No power cord included with new system
Post Date: 2009-07-14
eastor View Drop Down
  Quote eastor Quote  Post ReplyReply bullet Topic: No power cord included with new system
    Posted: 14 Jul 2009 at 2:45pm
Will a generic pc power cord work with the Corsair 1000 Watt power supply?   For some reason the power cord was not included, waiting on a response from DS.   Thanks for anyone's help in advance.  I have a old PC cord that fits the system but I do not want to turn it on in case it would cause issues.
Zurginator View Drop Down
  Quote Zurginator Quote  Post ReplyReply bullet Posted: 14 Jul 2009 at 2:59pm
Generic = Generic.
There is the special cable for the 1300+ watt psus, but you can use a generic there too most of the time.
  Quote eastor Quote  Post ReplyReply bullet Posted: 14 Jul 2009 at 4:01pm
Thanks for the heads up...I can't get anyone else to confirm yet, so I want to make sure before I blow up my brand new $5000 plus rig.  lol   Are you an expert on power cords?
Kliebor2 View Drop Down
  Quote Kliebor2 Quote  Post ReplyReply bullet Posted: 16 Jul 2009 at 1:25pm
Standard replacement computer power cables come in two sizes most commonly
18 AWG or 16 AWG... 18 is the narrower and is good for any standard PSU that does not require a 20 Amp outlet. The PSU you are talking about at 1000W is not a 20Amp wall current model, it is likely 10-12 amps at full draw, so 18 should be fine (This is what comes with virtually every boxed PC and PSU out there.) In fact your PSU is the same as mine and the cable that came with my PSU is 18 AWG.
16 AWG is thicker by a goodly margin and could handle higher amperage draws, like say from a 1500 Watt PSU operating at 80% + usage.
As far as compatibility there is no issue, if you want to know if the current is to much for your cord, plug it in, power up your PC, let it run for 15 minutes or so and feel the power cord itself, if the cord feels warmer than air temp that is a good indication the current draw is too much for the cable.
Dave Ouch
Edited by Kliebor2 - 16 Jul 2009 at 1:26pm
Dual PNY OC2 GTX 560Ti
8 Gigabytes DDR2/800
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 16 Jul 2009 at 1:59pm
PC power and cooling uses 14 gauge, been so long since I have used a different brand, forgot how small of a cord others use. lol
