Nothing showing on monitor
Post Date: 2022-09-06
Bwise View Drop Down
  Quote Bwise Quote  Post ReplyReply bullet Topic: Nothing showing on monitor
    Posted: 06 Sep 2022 at 8:38pm
Need help with my PC nothing shows up on the monitor after I cut the PC on it just says no input. I have tried swapping all all cords out even tried reaseating the graphics card and memory sticks multiple times. Does anyone have any idea what else I could do to troubleshoot the problem I'm lost at a dead end. I also have a yellow light on can anybody tell me what this means I'll post a picture of my load configuration if that helps.
  Quote Snaike Quote  Post ReplyReply bullet Posted: 07 Sep 2022 at 1:05am
Remove the GTX1650 and plug the monitor directly into the motherboard to see if the GPU has gone bad.
Question..how old is the machine?
Edited by Snaike - 07 Sep 2022 at 1:06am
  Quote Cretae Quote  Post ReplyReply bullet Posted: 07 Sep 2022 at 5:06am
Is your monitor plugged into the motherboard instead of the video card? It's a pretty common error.
This page was generated in 5.517578E-02 seconds.
