No signal
Post Date: 2020-06-01
Albertalo View Drop Down
  Quote Albertalo Quote  Post ReplyReply bullet Topic: No signal
    Posted: 01 Jun 2020 at 8:24pm
Hello, I bought a PC in October of 2019z. I recently moved cities and after properly trying to set up my PC(lynx lvl 2) I noticed that the monitor had a no signal message. It plugs in via HDMI and I have it plugged in the proper place(graphics card) and still no signal. I just want a solution to this please. Thank you
  Quote Cretae Quote  Post ReplyReply bullet Posted: 02 Jun 2020 at 7:53am
Since you moved, I would definitely suspect your video card came loose. To check that, you need to unplug from the wall, and touch some metal on your case to ground yourself. Get the side panel off and gently push/wiggle the GPU firmly into it's slot. Be sure the power plug(s) going into the GPU from the motherboard are fully seated. If that fails, call Digital Storm.
Best of luck.
