no sound via fiber optic
Post Date: 2013-02-17
D1 View Drop Down
  Quote D1 Quote  Post ReplyReply bullet Topic: no sound via fiber optic
    Posted: 17 Feb 2013 at 5:08pm
can somebody please tell me what I need to do to enable sound through fiberoptic outlet in motherboard? I have the cable connected but not sure if this is a windows 7 config issue or asus motherboard config matter. ASUS P9X79 DELUXE (Intel X79 Chipset)  when I look at end of cable there is no light coming through indicating socket is not active (my take). I could find nothing in windows control panel for this type issue.
let me know if you need further information to diagnose or make reccomendation.
thanks
D1
D1 View Drop Down
  Quote D1 Quote  Post ReplyReply bullet Posted: 17 Feb 2013 at 6:08pm
Downloaded a driver and got it working. Now if I can get the blu ray player to          play the blu ray I'm all set. Plays dvds fine. LG model. I'm using a trial version of corel windvd pro 11. Anyone experience problems with it playing discs? I'm trying a fresh new skyfall disc and it won't advance.
Can anyone also recommend any other blu ray player software? Id like one that plays and burns all in one if possible, but they all seem separate.
Thanks
D1
HockeyBuck View Drop Down
  Quote HockeyBuck Quote  Post ReplyReply bullet Posted: 17 Feb 2013 at 8:44pm
I use CyberLink Power DVD12... I just have a DVD burner/ blueray player....don't have a blueray burner... Plays blueray fine....have not yet needed to burn any dvd's...
