NZXT Switch 810 - Fan Control
Post Date: 2012-10-14
MICHAEL2A View Drop Down
  Quote MICHAEL2A Quote  Post ReplyReply bullet Topic: NZXT Switch 810 - Fan Control
    Posted: 14 Oct 2012 at 10:21am
Anyone experienced with this case? It has a fan hub on the backplate that can connect 7 fans. Unfortunately, there is no way to control the seven fans once they are hooked into it. My current plan is to use the 7 fan inputs on the X79 Sabertooth MOBO for 7 out of 11 fans (including the CPU cooler) and using an internal fan controller for the rest. Does anyone know a way to use the hub on the backplate and still be able to control the fans through it?
NZXT Switch 810
Asus Rampage V ED10
16GB Corsair Platinum 3000mhz
i-7 X5960, 3.0Ghz-3.5Ghz
Intel 750 800GB NVME-SSD
Corsair H115i CPU Cooler
2 Asus Strix 1080 8GB SLI
Corsair AXi 1200 PSU
