Not the Best Bolt X (Constant Coolant Leaks)
Post Date: 2020-02-11
MabuSoda View Drop Down
  Quote MabuSoda Quote  Post ReplyReply bullet Topic: Not the Best Bolt X (Constant Coolant Leaks)
    Posted: 11 Feb 2020 at 7:13am
This is going to be a review, or complaint on the Bolt X, which I purchased in July 2019. Took a while to ship, but that's expected, since I currently live in Florida.
Upon receiving it, things were great, fast computer, everything was fine. Only problem was the cooling.
The system leaks a lot. At first, I contacted support, and they had me ship the computer back to get it checked out. Not exactly sure what they did, but when it came back, the system didn't leak for around 2 weeks. However, ever since, whenever I had a leak, I just chose to epoxy the joints, and buy EKCryofuel to refill the coolant. Each leak may begin to appear around 1-2 weeks. I know that shipping the system back and forth wouldn't really do anything, and so I've been epoxying and refilling a bunch. Check out the pics, it'd probably be best to stay away from liquid cooled here.
Chassis Model: Digital Storm BOLT X
Side Window: Edge to Edge Premium Tempered Glass
Motherboard: ASUS ROG Strix Z390-I Gaming (Wi-Fi) (Intel Z390 Chipset) (Mini-ITX) (Up to 1x PCI-E Device)
System Memory: 32GB DDR4 3000MHz Corsair Vengeance RGB Pro (RGB Light Bar)
Power Supply: 700W Digital Storm Performance Series (Modular) (80 Plus Platinum) (Supports up to GTX TITAN Xp)
Storage Set 1: 1x SSD M.2 (1TB Samsung 970 PRO) (NVM Express) (Extreme Performance)
Graphics Card(s): 1x GeForce RTX 2080 Ti 11GB (VR Ready)
Extreme Cooling: Digital Storm HydroLux PRO LITE (CPU + Graphics Card)
HydroLux Fluid Color: Clear Fluid + Clear Tubing (Requires HydroLux Liquid Cooling System)
Chassis Fans: High Static Pressure - Corsair Air Series SP Fans (LED White)
Internal Lighting: Remote Controlled Advanced RGB Internal + Front Panel LED Lighting
Airflow Control: Corsair Commander PRO Management Control Board & Software (1x Board)
Sub-Total: $5,212.00
Tax (0%): $0.00
S&H: FREE Ground $0.00
Grand Total: $5,212.00
Reservoir is one of the parts leaking.
Right tube on GPU is one of the parts leaking at the moment.
Stains at the bottom of system/
I know the LEDs are weird but I can't really fix it and I don't mind them.
Edited by MabuSoda - 11 Feb 2020 at 7:18am
Alci View Drop Down
  Quote Alci Quote  Post ReplyReply bullet Posted: 11 Feb 2020 at 8:11am
Probably should have asked for a refund the second time it started leaking. All you can do know is to send it back and ask them to fix it again. These guys are stand up people and will resolve this issue. Why sit on this issue so long?
  Quote Alex Quote  Post ReplyReply bullet Posted: 11 Feb 2020 at 3:36pm
Hi MabuSoda,
I'm sorry to hear about your issue. It seems like your system is being mishandled by the courier when it comes to you, as the tubing can dislodge in shipping, and after a couple of days, the pressure buildup can easily create a leak.
The best solution here is for us to service it, and replace the entire cooling setup and ship it back to you via freight delivery to prevent any remote chance of it getting mishandled this time around.
We can also change the cooling system to soft tubing which will help take the stress of shipping abuse as well.
I recommend you reach out to our team so we can work with you to resolve this once and for all.
