New to DS, need build help
Post Date: 2011-11-03
miller41 View Drop Down
  Quote miller41 Quote  Post ReplyReply bullet Topic: New to DS, need build help
    Posted: 03 Nov 2011 at 1:30pm
Budget 2500.00
Using this system for all new games coming out, Diable 3, Skyrim ect and I have 2 monitors, a 27" and a 22" with 1980 x 1020 resolution. Would like a sytem that boots quickly and runs games fast. Any help would be great as things have changed to fast for me to keep up.
Looks like I will get order ODE Level 3, it is pre configured and seems to meet my needs. Will it work well with a 30" Dell monitor?
Edited by miller41 - 03 Nov 2011 at 3:33pm
There is no problem so big or complicated that it cannot be run away from.
sneaky George W View Drop Down
  Quote sneaky George W Quote  Post ReplyReply bullet Posted: 03 Nov 2011 at 3:34pm
hey Miller,
welcome to DS!
im assuming that both monitors are at that 1980 x1020 resolution?
if so, this build would give you fantastic performance, its a little over your budget ($2709). if you dont have the wiggle room drop down to one GTX 570 instead of two and add a 1Tb western digital hard drive. its really similar to my system which i love. you may want to add the internal lighting ($10, id go with red since that case comes with a red front fan). also youre going to want to ask them to add a fourth 200mm fan to the case (it has room for four but comes with three). dont forget a free t-shirt!
612354
Video Card: 2x SLI Dual (NVIDIA GeForce GTX 570 1.2GB (Includes PhysX Tech) (EVGA Edition)
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 03 Nov 2011 at 5:49pm
when you say all new games, for example for games like bf3 at those res ( 2 x 1980 x 1020) or 2560 x 1600 (30") and good aa you gonna want the 570 2.5GB sli.
so I would go with SGW's build but with sli 570 2.5GB
now having said all that your budget is not making that possible with everything else.
ode 3 will not do great with some games or if you want good aa settings at 2560 x 1600 res.
