New And Need Help With This Build
Post Date: 2019-01-13
Texcalon View Drop Down
  Quote Texcalon Quote  Post ReplyReply bullet Topic: New And Need Help With This Build
    Posted: 13 Jan 2019 at 3:12pm
[$4,000 (A little over is okay)]
[I want it to be able to handle any game on max settings.]
[Gaming]
[Nothing in particular.]
[I'm very new and know nothing about computers so if anyone can tell me that this build is good for what I want that would be very appreciated.]
Chassis
Core Components
Processor: Intel Core i9-9900X (10-Core) 3.50GHz
Motherboard: MSI X299 TOMAHAWK (Intel X299 Chipset) (Up to 3x PCI-E Devices)
System Memory: 16GB DDR4 3000MHz Digital Storm Performance Series
Power Supply: 750W Corsair RM750x (Fully Modular)
Storage / Connectivity
Storage Set 2: 1x Storage (3TB Seagate / Toshiba)
Graphics / Multimedia
Graphics Card(s): 1x GeForce GTX 1060 6GB (VR Ready)
Digital Storm Engineering
Extreme Cooling: H20: Stage 2: Digital Storm Vortex 240mm Liquid CPU Cooler (Fully Sealed + No Maintenance)
Digital Storm TwisterBoost Technology
Software
Accessories / Goodies
Customer Care
Edited by Texcalon - 13 Jan 2019 at 3:21pm
  Quote Cretae Quote  Post ReplyReply bullet Posted: 13 Jan 2019 at 4:44pm
That's not the best choice of proc for gaming. But that's very good news because the right choice is much less expensive. Will allow you to properly build a gaming rig around the video card where the true power comes into play.
The key detail is what monitor resolution you intend to game at. That will define your video requirement. At your budget, we can recommend a highly capable gaming computer.
  Quote Texcalon Quote  Post ReplyReply bullet Posted: 13 Jan 2019 at 4:49pm
Hello, thanks for responding. The monitor that I planned on getting is this one that is offered in the accessories: MSI 24 inch MAG24C Curved Series (144Hz Refresh) (1ms Response) (1920x1080).
  Quote Cretae Quote  Post ReplyReply bullet Posted: 14 Jan 2019 at 6:57am
Okay, here's the optimal build for the system you asked for.
Digital Storm Desktop - Config ID 2210559
$3,131.00     $3,131.00
Motherboard: MSI MPG Z390 GAMING PRO CARBON AC (Intel Z390 Chipset) (Up to 3x PCI-E Devices)
Storage Set 1: 1x SSD M.2 (500GB Samsung 970 EVO) (NVM Express)
Storage Set 2: 1x Storage (3TB Seagate / Toshiba / Hitachi)
Graphics Card(s): 1x GeForce GTX 1070 8GB (VR Ready)
Extreme Cooling: H20: Stage 2: Corsair H100i PRO - 240mm Liquid CPU Cooler (Fully Sealed + No Maintenance)
Display: MSI 24 inch MAG24C Curved Series (144Hz Refresh) (1ms Response) (1920x1080)
Branded Gear: - No Thanks
(I took out a bunch of stuff you didn't get to make it easier to read.)
The CPU is the top gaming proc you want.
The SSD is NVMe, up to 10x faster than a SATA drive. Samsung is the top brand with a 5 year warranty
The All-in-one cooler from Corsair is top quality with a 5 year warranty.
The video card is the best price/performance for 1080p monitors.
There is room in your budget for a lot more power if you want. You could go with a 1440p monitor, in which case I would advise the RTX 2080 for the best performance at that resolution. The 31" MSI 1440p monitor and the RTX 2080 would bring you to around $3815. All the other parts would remain the same, as they are already premium.
There's nothing wrong with 1080p gaming, I've been there for the last 8 years!
  Quote Texcalon Quote  Post ReplyReply bullet Posted: 14 Jan 2019 at 8:32am
Wow thank you so much. This is extremely helpful. You're the best.
Nagooker View Drop Down
  Quote Nagooker Quote  Post ReplyReply bullet Posted: 14 Jan 2019 at 9:47am
I would suggest spending the extra 60$ or so on a rtx 2070, so if you decide to upgrade to 1440P you will have a smoother experience.
  Quote Texcalon Quote  Post ReplyReply bullet Posted: 14 Jan 2019 at 9:59am
So the RTX 2070 will work with the current monitor I initially planned on getting, along with a 1440p?
  Quote Nagooker Quote  Post ReplyReply bullet Posted: 14 Jan 2019 at 11:39am
Yes, it will demolish 1080P and run 100+ fps on 1440pon most games
Edited by Nagooker - 14 Jan 2019 at 11:40am
  Quote Texcalon Quote  Post ReplyReply bullet Posted: 14 Jan 2019 at 11:49am
Okay. I think for now I will stick with the current 1080p monitor but get the RTX 2070 like you recommended. Thank you for helping.
Edited by Texcalon - 14 Jan 2019 at 11:51am
HockeyBuck View Drop Down
  Quote HockeyBuck Quote  Post ReplyReply bullet Posted: 14 Jan 2019 at 1:06pm
Good build and solid advice from both Cretae and Nagooker!
I do agree with Nagookers advice to go with the RTX 2070 here because it’s still well within your stated budget, and it’s the most current “sweet spot” RTX card that can run most everything on high settings... and it should serve you a bit farther down the road.
Bootystank911 View Drop Down
  Quote Bootystank911 Quote  Post ReplyReply bullet Posted: 14 Jan 2019 at 6:37pm
Phew, yeah i9 9900x would go to waste with a gtx1060. I9 9900x needs at minimum a rtx 2070 or higher. I would also get the 512GB SSD 970 pro extreme for your high end games that eat up Frames Per Second.
BootyStank911
  Quote Texcalon Quote  Post ReplyReply bullet Posted: 14 Jan 2019 at 6:43pm
Is this what you are mentioning? SSD M.2 (512GB Samsung 970 PRO) (NVM Express) (Extreme Performance)
  Quote Bootystank911 Quote  Post ReplyReply bullet Posted: 14 Jan 2019 at 6:55pm
Yes sir, the difference is in thd read speed after a game is downloaded. The write speed you can think about it as uploading a video. The higher the numbers the quicker you can manipulate/recieve the data.
BootyStank911
  Quote Texcalon Quote  Post ReplyReply bullet Posted: 14 Jan 2019 at 6:57pm
Okay, thank you. If anything helps with frames I will most likely purchase it.
  Quote Bootystank911 Quote  Post ReplyReply bullet Posted: 14 Jan 2019 at 7:00pm
144hz = 144 frames....that system can run well beyond the 100's
BootyStank911
  Quote Texcalon Quote  Post ReplyReply bullet Posted: 14 Jan 2019 at 7:01pm
Gotcha.
  Quote Bootystank911 Quote  Post ReplyReply bullet Posted: 14 Jan 2019 at 7:03pm
Btw your HDD drive creates extra heat/noise i would look into just swapping it out gor a 500GB SSD instead
BootyStank911
  Quote Texcalon Quote  Post ReplyReply bullet Posted: 14 Jan 2019 at 7:22pm
Are you saying this: SSD (500GB Digital Storm Performance Series) for the Storage Set 2?
  Quote Bootystank911 Quote  Post ReplyReply bullet Posted: 14 Jan 2019 at 7:25pm
Yes sir. Unless you need the HDD for older games on CDRom or its large space for photos then fine keep it. But if youre strictly gaming i would suggest the ssd
BootyStank911
  Quote Texcalon Quote  Post ReplyReply bullet Posted: 14 Jan 2019 at 7:26pm
Okay. You've been a big help. Thank again.
  Quote Cretae Quote  Post ReplyReply bullet Posted: 15 Jan 2019 at 4:54am
The difference between the 1070 and the 2070 is $105. Still not a lot if you anticipate 1440p gaming before you want different parts. There seems little gain in not going ahead with a 1440p monitor since you're getting the card for it, and it's still in budget.
The 970 PRO is said by Samsung not intended for comsumer use. Here again, there's not a major price difference, but there is very little gain between the two. You'd never see that slight extra speed in a gaming rig. It will have no effect on frame rates.
You should think hard about trading 3TB of storage for 500GB IMO. Two 500 GB drives would not be nearly enough for me. NVMe is not necessary for loading games. For faster loading and more capacity, get a Samsung SATA drive, 1 or 2 TB, but not here. Look at Samsung 860 EVO SATA SSD's on Amazon, and price compare.
If you simply must burn money, at least get the 1TB NVMe.
  Quote Texcalon Quote  Post ReplyReply bullet Posted: 15 Jan 2019 at 8:46am
Ah I see. I think I am just going to go ahead and go with a 1440p monitor and keep the storage you initially recommended. Thanks for helping.
  Quote hoserator Quote  Post ReplyReply bullet Posted: 16 Jan 2019 at 3:10am
(emphasis mine)
Get the Optane instead.
Edited by hoserator - 16 Jan 2019 at 5:13am
  Quote Cretae Quote  Post ReplyReply bullet Posted: 16 Jan 2019 at 5:00am
I think you're going to be very pleased. It's my pleasure to help if I can.
One thing I've learned in over 30 years of gaming (yes, I said that!) is the folks who go over the top spending on very marginal performance gains find that in a year in a half, their rig is out of date in almost every aspect. My approach is simply to save that money by getting what you need now so you can easily upgrade when you need to later. Seems to me that keeps you much closer to the cutting edge so much longer.
This page was generated in 0.1005859 seconds.
