NEW BUYER! HELP!
Post Date: 2016-12-26
brycedanielsmith View Drop Down
  Quote brycedanielsmith Quote  Post ReplyReply bullet Topic: NEW BUYER! HELP!
    Posted: 26 Dec 2016 at 3:01am
I am brand new to this computer stuff. I have never really gamed on a computer before but I do want to get into it. I also edit videos for YouTube so I need something that can do that as well. I am planning to have three monitors, so I need something that can support that as well.
Budget: Under $1,200
Any advise would be awesome! Thanks!
Bryce Smith
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 26 Dec 2016 at 8:45am
Here's a build that is a tad over budget but it gives you what I would recommend for you gaming and editing.....
Configuration Code: 1572437
Total Price with Instant Savings: $1,257.00
Direct Load URL: https://www.digitalstorm.com/configurator.asp?id=1572437
Chassis Model: Special Deal Hot Seller - Digital Storm VANQUISH 5
Processor: Intel Core i7 6700 3.4GHz (Codename Skylake) (Quad Core) (Not Overclockable)
Motherboard: ASUS/GIGABYTE (Intel Z170 Chipset)
System Memory: 8GB DDR4 2666MHz Digital Storm Performance Series
Power Supply: 600W EVGA/Corsair
Storage Set 1: 1x Storage (1TB Western Digital - Black Edition) <br><strong></strong>
Storage Set 2: - No Thanks <br><strong></strong>
Graphics Card(s): 1x GeForce GTX 1060 6GB (VR Ready)
Extreme Cooling: High Performance Cooler with Large Fan and Copper Pipes
Airflow Control: - No Thanks
Recovery Tools: Factory Reset Feature (Restore Windows + Drivers) (Partition up to 50GB of Storage)
Branded Gear: - No Thanks
You could change the i7-6700 cpu for the i5-6500 and stay under budget but the i7 will perform better for your needs.  Either will work.
You didn't mention the monitor resolution, but the gtx 1060 is very good for 1080p at med to high gaming.  Most if not all graphics cards support multi monitor.
Hope this helps. Big%20Smile
Edited by bprat22 - 26 Dec 2016 at 8:46am
  Quote brycedanielsmith Quote  Post ReplyReply bullet Posted: 26 Dec 2016 at 10:41am
Thanks for the helpful advise!
I just want to check a little bit more on the monitors. I am planning to have a:
(x1) LG 25UM58-P 25-Inch 21:9 UltraWide IPS Monitor with Screen Split in the middle
and
(x2) ASUS VS248H-P 24" Full HD 1920x1080 2ms HDMI DVI VGA Back-lit LED Monitor on the outside
Will these work with that particular configuration?
Thanks!
Bryce Smith
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 26 Dec 2016 at 12:50pm
The video cards typically have a DVI, 2x HDMI and 2x DisplayPort ports to connect monitors to.   But they're not all the same. Worse case you get a dvi to hdmi adapter, etc to match your monitor to the card.
Just an FYI....the more monitors are being used at once, the lower the gaming frame rate because the video cards workload to render increases.
Edited by bprat22 - 26 Dec 2016 at 12:51pm
