Novice seeking help and answers!
Post Date: 2011-10-28
bode View Drop Down
  Quote bode Quote  Post ReplyReply bullet Topic: Novice seeking help and answers!
    Posted: 28 Oct 2011 at 6:05pm
I have never done this before. I kept looking at IBUYPOWER and Cyberpower, but saw negative reviews. I then thought about Alienware, but also saw negative things. I finally found Digital Storm and this really looks like the place to buy a computer if you're not going to build it yourself. Thanks in advance for your help!
$3000 - $3500
Best components for the money. Single display. Want to be able to upgrade.
Mainly gaming. 24 inch Dell Screen
Would like a fairly quiet computer. Not sure about overclocking.
Saved Ticket #:
610339
Chassis Model: Special Deal Hot Seller - Black OPS Assassin Edition
Processor: Intel Core i7 2700K 3.50 GHz (Unlocked CPU for Extreme Overclocking) (Quad Core) <b></b>
Motherboard: ASUS Maximus IV Extreme (Intel P67 Chipset) (New & Improved B3 Revision Without SATA 3G Issue) <b></b>
System Memory: 16GB DDR3 1600MHz Corsair Dominator DHX (High-Performance) <b></b>
Power Supply: 1200W Digital Storm Certified (Dual/Triple/Quad SLI Compatible) (Silent Edition Highly Recommended) <b></b>
Expansion Bay: Internal Digital Media Card Reader (Black) <b></b>
Hard Drive Set 1: Operating System: 1x (1TB Western Digital Caviar (7200 RPM) (Model: Black Edition) <b></b>
Hard Drive Set 2: Multimedia\Data: 1x (1TB Western Digital Caviar (7200 RPM) (Model: Black Edition) <b></b>
Optical Drive 2: Blu-Ray Writer/Reader (Burn and Play Blu-Ray Discs) <b></b>
Video Card: 1x NVIDIA GeForce GTX 560 1GB (Includes PhysX Technology) (EVGA Edition)
Add-on Card: USB 3.0 4-Port PCI Express Card <b></b>
Sound Card: Creative Labs X-Fi Titanium Fatal1ty Professional <b></b>
Extreme Cooling: H20: Stage 2: Digital Storm Vortex Liquid CPU Cooler (High-Performance Edition)
Internal Lighting: Internal Chassis Lighting System (Blue) <b></b>
Noise Reduction: Noise Suppression Package Stage 2 (Optimized Airflow & Fan Speeds with Noise Dampening Material) <b></b>
Boost Processor: FREE: Overclock the processor between 3.3GHz to 3.9GHz
Exclusive T-Shirt: FREE: Digital Storm T-Shirt - Black (Large) <b></b>
Some questions,
1) Is the 1200 watt ds power supply good or should I go with a name brand?
2) I don't know if I will really need the internal media card reader, but since it's cheap I thought I would go ahead and get it. Is there a downside to doing that? For instance will this just add heat to the computer?
3) Should I have 2 hard drives and do I need RAID.
4) Any downside to having usb pci express card.
5) I have Logitech 5.1 sound. Do I need creative titanium or is the integrated motherboard good enough?
6) Does overclocking the computer wear out the components?
7) I read someone say you need better version of Windows if you have more RAM?
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 28 Oct 2011 at 10:30pm
your config is all wrong and lot of waste of money in there that you will see no gain from.
Here you go Ticket# 610901 --- $2,851 (To see this build click here)
Edited by DST4ME - 30 Oct 2011 at 3:07am
bbaisw View Drop Down
  Quote bbaisw Quote  Post ReplyReply bullet Posted: 29 Oct 2011 at 5:41pm
Would I be better getting the gtx 570 2.5 gb?
sneaky George W View Drop Down
  Quote sneaky George W Quote  Post ReplyReply bullet Posted: 29 Oct 2011 at 5:45pm
bbaisw,
the extra VRAM is only used/needed at resolutions higher than 1900x1080, so if youre going to be gaming at a higher res then yes, other wise no. keep in mind that even with the higher vram you are probably going to want to swap out the gpus in two-three years anyway to stay currant.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 29 Oct 2011 at 11:47pm
What he said ^
  Quote sneaky George W Quote  Post ReplyReply bullet Posted: 30 Oct 2011 at 2:49am
a couple of things;
first DST, your link above is to an ODE 0...
and second, bbaisw you'll want to have Digital Storm add an additional 200mm fan to the top of your case (it comes with 3, has room for 4) which will cost ~$20. while your at it, how about some shiny internal lights ($10)? if you really wanted you could liquid cool the CPU to stage 4 and still be in your price range (keep in mind that it would be a luxury and is NOT needed by ANY means, it just looks cool and keeps your CPU REALLY cool). I personally have my CPU liquid cooled and think its great/awesome, but its not necessary at all.
also to answer some of your questions,
1) go with the power supply DST recommended, it has more than enough power for present and probably future gpus
2) the only downsides i can think of to the media card reader are that it would take up a 5" drive bay and a SATA port, both of which you'd have extras of. but if you dont needed why not save the money? most devices come with usb connectors anyway.
3) you'll want the above hard drives, and RAID isn't needed.
4) it takes up a PCI slot that you could use for something else... if you need the ports, go for it, otherwise id skip it, the mobo has lots.
5) the integrated sound will be fine unless youre really really picky about sound. im not and i use 5.1 on integrated and im very happy with it.
6) it can if not done properly. the two things to watch are the temps and the vcore. the temps vary, and the vcore is just a setting. if they are with in acceptable ranges then your hardware will be obsolete before it wears out anyway. you want your temps to be below 85' C and your vcore on your CPU to be under 1.4. Digital Storm is good at OC, dont worry to much about it, just ask them to keep your vcore low.
7) i think thats right about the ram, but its like if you want to have 16GB vs 24GB or something. regardless youre not going to need that much ram.
just some thoughts, youre going to love Digital Storm
Edited by sneaky George W - 30 Oct 2011 at 3:00am
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 30 Oct 2011 at 3:06am
Why the heck is that going to ode 0 for? that build was not ode nor does that ticket number belong to ode, its getting re routed to ode.
I just updated teh ticket number on that build,so it should go to the custom config now.
Edited by DST4ME - 30 Oct 2011 at 3:08am
  Quote bbaisw Quote  Post ReplyReply bullet Posted: 31 Oct 2011 at 6:07pm
Just to clarify, I ask for the standard factory chasis fans with an extra one on top. And I can ask that all of these be LED lights (red). But don't upgrade to LED performance fans because those are different and would add noise? Thanks for your patience!!!
  Quote sneaky George W Quote  Post ReplyReply bullet Posted: 31 Oct 2011 at 6:10pm
i think so... with my build i asked for the led fan upgrade and got the 200mm led fans so idk. just be clear with them about what you want and be sure you get the 200mm fans. the led's look awesome btw.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 31 Oct 2011 at 7:31pm
fan upgrade is different, you want to ask for "oem 200mm red led fan". for all your fans but the front, and the optional on top.
Edited by DST4ME - 31 Oct 2011 at 7:32pm
  Quote bbaisw Quote  Post ReplyReply bullet Posted: 01 Nov 2011 at 7:12pm
I'm confused as to why not the 200 mm led red on the front and the optional on top?
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 02 Nov 2011 at 12:10am
I guess I didn't word it correctly, you do want the led on the optional top but the front fan is already a 230mm red led fan, no sense in changing it to a smaller fan 200mm fan.
