Nvidia 470 and 480...LC required??
Post Date: 2010-06-02
Bullseye View Drop Down
  Quote Bullseye Quote  Post ReplyReply bullet Topic: Nvidia 470 and 480...LC required??
    Posted: 02 Jun 2010 at 2:55am
Hey Forum,
I've been hearing loads of stuff on the forums about these 2 cards running super hot. Would a SLI setup work with the Noctua NH-D14? A setup with either 2 470's or 2 480's. If not would the frostchill upgrade work? It's only for the CPU but what if there were also Zalman fans??
Thanks in advance
SemperFuzz View Drop Down
  Quote SemperFuzz Quote  Post ReplyReply bullet Posted: 02 Jun 2010 at 4:49am
The NH-D14 covers some of the Ram up but from what i have seen does not in anyway obstruct or preclude one from going SLI at all.  Page 2 shows it mounted on a mobo, as long as you dont have crazy tall ram your good to.
and pic here mounted with crossfire in a small case
and another mounted on an asus with plenty of clearance
  Quote Bullseye Quote  Post ReplyReply bullet Posted: 02 Jun 2010 at 6:34am
So I will be fine???
Dragoonseal View Drop Down
  Quote Dragoonseal Quote  Post ReplyReply bullet Posted: 02 Jun 2010 at 7:02am
You could have 4 of them in SLI and you still wouldn't need LC.
They cool themselves man, they're self contained little units with a fan that sucks in cool air from the case and vents the warm air out the back of the case. If you couldn't run them without some expensive aftermarket liquid cooling system how could they even sell the things?
The only time you will ever need LC for a GPU is if you are trying push it extremely hard with a high overclock. That's hardly cost effective though, big GPU LC setups are expensive and you're not likely to get a huge overclock like on CPUs, cheaper to just add another GPU into the mix.
Lilim
Intel Core i7 920 @4.2GHz
  Quote !ender_ Quote  Post ReplyReply bullet Posted: 02 Jun 2010 at 9:42am
i dont know that i would really call that "plenty" of room, those are actually quite similar in size to the 480, and not far off in temps, he did say that "hes running fine" but he didnt say anything about temps in the post
im not saying the responders are wrong, im just saying that there is a difference between good and good enough, and i would definitely call stock cooling and a cramped case good enough for 2x480s, but i would never reccomend it. the cooling on the cards is by no means useless, but extra air cooling on them could never hurt, or at least some room to dissapate a little heat
i do agree though with the comment about only needing lc to do some real overclocking
i will say on the other hand though that i too am responsible for furthering comments about the heat off the 480 series, but the more i look, the less bad they seem. i mean 97 load sound pretty scary to me, but the 5870 is showing around 93, not the huge difference that a lot are making it out to be
  Quote Bullseye Quote  Post ReplyReply bullet Posted: 02 Jun 2010 at 10:05am
so whats better?
  Quote !ender_ Quote  Post ReplyReply bullet Posted: 02 Jun 2010 at 10:28am
better? liquid, but only if you need it for overclocking or have the money sitting around
  Quote Bullseye Quote  Post ReplyReply bullet Posted: 02 Jun 2010 at 11:15am
I don't really need it cos i won't overclock it. Would it be better to get 2x 1.2 gb or 1x 1.5??
JTF2 View Drop Down
  Quote JTF2 Quote  Post ReplyReply bullet Posted: 02 Jun 2010 at 11:44am
What size monitor are you planning to use with the final setup?
Intel Core i7 920 @ 3.8Ghz
NOCTUA NH-U12P
Asus P6T-Deluxe Motherboard
6GB OCZ 1600
EVGA GTX480
2x 74GB WD RAPTOR (RAID 0)
  Quote !ender_ Quote  Post ReplyReply bullet Posted: 02 Jun 2010 at 11:54am
yea, that will basically come down to what res you wish to use, a 480 has some serious power, you have to go pretty high res with high aa / af before you will see a benefit from sli
Edited by !ender_ - 02 Jun 2010 at 12:40pm
kainhall View Drop Down
  Quote kainhall Quote  Post ReplyReply bullet Posted: 03 Jun 2010 at 12:24am
some nvidia cards run hot,  like the...
8800gt
9800gt
9800gx2
295
480
any thing under 95c is good, i dont like temps over 80c but, unless your artifacting or crashing etc your good.
and make sure the temp in your room is good, im my small room with a celeron and a g force 4mx i have to open a window other wise it overheats
steam friends is kainhall
  Quote Bullseye Quote  Post ReplyReply bullet Posted: 03 Jun 2010 at 1:23am
I will be using a 28 inch, here are the specs:
Model
Brand     Hanns·G
Model     HH-281HPB
Cabinet Color     Black
Display
Screen Size     28" (27.5" viewable area)
Widescreen     Yes
Recommended Resolution     1920 x 1200
Viewing Angle     170°(H) / 160°(V)
Pixel Pitch     0.309mm
Display Colors     16.7 Million
Brightness     400 cd/m2
Contrast Ratio     DC 15000:1(800:1)
Response Time     3ms
Horizontal Refresh Rate     24kHz - 80kHz
Vertical Refresh Rate     56Hz - 75Hz
Panel     Active Matrix, TFT LCD
Display Type     WUXGA
Connectivity
Input Video Compatibility     Analog RGB, Digital
Connectors     D-Sub, HDMI
D-Sub     1
DVI     No
HDMI     2
Power
Complies with     Energy Star
Power Supply     100 - 240 VAC, 50/60Hz
Power Consumption     On: 85W(Typ), Standby: <=1W
Convenience
Regulatory Approvals     FCC, UL/CUL, CB, 3C, BSMI, PSB, KCC, MPRII, GOST, CE, Nemko Bau-mark, RoHS, Vista Premium
Stand Adjustments     Tilt
Built-in TV Tuner     No
Built-in Speakers     2 x 2W
HDCP Support     Yes
Features     Kensington Slot
VESA Mounting: 200mm x 100mm
Packaging
Package Contents     LCD Monitor
User Manual
VGA Cable
HDMI-DVI Cable
Power Cable
Audio Cable
Support Disk
Dimensions
Dimensions     25.7" x 20.7" x 10.2"
Weight     16.3 lbs.
Temperature Range     5°C-35°C/41°F-95°F
Humidity Range     10%~85%
Manufacturer Warranty
Parts     3 years limited (1 year LCD/Backlight)
Labor     3 years limited
JTF2 View Drop Down
  Quote JTF2 Quote  Post ReplyReply bullet Posted: 03 Jun 2010 at 12:23pm
One GTX480 will rock any game at 1920 x 1200.
When you start playing at  2560 x 1600  and above is where SLI really starts to shine.
NOCTUA NH-U12P
6GB OCZ 1600
EVGA GTX480
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 03 Jun 2010 at 12:37pm
1,2,3,4 GTX 480's will not rock any game at 1920 x 1200, not even remotely close, if rock mean getting 40-50 FPS min with max settings... there are more games that it cannot do that than there games that even use Physx. Smile
  Quote Bullseye Quote  Post ReplyReply bullet Posted: 03 Jun 2010 at 1:00pm
So I'm better off not running in SLI?? I am gonna be using this for the next 5 years...
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 03 Jun 2010 at 1:15pm
??? SLI will produce better frame rates?  don't really know what you are asking
  Quote Bullseye Quote  Post ReplyReply bullet Posted: 03 Jun 2010 at 1:57pm
I'm saying I will probably keep this rig for a while. So is 1 card fine?? I will be playing games that come out in the next 5 years so I think it's best 2 get 2 cards so they last
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 03 Jun 2010 at 2:04pm
matters the resolution, matters the game, and matters the settings, but one 480 will be fine for a year to year and a half or so with 1920x1200 or smaller res, 2 480's should get you 2-3 years tops. no GPU solution will last more than 2-3 years, and still be able to play new games at high settings.. plus new direct X, and other features make GPU's obsolete faster than any other hardware.
JTF2 View Drop Down
  Quote JTF2 Quote  Post ReplyReply bullet Posted: 03 Jun 2010 at 2:09pm
I currently run Metro 2033 with everything maxed (DX11 and PhyX enabled) and it is smooth as silk.
Don't get me wrong. I am a power gamer after all so more = better, but if I were you I would get one card right now until:
1. You start running games at higher Res.
2. Games have caught up to the performance of a single GTX480.
NOCTUA NH-U12P
6GB OCZ 1600
EVGA GTX480
  Quote Bullseye Quote  Post ReplyReply bullet Posted: 03 Jun 2010 at 2:14pm
I'll take 2 then. Thanks for all the help!!
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 03 Jun 2010 at 2:21pm
I find it impossible to believe that 10FPS is good... even on a 12" monitor  a single GTX 480 will see 15-16 FPS...3 GTX 480's still have a very hard time running this game, and your single does beter?? I think you are not setting it on maximum settings. lol
JTF2 View Drop Down
  Quote JTF2 Quote  Post ReplyReply bullet Posted: 03 Jun 2010 at 2:28pm
Hmm.. will have to check again.
Does look amazing though.
 I did not think that much of the game. After about 6 hours in I got bored.
It did make me re-install Fallout 3 though  :)
Edited by JTF2 - 03 Jun 2010 at 2:30pm
NOCTUA NH-U12P
6GB OCZ 1600
EVGA GTX480
  Quote Bullseye Quote  Post ReplyReply bullet Posted: 03 Jun 2010 at 2:29pm
I am thinking of getting a 2x 1.2 or a 1x 1.5 so I decided to go with 2x 1.2
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 03 Jun 2010 at 2:30pm
32aa? check all the settings, but I imagine you are a long ways from max settings
... what size monitor?
JTF2 View Drop Down
  Quote JTF2 Quote  Post ReplyReply bullet Posted: 03 Jun 2010 at 2:33pm
HP LP2465 24-inch   1920 x 1200
NOCTUA NH-U12P
6GB OCZ 1600
EVGA GTX480
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 03 Jun 2010 at 2:41pm
at that res, 10 frames a second and jerky as hell, with all settings maxed, no question about it. but yeah, the game is not that geat at all. lol
Edited by justin.kerr - 03 Jun 2010 at 2:42pm
  Quote Bullseye Quote  Post ReplyReply bullet Posted: 03 Jun 2010 at 2:51pm
u mean metro???
JTF2 View Drop Down
  Quote JTF2 Quote  Post ReplyReply bullet Posted: 03 Jun 2010 at 2:52pm
While I have your attention Justin I was considering moving to Liquid cooling.
What are you currently using as a setup and what would you recommend if you were going to pick something up today?
I am using a Antec p160 case that will most likely get upgraded with the LQ purchase. I was thinking Obsidian Series 800D but the Lack of SATA 3 backplane has me put off.
NOCTUA NH-U12P
6GB OCZ 1600
EVGA GTX480
JTF2 View Drop Down
  Quote JTF2 Quote  Post ReplyReply bullet Posted: 03 Jun 2010 at 2:54pm
Sorry about Hijacking the thread Bull  Broken%20Heart
NOCTUA NH-U12P
6GB OCZ 1600
EVGA GTX480
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 03 Jun 2010 at 3:02pm
I would not recomend water cooling to anyone really... you either do it half assed and end up with a hot, loud mess, or do it right, and it costs a ton of cash...
  Quote Cretae Quote  Post ReplyReply bullet Posted: 05 Jun 2010 at 11:18am
Bullseye , you are going the wrong way!!! You should NOT do SLI until you absolutely need to. By that time, there will be new cards out, maybe a whole new tech that will give you a much better upgrade path than 2X obsolete cards.
Whatever you do, do not go SLI, and then gimp yourself with 470's. I doubt that setup would be worth it at all.
Yeh, and Metro sounded like a crap game to me, and now I know.
Coolermaster Storm Sniper
Intel Core i7 930 3.8GHz OC
EVGA X58 LE
6GB DDR3 1600Mhz Ram
750W Corsair
1TB HDD
1x ATI RadeonHD 5870 1GB
Noctua Dual 120mm
  Quote Bullseye Quote  Post ReplyReply bullet Posted: 05 Jun 2010 at 2:02pm
No problem man!
  Quote Bullseye Quote  Post ReplyReply bullet Posted: 05 Jun 2010 at 2:05pm
Ok I will get 1 and upgrade in the future.
I think I will keep getting new cards as they come out.
The Evga deal where you can trade your card in after 90 days of purchase is still valid??
  Quote Cretae Quote  Post ReplyReply bullet Posted: 05 Jun 2010 at 3:22pm
Yup, but look how long it took them to come with the 400's. SmileSmile
EVGA X58 LE
750W Corsair
1TB HDD
Noctua Dual 120mm
  Quote Bullseye Quote  Post ReplyReply bullet Posted: 05 Jun 2010 at 3:27pm
I could sell it...
