normal monitor behaviorPost Date: 2009-12-24 |
| Author | |
AndydViking
Joined: 10 Sep 2009 Online Status: Offline Posts: 733 |
Topic: normal monitor behaviorPosted: 24 Dec 2009 at 3:44am |
Just got a new GPU and wanna make sure it isn't getting squirrly on me already.
This happens sometimes comming out of sleep and on boot. You will see 5 or 6 seconds in a weird green line. I don't remember this happening before. Is this normal or bad indication for monitor or GPU?
Edited by AndydViking - 24 Dec 2009 at 3:47am |
Captain Francis
Joined: 13 Dec 2009 Online Status: Offline Posts: 117 |
Posted: 24 Dec 2009 at 4:31am |
Um... you mean that weird windows background? The swirly lines and the green one has a little leaf or something on it?
If not, I can't see it. |
AndydViking
Posted: 24 Dec 2009 at 4:47am |
AndydViking
Posted: 24 Dec 2009 at 4:51am |
Sorry the above post pic is what I was referring to.
AndydViking
Posted: 28 Dec 2009 at 4:00pm |
Update:
I switched out my GPU and that wasn't the problem because it still does the same thing. I also ran PRime 95 for 18hrs with no problem with the highest CPU temp reaching 61 degrees.
I am thinking this is motherboard related at this point. Any ideas?
Also, their has been two instances where the motherboard has not read or detected my mouse. Edited by AndydViking - 28 Dec 2009 at 4:12pm |
Captain Francis
Posted: 28 Dec 2009 at 4:04pm |
I didn't even see that. That's weird.
Posted: 28 Dec 2009 at 4:31pm |
I think you should talk to DS.
AndydViking
Posted: 28 Dec 2009 at 7:26pm |
venom
Joined: 08 Oct 2008 Online Status: Offline Posts: 0 |
Posted: 28 Dec 2009 at 8:42pm |
If this is a CRT monitor, I have seen that on a few that I own. If it isn't then it is probably your monitor if it only occurs when switching resolutions or gaining/loosing signal.
Edited by venom - 28 Dec 2009 at 8:43pm |
AndydViking
Posted: 28 Dec 2009 at 9:03pm |
Thanks for the suggestion. It is on a LCD monitor however I have some CRT's laying around and I'll try them out and see if this still occurs. |
| Forum Jump | Forum Permissions ![]() You cannot post new topics in this forum You cannot reply to topics in this forum You cannot delete your posts in this forum You cannot edit your posts in this forum You cannot create polls in this forum You cannot vote in polls in this forum |
