ODE Level 1 questionsPost Date: 2012-01-22 |
| Author | |
Fran49829
Joined: 22 Jan 2012 Online Status: Offline Posts: 2 |
Topic: ODE Level 1 questionsPosted: 22 Jan 2012 at 7:08am |
Hello,
My budget is around $1500-$1600. I expect to be able to run Flight Sim X with really good results. I expect to connect to 2 hdmi tvs seeing the same display. . One hdmi tv would be the display for the computer and I would also need to be able to view the computer on my Vizio 55" hdmi tv so I can view my photos.Does this computer have an HDMI and DVI output? How about vga? I need to know what video and audio outputs the computer has. I expect to be able to use my wireless keyboard and mouse. I plan to use this computer mainly for web surfing, FSX, and Tomb Raider ( there is a new tomb raider coming out at the end of the year). I do not want a loud computer and my house has a more than normal amount of dust. Thanks, Fran Edited by Fran49829 - 22 Jan 2012 at 7:10am |
Posted: 22 Jan 2012 at 11:02pm |
For your budget you should look at ode 1.
tv's don't make the best monitors and also unless you are dealing with hdmi 1.4, you are limited to 30fps which is not what you want. the ode 1 has a 570 gtx which has 2 dvi ports and probably one mini hdmi. as for sound check out the sound outputs:
Fran49829
Posted: 23 Jan 2012 at 6:18am |
Thanks,
Can I use my wireless keyboard and mouse with the ODE1? Fran |
Posted: 23 Jan 2012 at 6:49am |
Hi Fran49829...Yes, the ODE 1, and any pc here, will support wireless keyboard and mouse. All that is needed is a USB port for keyboard's wireless receiver to plug into and the ODE has 4 in front, 5 with USB 3, and six or so in the back.
The ODE will be a bit louder than a typical off the shelf pc with a single fan in the back., because of the front, top and back cooling fans plus the A70 cpu cooler and graphics card cooler. The price to pay for a gaming pc. I personally don't find it too loud, but each to their own. As far as dust...The ODE has a filtered front intake fan that is easy to clean. Have Fun Edited by bprat22 - 23 Jan 2012 at 7:02am |
Posted: 24 Jan 2012 at 1:19pm |
As long as you have the wireless receivers for it I don't see why not. Edited by DST4ME - 24 Jan 2012 at 1:19pm |
