New Monitor (Need help picking one)
Post Date: 2009-12-12
Clinton View Drop Down
  Quote Clinton Quote  Post ReplyReply bullet Topic: New Monitor (Need help picking one)
    Posted: 12 Dec 2009 at 11:32pm
So I don't want to go over about $270 for a new monitor. I've been told that NEC are a lot better, but I just can't afford one. Looking for a resolution of 1920x1200. I was looking at this monitor but was told it probably wasn't very good.
http://www.newegg.com/Product/Product.aspx?Item=N82E16824001280
Any help would be appreciated, thanks. *Looking for a good monitor now that I've decided to get an ATI 5850 instead of Nvidia 275GTX :(  *
titusmckieus View Drop Down
  Quote titusmckieus Quote  Post ReplyReply bullet Posted: 13 Dec 2009 at 12:52pm
That particular one has a TV tuner Built into it. Id say if you don't do much TV on your monitor . Id get something else. I own the non tuner version. and I would say that there are better ones out there for less. The viewing angle stinks on mine. you can find that sweetspot. but if you do any kind of gaming. and moving around a lot, it bites. I would rate mine as just being "OK". nothing more.
  Quote Clinton Quote  Post ReplyReply bullet Posted: 13 Dec 2009 at 4:43pm
I don't necessarily need the tv tuner or the speakers. I just want a high definition monitor with a resolution of 1920x1200. Viewing angle isn't really that big of a problem.
  Quote titusmckieus Quote  Post ReplyReply bullet Posted: 13 Dec 2009 at 5:56pm
This is the one I have, and I like it a lot. http://www.newegg.com/Product/Product.aspx?Item=N82E16824236047
Looks like I bought the last one though.
