Newbie with general questions
Post Date: 2008-07-02
Doc View Drop Down
  Quote Doc Quote  Post ReplyReply bullet Topic: Newbie with general questions
    Posted: 02 Jul 2008 at 1:27pm
 Hello. I'm planning a new rig. Been shopping, comparing, gathering as much info as I can before ordering. I really like what I've found here so far. Been lurking here for a while. I'm looking towards a purchase in the next couple of months, primarily because Battlefield 3 is due out before the end of the year.(Although I'm not holding my breath) I doubt my current comp will run it. My goal is to be bleeding edge ENOUGH so as to do as well as I have with my current rig. I have a Dell 8300 series. Its nearly 6 years old. All I've had to upgrade in that time is some additional RAM and GPU (now a 7800GS). It still runs 2142, FFOW, COD4, BF2 on med to high settings. So on to my many questions.
 Processors. 9450 to 9650. The only difference is clock speed? So overclocking a 9450 is same as non-OC 9650?
 My understanding is that the FSB is the issue with overclocking and choosing memory, etc. If the MB only supports 1333, getting memory with 1600 is useless as the MB becomes a bottleneck. Just asking so as to match the MB, memory and processor's speeds. If any of the three is slower, bottlenecks occur?
 Two hard drives set up with their own OS = two computers. One for family, one for gaming toy for me that they can't corrupt with inadvertant or intentional well-meaning downloads?LOL
 Bigfoot Killer network adapter card. Noone seems to select this. I've heard great HYPE about them. Is it everyone's opinion that it is hype? Are they worth it?
 Windows OS tweak. What's involved? What "unnecessary" things won't work afterwards?Wink
 Why does everybody here buy computers without monitors, speakers, keyboards and mouses? Makes the price look better?
 What do I need to share my cable internet with my current comp?
Thanks to everyone in advance.
Edited by Doc - 02 Jul 2008 at 1:30pm
skyR View Drop Down
Digital Storm Apprentice
  Quote skyR Quote  Post ReplyReply bullet Posted: 02 Jul 2008 at 1:54pm
The QX9650 has an unlocked multiplier so enthusiasts can take the chip to its limits. But other than that and the price, both are the same.
Nope, not exactly correct. The motherboard is guaranteed to support that component's speed, it doesn't mean that it's limited to that speed but it might be depending on the quality of the motherboard. You just have to worry about the CPU and RAM bus. And remember that CPU and RAM "effective" bus are calculated differently... the CPU effective bus is quad-pumped (4 x 333 = 1333) while the RAM effective bus is duo-pumped (2 x 666 = 1333). The actual bus speeds of the CPU (333) and RAM (666) should match, not the effective bus speeds.
I guess you can put it that way.
Too expensive. Money can be better spent in other things.
Most people already have the monitor, keyboard, and mouse from their old computer. Some prefer other brands such as Logitech which Digital Storm doesn't offer. And you'll find a better deal if you spend some time searching ($20 for logitech G5 =p).
You need a router.
Edited by skyR - 02 Jul 2008 at 1:55pm
Doc View Drop Down
  Quote Doc Quote  Post ReplyReply bullet Posted: 02 Jul 2008 at 3:39pm
So is the bigfoot just too expensive (which it is) or too expensive for what it does? How much difference does it make gaming?
Also are the OS tweaks they offer worth the money. What's it do exactly?
skyR View Drop Down
  Quote skyR Quote  Post ReplyReply bullet Posted: 02 Jul 2008 at 3:54pm
The bigfoot is way too expensive for what it does. You'll get double digit ping in America no matter what and if you want single digit ping in gaming, move to Korea.
If you aren't computer savvy, the os tweaks are probably worth the money. I don't have an exact list of what it includes, you can call them and ask.
Kliebor2 View Drop Down
  Quote Kliebor2 Quote  Post ReplyReply bullet Posted: 02 Jul 2008 at 3:58pm
Bigfoot is too expensive period. Every review I have read puts it in the "if I had unlimited money and space would it be cool, sure" category.
In essence it offloads a trivial amount of system processing to the network card. It is for people spending loads of cash on the ultimate bleeding edge machine looking to get that one last gasp of power out of their system.
There are far better dollar to performance ratio items you can spend on before going with a bigfoot nic
Dual PNY OC2 GTX 560Ti
8 Gigabytes DDR2/800
Doc View Drop Down
  Quote Doc Quote  Post ReplyReply bullet Posted: 02 Jul 2008 at 4:08pm
Thank you for the input guys. Moving to Korea would make my commute intolerable.Big%20smile
  Quote Kliebor2 Quote  Post ReplyReply bullet Posted: 02 Jul 2008 at 4:43pm
Oh come on... all you need is a personal leer jet, some flying lessons and a second wife/girlfriend to keep a house on both sides of the ocean... what is the problem there?
Star
Doc View Drop Down
  Quote Doc Quote  Post ReplyReply bullet Posted: 02 Jul 2008 at 6:33pm
The second wife would be an issue, I'm sure.OuchLOL
SunfighterLC View Drop Down
  Quote SunfighterLC Quote  Post ReplyReply bullet Posted: 02 Jul 2008 at 6:49pm
DS charges 25 bucks for their OS tweeking services. If youre getting Vista, id recommend the program by stardock called tweekvista, it basically can do the same service but in one mouse click, it also does other bonus things. And its 19.95, not a huge savings over DS tweeking, but a savings non the less. Link below.
E8500@ 4.03Ghz
XFX 790i Ultra
1000W Corsair HX
2 280 GTX EVGA FTW
4GB OCZ Reaper 1800Mhz
250-80-300GB VR HD
Logitech Z-2300 2.1 Speakers
Asus Xonar 7.1
Doc View Drop Down
  Quote Doc Quote  Post ReplyReply bullet Posted: 02 Jul 2008 at 7:00pm
That's interesting Sunfighter. Thanks.
Edited by Doc - 02 Jul 2008 at 7:01pm
  Quote !ender_ Quote  Post ReplyReply bullet Posted: 03 Jul 2008 at 1:09am
Originally posted by skyR
What do I need to share my cable internet with my current comp?  You need a router.
not 100% true, with only 2 computers you can connect one to the internet and tunnel to the 2nd, good way to avoid paying for a router or for 2 internet connections.
Nickdapimp View Drop Down
  Quote Nickdapimp Quote  Post ReplyReply bullet Posted: 03 Jul 2008 at 2:50am
I got the bigfoot network card, and it just.. .well doesn't even help I guess... I might sell it... It maybe helps with only like 1 ping lol
  Quote Kliebor2 Quote  Post ReplyReply bullet Posted: 03 Jul 2008 at 5:57am
Vista allows easy internet connection sharing when you first start it up it asks if you want to set up internet connection sharing, all you need is 2 network ports and a second network cable. This has the drawback of requiring the master computer that is connected to the cable or dsl modem to be on in order for the slaved PC to have internet.
The 780i and 790i motherboards both have the two needed network ports.
Windows will take care of the rest.
Dave
Edited by Kliebor2 - 03 Jul 2008 at 5:58am
  Quote Kliebor2 Quote  Post ReplyReply bullet Posted: 03 Jul 2008 at 9:46am
Thumbs%20Up We are a go Houston.... Star
