Need tips for OC ASUS P6T Delux with i7 965 CPU
Post Date: 2009-02-20
Mannyfit75 View Drop Down
  Quote Mannyfit75 Quote  Post ReplyReply bullet Topic: Need tips for OC ASUS P6T Delux with i7 965 CPU
    Posted: 20 Feb 2009 at 12:36pm
I need tips on OC ASUS P6T Deluxe with i7 965 CPU.  I would like to OC mine to 4 Ghz and keep it stable. My cooler is Coolit Domino ALC.  I currently OC my CPU at 3.8 Ghz with voltage of 1.38.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 20 Feb 2009 at 4:24pm
CAll DS for that, they will walk you thru
  Quote <8) slunK parade Quote  Post ReplyReply bullet Posted: 20 Feb 2009 at 6:12pm
or go to some asus forums or something were they probly have dedicated threads for asus products
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 20 Feb 2009 at 6:30pm
LOL he does not need to go to another forum we could help him here, but I think since DS is warranting the OC, its best to let them do for him and in the process he can learn also.
otherwise all he needs to do is take up the multiplier one or raise the fsb
  Quote Mannyfit75 Quote  Post ReplyReply bullet Posted: 20 Feb 2009 at 7:40pm
Well, I run some Prime 95 and Real Temp and the limitation for my overclock is at 3.8 Ghz. I think I am fine with this clock speed.  I do not think the Coolit Domino ALC can keep my CPU stable at 4 Ghz.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 20 Feb 2009 at 8:05pm
there is not much difference between 3.8 and 4.0 anyways
PatrickB View Drop Down
  Quote PatrickB Quote  Post ReplyReply bullet Posted: 20 Feb 2009 at 11:38pm
This is true, but it does raise your E-peen. And you get that good feeling of saying you have a 4ghz overclock. Ouch
Q9550 @ 3.4Ghz for now
Xigmatek Thor's Hammer
MSI P45 Neo2-fr
6gig 1066 Corsair Dominator
XFX Radeon HD 4890
PC Power&Cooling 750W
Seagate Barracuda 500Gb
Antec 900
Vista 64bit
  Quote Mannyfit75 Quote  Post ReplyReply bullet Posted: 21 Feb 2009 at 1:09am
Hug
true. There isn't. 3.8 is close as I can get to 4 Ghz.  I noticed Overclockers who go over 4 Ghz either use liquid nitrogen  cooling
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 21 Feb 2009 at 1:14am
what was your highest temp?
you know your OC is fine if the temps don't go high during your usage
  Quote Mannyfit75 Quote  Post ReplyReply bullet Posted: 21 Feb 2009 at 1:21am
I am  doing a Real Temp Test now to see how high it can go. I'll send some images shortly
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 21 Feb 2009 at 1:21am
see what it does after 30 minutes to an hour of playing your games, I doubt going to 4.0 from 3.8 will make that much of a heat difference.
frostbite would have done it for you
Edited by DST4ME - 21 Feb 2009 at 1:22am
  Quote Mannyfit75 Quote  Post ReplyReply bullet Posted: 22 Feb 2009 at 2:17am
It went high at 81-82 on Prime 95.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 22 Feb 2009 at 2:40am
ya I guess you better leave it at that.
Edited by DST4ME - 22 Feb 2009 at 2:40am
Hammer View Drop Down
  Quote Hammer Quote  Post ReplyReply bullet Posted: 22 Feb 2009 at 11:09am
82 degrees is pushing dangerously close to the 85 limit. I'd say your e-peen is just fine where it is. Ermm Push it much farther and you're gonna burn the tip. Clown
"It is important to realize that any lock can be picked with a big enough hammer."
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 22 Feb 2009 at 4:42pm
The danger point is more like 95c to 100c
Edited by DST4ME - 22 Feb 2009 at 4:43pm
  Quote Mannyfit75 Quote  Post ReplyReply bullet Posted: 23 Feb 2009 at 11:12am
According to Intel Website,  the Intel i7 core temp limit is 90-100 c like DST4ME said.
Edited by Mannyfit75 - 23 Feb 2009 at 11:12am
  Quote Mannyfit75 Quote  Post ReplyReply bullet Posted: 23 Feb 2009 at 11:13am
One note, it only remain high at 81-82 degrees Celsius at 100% load.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 23 Feb 2009 at 3:25pm
yes its the load temps that matter
  Quote Mannyfit75 Quote  Post ReplyReply bullet Posted: 10 Mar 2009 at 2:19am
In increased the bus speed to 134
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 10 Mar 2009 at 4:12am
are you max temp at 81c still? if yes then leave it alone
LDLD View Drop Down
  Quote LDLD Quote  Post ReplyReply bullet Posted: 13 Mar 2009 at 4:59am
Hey Manny,
Any luck on the OC?
This page was generated in 6.835938E-02 seconds.
