Noob needs help on mid-level budget gaming rig
Post Date: 2011-11-18
Indiestuie View Drop Down
  Quote Indiestuie Quote  Post ReplyReply bullet Topic: Noob needs help on mid-level budget gaming rig
    Posted: 18 Nov 2011 at 6:34pm
I am looking to buy a rig for gaming.
I would also like to be able to use 3ds max well.
My budget is 1500 but I will go 1750-2000 if you can help me understand why I should spend that much.
I want an i7, I was thinking 16gb ram but the amount of ram doesn't matter as much as quality right? I don't mind upgrading later so that I can stay within budget now.
I also would like a decent graphics card. I think gt580 and gt590 are too expensive for my budget so I was thinking I should get a single gt570 and get another one in the future for SLI. My point being that I would need the rig to be SLI capable.
I don't know anything about cases, fans or cooling but I am willing to listen.
I really wanted to ode because I thought it was a good deal but I realized it cant do SLI and you cant customize it. So I tried to pic a diff model and customize that to match the ode but to have sli . I know that's prob not going to get me good pricing comparisons so I came to the forums for advice.
So basically Im looking for an i7 2600k, sli enables,  with 6gb ram 1600MHz and a gt570, and maybe a blueray player/burner option if you think that's viable.
Thanks for the help!
  Quote Indiestuie Quote  Post ReplyReply bullet Posted: 18 Nov 2011 at 7:14pm
Oh, I tried customizing the renegade level 3 and changed the motherboard to have sli.
ticket number 619424
So Is that the best option?
what should I change on that to make it cheaper or should I pick a different starting point?
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 19 Nov 2011 at 2:28am
Here you go Ticket# 619600 --- $2,076 (To see this build click here)
Motherboard: ASUS P8Z68-V PRO (Intel Z68 Chipset) (Features Intel Quick Sync Technology)
Hard Drive Set 1: Operating System: 1x (500GB Western Digital Caviar (7200 RPM) (16MB Cache) (Model: Blue Edition)
Video Card: 1x NVIDIA GeForce GTX 570 1.2GB (Includes PhysX Technology) (EVGA Edition)
assuming that you game at 1900 x 1200, if your res is lower then you don't even need sli.
here you have much much better case, psu, cpu cooler.
the case has amazing airflow the best around.
the psu will allow you do to sli 580, you can drop the psu to 800w but then in the future if you want to upgrade the sli to future cards and they have needs of a 580 sli the 800w can't do it, plus the 750w hx is more powerful then the 800w, it can't do sli 580 but it can do sli 570 better then the 800w.
the cpu cooler is much better then vortex and is not as loud.
now that is a quality build, if you don't want sli 580 ability for future upgrades go with the 750w hx psu but don't change anything else in my build otherwise performance/reliability will suffer.
  Quote Indiestuie Quote  Post ReplyReply bullet Posted: 28 Nov 2011 at 12:45pm
I really appreciate your help.
I dont understand how you got to that create your own dream pc page.
I can find links to it but they always have parts picked already,, how do I reset the page to 0$?
on that page is there a way to start from scratch and still have all the options?
I notice when i customize a prebuilt pc I only get so many options for each part and if i customize another prebuilt one then i get diff option.
I just want to be able to see everything! you know what i mean?
Would this pc be very loud?
If I was to do liquid cooling does that make it really really hard for me to upgrade on my own? is it hard to take the liquid cooling on and off?
Thanks for your help!
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 29 Nov 2011 at 12:10am
I just config the lowest model that is already built to be honest with you.
there is no way to set the page to zero.
there are 2 sections of forum, blackops and special opps, each has options the other does not.
95% of your noise comes from gpu's fan when under load, only way to make that quiet is to put it under lc.
this has lot less noise than your config, but if you want to make it more quiet, you need to go with noctua or stage 4 lc, that stage will add lots to the cost.
If you get lc on gpus, if something goes wrong with gpus or its time to upgrade, you need to take out the gpu from the lc loop, take off the water block from the current gpu and put it in the new gpu, then add the new gpu back to the block.
its something that takes a few times to get uses to but after that its not difficult.
If you tell me your res I can make the work easy for you and tell you whats your money's worth.
