new rig on the way, need help with monitor
Post Date: 2009-08-22
travi24 View Drop Down
  Quote travi24 Quote  Post ReplyReply bullet Topic: new rig on the way, need help with monitor
    Posted: 22 Aug 2009 at 2:06pm
hey guys,
my new DS rig will be here next week and im looking for a monitor. i have 19 inch now. my new rig has 2 275 cards in sli. im thinking of 24 inch but have a question. If i get 24 inch and game that i play does not use sli. am i still going to be able to max the settings for that game with 24 inch and just one 275 card. in other words do you guys know of problems like that i will run into with this setup with 24 inch monitor. or should i just go with 22, which im hearng is not what i need for sli. thanks for you help
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 22 Aug 2009 at 5:24pm
Depends on the games, on some games you may have to turn down the setttings if they don't support sli, but for majoratiy of games you should be fine.
go with a 24 inch, look for a monitor that has the same Viewing Angle, both vertical and horizontal, and above 170°
Showboat View Drop Down
  Quote Showboat Quote  Post ReplyReply bullet Posted: 22 Aug 2009 at 5:40pm
My Extreme 1 just hit stage 6 in a update email a few minutes ago and im in the same boat for a monitor. I need to go economy and looked at the recommended monitors in the other thread discussion. Im still on the fence about a couple of them, but im leaning towards this to get a 24" for now, and then upgrade maybe next year to a 30" when funding looks better.I found this on newegg and read reviews from several sites on it. Its not bad for middle of the road economy.
  Quote <8) slunK parade Quote  Post ReplyReply bullet Posted: 22 Aug 2009 at 6:58pm
that looks like a good monitor, never used NEC before.
if something doesnt run in SLI, and you have to use just 1 card, just remember, you will be running that program with the fastest single card out right now, so no matter what you will have performance greater than or equal to everyone else
  Quote Showboat Quote  Post ReplyReply bullet Posted: 22 Aug 2009 at 7:16pm
I have been researching for a couple days now and that NEC ASLCD24WMCX is hot in the running even if its not the best. I have a NEC MultiSync FE2111 CRT monitor that has served me well over the past 5 years.Not to hijack travi24 monitor thread but I just went stage 7! These guys are workin hard on a Saturday and im impressed! That also means im pushin harder for a monitor now to fit my set up, that will probably ship Monday if all goes well. Thanks for all input! Back to research!
  Quote <8) slunK parade Quote  Post ReplyReply bullet Posted: 22 Aug 2009 at 7:25pm
if you play games you might want a monitor with a higher vertical refresh rate
like 85-100khz
youll get less chance of tearing at high fps
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 22 Aug 2009 at 8:09pm
I think most dell monitors are nec.
I like nec myself.
Edited by DST4ME - 22 Aug 2009 at 8:10pm
sdelu View Drop Down
  Quote sdelu Quote  Post ReplyReply bullet Posted: 22 Aug 2009 at 8:51pm
I always recommend Samsung for anything tv/monitor related. Usually priced fairly and generally very high quality.
DELL has good monitors as well.
Edited by sdelu - 22 Aug 2009 at 8:54pm
  Quote Showboat Quote  Post ReplyReply bullet Posted: 23 Aug 2009 at 2:15pm
Well..I have narrowed it down and think this is a good deal.Its $175 more than the NEC and a H-IPS panel versus the TN type.Better vertical refresh rate too.... And its on the recomended list.Anybody have one?  http://www.newegg.com/Product/Product.aspx?Item=N82E16824176104
frnk55 View Drop Down
  Quote frnk55 Quote  Post ReplyReply bullet Posted: 23 Aug 2009 at 4:31pm
I'm in the same boat as you.  So after doing some research I decided on that HP!
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 23 Aug 2009 at 4:53pm
I would go with the nec IMO, it has better reviews.
satsunada View Drop Down
  Quote satsunada Quote  Post ReplyReply bullet Posted: 23 Aug 2009 at 5:02pm
The HP is kinda random on quality depending on where it's built. I recommend looking here for info on monitors:
  Quote frnk55 Quote  Post ReplyReply bullet Posted: 24 Aug 2009 at 5:58am
DOH!Cry
I guess I'm taking a chance with the HP.  I bought it at New Egg and the reviews were good.  Oh well, If I have problems I hope New Egg return policy is decent.
EVE Hell View Drop Down
  Quote EVE Hell Quote  Post ReplyReply bullet Posted: 26 Aug 2009 at 5:50pm
Why don't you thinking 'bout a larger one?DELL 2709,its a good one.I'm useing this for about 4 month,Or HP lp3065?
Intel I7 920 OCED 4.0 GHZ
12G G.Skill DDR3 12800CL8T
Dual Gigabyte GTX295 Q-SLI
1200W Thermaltake PS
1T WD HD x2
Gigabyte EX58-Extreme
Raven RV-01B
DELL 2709+Panasonic 42PZ800C
From China
Caleb View Drop Down
  Quote Caleb Quote  Post ReplyReply bullet Posted: 26 Aug 2009 at 11:34pm
This one is your "Best Bang for the Buck". So I'm told.
