_UV_Hose_-_Retail_Packed_-_38_ID_12OD_Anti-Kink_Tubing_-_Clear_UV_Blue.html?tl=g30c99s171#blank
Coolant - Distilled Water
CPU Block - Swiftech Apogee GTZ i7 CPU Waterblock - Socket LGA 1366
http://www.frozencpu.com/products/9160/ex-blc-620/Swiftech_Apogee_GTZ_i7_CPU_Waterblock_-_Socket_LGA_1366.html?tl=g30c325s839#blank
GPU Blocks - Blegh. Screw Graphics for now.
SLI Connectors - Screw SLI for now
Any Safety Devices - ThermalTake FlowTX Meter with Temperature Indicator
http://www.frozencpu.com/products/6876/ex-flo-05/Thermaltake_Flow_TX_Plus_Flow_Meter_w_Temperature_Indicator_CL-W0138.html?tl=g30c229s579
Quick Release Valves - Koolance QDC (High Flow) Shutoff Nozzle, Female Panel Barb (10mm, 3/8")
http://www.frozencpu.com/products/8388/koo-162/Koolance_QDC_High_Flow_Shutoff_Nozzle_Female_Panel_Barb_10mm_38_VL3-F10B-P.html?tl=g30c405s1027
                                 -Koolance QDC (High Flow) Shutoff Nozzle, Male Panel Barb (10mm, 3/8”)
http://www.frozencpu.com/products/7150/koo-112/Koolance_QDC_High_Flow_Shutoff_Nozzle_Male_Panel_Barb_10mm_38_VL3-M10B-P.html?tl=g30c405s1027
Thermal Paste Cleaner - ArtiClean 1 & 2
http://www.frozencpu.com/products/3778/thr-20/ArctiClean_1_and_2_Thermal_Material_Remover_and_Surface_Purifier_-_60ml_Kit.html?tl=g8c123s248#blank
Thermal Paste - Arctic MX-3
http://www.frozencpu.com/products/9633/thr-68/Arctic_Cooling_MX-3_Super_High_Performance_Non-Conductive_Thermal_Compound_4g.html#blank
Lighting - Dual 12 inch Cold Cathode Kit - UV Blue
http://www.frozencpu.com/products/2998/lit-46/Dual_12_Cold_Cathode_Kit_-_Ultra_Bright_UV.html?tl=g6c75
Miscellaneous - Tube Cutter
http://www.frozencpu.com/products/2248/ex-tub-04/Tube_Cutter.html
Planned Loop:
Reservoir -> Pump -> Quick Release -> 1st Stop CPU WaterBlock -> Quick Release -> Primary E-GeForce 9600 GT WaterBlock -> Quick Release -> Secondary E-GeForce 9600 GT WaterBlock -> Quick Release -> Radiator -> Repeat Loop
Edited by ablahblah - 05 Apr 2010 at 9:59pm
R4D4RPR00F
Asus Sabertooth X58
EVGA GTX 570
Mushkin 6GB 1414Mhz
Dragoonseal View Drop Down
  Quote Dragoonseal Quote  Post ReplyReply bullet Posted: 05 Apr 2010 at 8:31pm
Lalala, it's times like this that I appreciate my Noctua NH-D14 more and more.
Lilim
Intel Core i7 920 @4.2GHz
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 05 Apr 2010 at 8:35pm
if you are doing this just for quietness..... seems pretty crazy. lol
the graphics cards, I would sell them and get one decent card.. will be a lot better way to go.. Investing more money into those cards does not make any sense to me.. but to each his own.
any time you see ThermalTake and water cooling run... lol
a 240 mm radiator and an i7 plus 2 graphics cards is way to small.
never use pre-made coolants, they are all junk, have poor performance, and will clog up the water blocks.
artic silver 5 is a poor TIM, MX-2 is a lot better, and easier to use.
 radiator, could not have picked a worse one for those fans..
looking at a lot of money on that list, and that would be a very poor performing water cooling setup, honestly better to get the Asetek.
If you want to get into water cooling, I can help, but to do things right, it will take time, cost a lot of cash, and not improve your performance much..
Edited by justin.kerr - 05 Apr 2010 at 8:38pm
  Quote ablahblah Quote  Post ReplyReply bullet Posted: 05 Apr 2010 at 9:28pm
my current cooling "setup"
i7 - Stock
9600 GTs - Stock
Case - Vertically Mounted PCI Cards w/180mm fans
it's somehow been enough to amp up the i7 from 2.66 to 3.2.
stock cooler's noise level has been bugging me for awhile, i've sourced it too.
yep, i've been looking at a single graphic card option for a long time now, just haven't had the right circumstances to get it. looking online, GTX285's run for 440 or so, and wait, why are the GTX470's cheaper than that by 50....
so for coolants, just use distilled water like everyone says?
the fans, eh, i just put them in there because they were low dBa. i really had no clue what to look for....
EDIT: Wtf was i doing there. 14.3 CFM fans for rads SmileSmileSmileSmile
I updated the list, fans are now 69 CFM's with low dBa still, updated to MX-3 compound, and killed the GPU stuff. And replaced the tubing with UV reactive stuff. Hell, I can just use distilled water, I can get it free or cheap because my mom happens to work in the medical industry.
Edited by ablahblah - 05 Apr 2010 at 9:55pm
R4D4RPR00F
Asus Sabertooth X58
EVGA GTX 570
Mushkin 6GB 1414Mhz
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 05 Apr 2010 at 9:57pm
well, you might be replacing a slightly noisy cooler, with a noisier one. lol
distilled water, but you need a biocide to kill the nastiesl, I use a chunk of silver, you can use PT nuke, or several others.
so if you want to post your new list we can tweak it more. lol
  Quote ablahblah Quote  Post ReplyReply bullet Posted: 05 Apr 2010 at 10:00pm
*updated previous list....
(fans run at 19 dBa, not absolutely horrible, but not that good either. then again, i DO have that extra slot on my fan controller...)
hey, it's distilled water coming from a medical research institute, if it's got little buggers in it then we have a problem Smile
Edited by ablahblah - 05 Apr 2010 at 10:03pm
R4D4RPR00F
Asus Sabertooth X58
EVGA GTX 570
Mushkin 6GB 1414Mhz
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 05 Apr 2010 at 10:05pm
you will get little buggers in there, sooner or later, lol
  Quote Marcus Quote  Post ReplyReply bullet Posted: 05 Apr 2010 at 10:06pm
Whats the biggest radiator you can fit inside the raven case? just curious.
  Quote ablahblah Quote  Post ReplyReply bullet Posted: 05 Apr 2010 at 10:08pm
Um, you don't. Smile
They go on the exterior i believe.
On top? Occupied by PCI slots. On the bottom? PSU's there. Inside the back area? Um, wires and the mobo are occupying already. In front? Are you nuts? Only left is exterior in back.
Edited by ablahblah - 05 Apr 2010 at 10:09pm
R4D4RPR00F
Asus Sabertooth X58
EVGA GTX 570
Mushkin 6GB 1414Mhz
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 05 Apr 2010 at 10:11pm
UPDATED
no no no. Thermaltake= no no for water cooling... never ever..
why not save a few bucks and get the regular pump and use 1/2 tubing?
for 1500 RPM fans or faster, this radiator is ok, but loud... for 1500 RPM and lower save some money and get the XSPC RX 240, or 360 if you can fit it..
ok.... gentle typhoons 1450 for quietness, better performing/
primochill LRT pro 1/2" is about the best tubing around
Coolant - Distilled Water '
have to add biocide. then good to go
the EK supremem HF is better, the Swiftec XT is also better
stay far away from this company   themaltake = crap of all water cooling suplies
I would pass on the quick disconnects, but up to you..
  Quote Marcus Quote  Post ReplyReply bullet Posted: 05 Apr 2010 at 10:12pm
Well, i believe if you do some modding you can fit a 360 rad on the bottom of the case.
  Quote Marcus Quote  Post ReplyReply bullet Posted: 05 Apr 2010 at 10:14pm
  Quote ablahblah Quote  Post ReplyReply bullet Posted: 05 Apr 2010 at 10:15pm
i've heard better things about 3/8's tubing, and I can only find that specific swiftech pump on frozencpu. I'm limiting it to one website because I don't wanna go handing out credit card info to 15 different sites and having to call in numerous RMA's later on if I need to.
The extra reducer was just in case it ships with a missing reducer. Someone has reported this in the comments.
what's the deal with Thermaltake anyways?
Marcus. That's the Raven 2. Easily possible with that case.
I have the original raven. This baby.
In my opinion, looks a lot better aesthetically than the Raven 2, and also has support for E-ATX.
(also, dude, that's one freaking hell of a bend he has in one of his tubes. that's not good.)
Edited by ablahblah - 05 Apr 2010 at 10:18pm
R4D4RPR00F
Asus Sabertooth X58
EVGA GTX 570
Mushkin 6GB 1414Mhz
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 05 Apr 2010 at 10:15pm
  Quote ablahblah Quote  Post ReplyReply bullet Posted: 05 Apr 2010 at 10:17pm
Yesss. that's more like it.
Wait, where's that guy's pump...OHHH i see, pump/reservoir combo.
R4D4RPR00F
Asus Sabertooth X58
EVGA GTX 570
Mushkin 6GB 1414Mhz
  Quote Marcus Quote  Post ReplyReply bullet Posted: 05 Apr 2010 at 10:17pm
Thermaltake makes cases.    Oh i didnt notice u had the raven one.
Edited by Marcus - 05 Apr 2010 at 10:20pm
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 05 Apr 2010 at 10:21pm
I would just go 1/2" but, do what you want.
Gary, the owner of http://www.sidewindercomputers.com/ is great to deal with, and very good about problems/returns. might check out his site.
Thermaltake has screwed over a lot of water cooling people, for one,  two they use a lot of aluminum. You can't have one drop of aluminum in a water loop, if you use copper water blocks.. like all water blocks are....Unless you run a coolant that will slow Galvanic corrosion.
  Quote ablahblah Quote  Post ReplyReply bullet Posted: 05 Apr 2010 at 10:24pm
Though the case is steel, many of silverstone's add-on components are aluminum made, which is their tradition. Is that bad?
have checked out sidewinder before, more familiar with frozencpu though.
Edited by ablahblah - 05 Apr 2010 at 10:26pm
R4D4RPR00F
Asus Sabertooth X58
EVGA GTX 570
Mushkin 6GB 1414Mhz
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 05 Apr 2010 at 10:25pm
case is fine, it is there water cooling parts that are soo bad, you can't have aluminum in the loop...
  Quote ablahblah Quote  Post ReplyReply bullet Posted: 05 Apr 2010 at 10:27pm
aluminum just messes up and corrodes everything, right....
oh and, where the heck would i exactly mount the pump. nicely, velcro or zip tie i'd rather not do, but I could if really necessary.
also, is there any advantage or point to having a chipset LC'd?
hey, i just noticed something. liquid cooling doesn't really have ANY form of cooling at all, it's just really a heat exchange system, right?
Edited by ablahblah - 05 Apr 2010 at 10:34pm
R4D4RPR00F
Asus Sabertooth X58
EVGA GTX 570
Mushkin 6GB 1414Mhz
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 05 Apr 2010 at 10:35pm
matters the pump, the DDC 3.25 with the XSPC res top like the one I showed you in the pic is a great performer. all pumps need to be mounted in a way that stop the vibration from resonating through the case, so rubber, or good velrco.. The pump come with mounting screws, or a sticky, thick pad.
Mixing metals like copper and aluminum, will cause corrosion, that will eat away the parts.
a triple radiator would be a good idea, and more flow= lower temps.. to a point, most setups won't see much temp reduction once you get past 1.5 Gal per min, here is a recent water block test. should explain better what I am saying.
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 05 Apr 2010 at 10:39pm
liquid cooling the chipset, is mostly for looks, all of my classifieds have chipset blocks, because the VRM run so hot that I ran into stability problems when overclocking, so I first added fans to the stock cooler, which worked fine, but was loud, and looked like crap, so went full coverage water block.
Liquid cooling is just air/water exchanger.
  Quote ablahblah Quote  Post ReplyReply bullet Posted: 05 Apr 2010 at 10:43pm
so the pumping speed doesn't really matter if you're over 1.5 gallons per minute/90 gallons per hour? that's good to know...
for graphics cooling, i've read that instead of going from CPU to Graphics, you can just hook up a T connector before the CPU and have coolant direct to both simultaneously. is that seriously a good idea?....
R4D4RPR00F
Asus Sabertooth X58
EVGA GTX 570
Mushkin 6GB 1414Mhz
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 06 Apr 2010 at 8:44am
1.5 GPM is harder to get that you might think. lol I can calc out your flow rate, and on the first one you figured It would be no where near 1.5 GPM, maybe half that.. lol
the T connector before the GPU, remember, that water will take the path of least resistance, and the CPU water block will be the most restrictive, so it won't get crap for flow, raising temps throught the roof. You can do a T and run multiple water block, and it will work, if the flow restriction is the same on each block after the T.
  Quote ablahblah Quote  Post ReplyReply bullet Posted: 06 Apr 2010 at 10:27am
wait...how do u calculate flow rate?
ohhh, so basically, running everything in series is the safe way to do things, if the two circuits connected to the T differentiate in flow resistance, one or the other won't get the right flow...
by the way, happen to know the normal operating temp for a GTX470...?
i might upgrade to a solo GTX470 in the future, it's better than both my cards combined...
Does this look worthwhile to you?
Swiftech MCR220 Drive Dual 120mm Radiator / Reservoir w/ MCP350 Pump Combo
http://www.frozencpu.com/products/10088/ex-rad-172/Swiftech_MCR220_Drive_Dual_120mm_Radiator_Reservoir_w_MCP350_Pump_Combo_MCR220-Drive.html?tl=g30c97s1076#blank
uh, one more thing, what exactly is a dual-loop system?..
(wait, about coolant fluids, i thought it was always safer to use something premixed that's non-conductive, what if a leak springs in full system operation and  (distilled) water leaks and sprays all over my parts and shorts everything??)
( Feser Aqua Non Conductive Ultra Pure Water  ?
http://www.frozencpu.com/products/7015/ex-liq-94/Feser_Aqua_Non_Conductive_Ultra_Pure_Water_-_1000_ml_FA-0054.html?tl=g30c103s753 )
Edited by ablahblah - 06 Apr 2010 at 11:07am
R4D4RPR00F
Asus Sabertooth X58
EVGA GTX 570
Mushkin 6GB 1414Mhz
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 06 Apr 2010 at 12:11pm
that swiftech setup is ok, but very expensive.. $50 rad, and $50 pump for $200. lol
I can calculate flow if you give me all of the parts.
GTX 470, yeah that is like 5-6 of your cards now?
dual loop means 2 separate loops, so 2 pumps, two reservoirs, ect.. one loop for CPU, one loop for GPU.. make sense?
distilled water is non-conductive.
but all pre-mix coolants, and distilled water, over time become conductive.
  Quote ablahblah Quote  Post ReplyReply bullet Posted: 06 Apr 2010 at 4:29pm
it's also a reservoir, all in one LC combo, but then again, I'm not liking 29 dBa on the pump (which is obviously going to be exterior mounted and spread noise out easier). i thought LC was supposed to make your computer QUIETER....
hey wait, I just had an idea.... I have two 120mm fans already mounted on my system (one on the side currently functioning as intake, one on top functioning as outtake) and two 180mm fans mounted at the bottom. 180mms are supposedly intaking air from the bottom of the case, and dragging it to the PSU and HDD, the 180mm over the PSU then blowing air to the main cavity.
Would it be realistic to swap both my 120mm fans to outtakes, then run a dual loop system and strap small, single radiators to those fans instead of having one large exterior radiator?
Edited by ablahblah - 06 Apr 2010 at 4:36pm
R4D4RPR00F
Asus Sabertooth X58
EVGA GTX 570
Mushkin 6GB 1414Mhz
  Quote ablahblah Quote  Post ReplyReply bullet Posted: 06 Apr 2010 at 5:03pm
UPDATED AGAIN
Dual Loop
Reservoir - Swiftech MCR120 "Quiet Power" 120mm Radiator w/ Reservoir
http://www.frozencpu.com/products/6570/ex-rad-125/Swiftech_MCR120_Quiet_Power_120mm_Radiator_w_Reservoir_-_MCR120-QP_Res.html
Pumps - Swiftech MCP350™ 12v Water Pump (Native 3/8") (92.4 GPH) (DIRECTLY MOUNTABLE ON RESERVOIR)
http://www.frozencpu.com/products/2132/ex-pmp-31/Swiftech_MCP350_12v_Water_Pump_Native_38_924_GPH.html#blank
Pump Attached Quick Release - Koolance QDC (High Flow) No-Spill Shutoff Nozzle, Male Panel Barb (10mm, 3/8")
http://www.frozencpu.com/products/10355/koo-213/Koolance_QDC_High_Flow_No-Spill_Shutoff_Nozzle_Male_Panel_Barb_10mm_38_VL3N-M10B-P.html
                                              - Koolance QDC (High Flow) No-Spill Shutoff Nozzle, Female Compression (10mm, 3/8" x 13mm, 1/2")
http://www.frozencpu.com/products/9499/koo-180/Koolance_QDC_High_Flow_No-Spill_Shutoff_Nozzle_Female_Compression_10mm_38_x_13mm_12_VL3N-F10S.html
Radiators - Swiftech MCR120 "Quiet Power" 120mm Radiator w/ Reservoir
Radiator Fans - 2x Cooler Master R4 Series 120x25mm Super Silent Fan (wait, the Scyth 1450's run at 22 dBa and 50 CFM, these run at 19 dBa and 69 CFM...)
http://www.frozencpu.com/products/9303/fan-575/Cooler_Master_R4_Series_120x25mm_Super_Silent_Fan_-_Blue_LED_-_R4-L2R-20AC-GP.html
Quick Release Attached To Radiator - Koolance QDC (High Flow) No-Spill Shutoff Nozzle, Male G1/4 Thread
http://www.frozencpu.com/products/9503/koo-184/Koolance_QDC_High_Flow_No-Spill_Shutoff_Nozzle_Male_G14_Thread_VL3N-MG.html
                                                        Koolance QDC (High Flow) No-Spill Shutoff Nozzle, Female Angle Compression (10mm, 3/8" x 13mm, 1/2")
http://www.frozencpu.com/products/10264/koo-209/Koolance_QDC_High_Flow_No-Spill_Shutoff_Nozzle_Female_Angle_Compression_10mm_38_x_13mm_12_VL3N-F10L.html
Coolant - Distilled Water coming from a Medical Research Institute Smile
Antibio - Feser Base Corrosion Blocker
http://www.frozencpu.com/products/7086/ex-liq-95/Feser_Base_Corrosion_Blocker_-_50ml_FB-0055.html
CPU Block - Swiftech Apogee XT Extreme
http://www.frozencpu.com/products/9767/ex-blc-679/Swiftech_Apogee_XT_Extreme_Flagship_Performance_CPU_Waterblock_Sockets_775_1156_1366.html
GPU Blocks - Screw Graphics for now.
SLI Connectors - Screw SLI for now.
Any Safety Devices - Koolance INS-FM17 Coolant Flow Meter with Signal Amplifying Adapter Board
http://www.frozencpu.com/products/8294/koo-158/Koolance_INS-FM17_Coolant_Flow_Meter_and_Adapter_Board_No_Fittings.html?tl=g30c229s582#blank
Planned Loop:
Note: Reservoir A and B are mounted together in the same frame.
Reservoir A -> Pump I -> Quick Release Set 1 -> Core i7 -> Quick Release Set 2 -> Reservoir A
Reservoir B -> Pump II -> Quick Release Set 2 -> GPU  (GTX470?) -> Quick Release Set 3 -> Reservoir B
Edited by ablahblah - 06 Apr 2010 at 6:26pm
R4D4RPR00F
Asus Sabertooth X58
EVGA GTX 570
Mushkin 6GB 1414Mhz
Exsidium View Drop Down
  Quote Exsidium Quote  Post ReplyReply bullet Posted: 06 Apr 2010 at 6:02pm
(Justin to ablahblah)
I'm looking forward to completing your training. In time you will call me Master.
SmileSmileSmileSmileSmileSmile
  Quote ablahblah Quote  Post ReplyReply bullet Posted: 06 Apr 2010 at 6:08pm
LOL SmileSmileSmileSmileSmileSmile
hey justin, was just looking at your rig post, you just leave a block of silver inside the reservoir all the time? i thought you originally meant just using silver and a tub of water to purify it, simply leaving a block in the reservoir itself works?
Edited by ablahblah - 06 Apr 2010 at 6:14pm
R4D4RPR00F
Asus Sabertooth X58
EVGA GTX 570
Mushkin 6GB 1414Mhz
This page was generated in 8.105469E-02 seconds.
