New fans problem
Post Date: 2010-09-27
cruncher View Drop Down
  Quote cruncher Quote  Post ReplyReply bullet Topic: New fans problem
    Posted: 27 Sep 2010 at 5:46pm
I'm sort of a hardware noob, so there's that.
I've had my DS system for about a month now and decided to increase the ventilation a little bit.  I have a Coolermaster Elite 430 with the EVGA x58 LE board.  I bought a couple of thermaltake 2000 rpm fans to stick in, and now I'm a little confused.
Due to the way everything is jammed in the only place to fit an additional fan is on the side cover, so I did that and replaced the fan at the top of the case behind the cpu.  That one was plugged into the motherboard, the thermaltakes have the 4 pin connectors and I'm instructed to plug them into the power supply,   Fair enough.
I got both fans installed and didn't see where to plug them into the PS, it's the 'DS certified' TechNPS 750 watt.  I rummaged through the goodie leftover box and found a couple of the 4-pin-to-fits-in-the-PS wires.  Each one has two plugs on it.  I plugged both fans into the one adapter and lit it up.  Only one fan worked.  I then grabbed the other adapter so each fan had it's own plug into the PS.  Only one fan works, whichever one is plugged into the top plug on the PS.
I don't see that I have anything in the goodies box to convert the four pin plug on the fan to plug back into the motherboard like it was originally.
What am I doing wrong here?
TIA
  Quote cruncher Quote  Post ReplyReply bullet Posted: 27 Sep 2010 at 6:05pm
I mentioned I'm a hardware noob, didn't I?
Thanks for help I was going to get, but I had a crazy idea literally 30 seconds after posting and it worked.
KJ View Drop Down
  Quote KJ Quote  Post ReplyReply bullet Posted: 27 Sep 2010 at 8:30pm
Ok Ok   soooo what was your  fix  Confused
  Quote cruncher Quote  Post ReplyReply bullet Posted: 28 Sep 2010 at 1:44am
Yeah, apparently when converting from the six pin plug on PS the two 4 pin connectors don't have the same things to offer.  Sticking the fan that didn't work into the other plug made her spin.
Pretty elementary to you fellas I'm sure.
rholyrag View Drop Down
  Quote rholyrag Quote  Post ReplyReply bullet Posted: 28 Sep 2010 at 5:27am
Good to hear you got it figured out..Awesome.
