Ode Level 3 Power Supply
Post Date: 2012-02-24
josephlee View Drop Down
  Quote josephlee Quote  Post ReplyReply bullet Topic: Ode Level 3 Power Supply
    Posted: 24 Feb 2012 at 5:35am
I am looking to spend around $2,500 on a new gaming PC. One monitor at ultra res. I have a 20 inch now, but looking at getting something bigger down the road. WOW, D3, and the like.
I have been reading quite a few posts and seems like Ode 3 is the front runner at this point. The alternatives that everyone suggests always has a better PS (along with other upgrades).
So my question is, if I go with Ode 3 and the 800W PS, am I limiting myself on the future upgrade side of things? Is it "easy" to upgrade the PS down the road or is that not really an option for the Ode case/setup?
Looking forward to finally pulling the trigger sometime soon!
  Quote FrankW Quote  Post ReplyReply bullet Posted: 24 Feb 2012 at 6:05am
Hi josephlee,
The power supply used in the ODE-3 is adequate for its intended purpose. It is not as good as the HF or HA series from Corsair which have longer warranties and are more efficient. The ODE-3 power supply works with the 570 series GPU but not a good choice for the 580 GPU. We don't know the power requirements for future GPUs and that will effect what upgrades you could make. The trend has been to reduce GPU power requirements since the 4xx series of GPUs.
The ODE-3 is a best buy computer and it has compromises in some equipment. These compromises doesn't reduce its ability to play todays games that the computer is intended for. Changing out a PS is not a hard job. You just need to be organized and take your time. If all else fails you can take the computer to a local computer store and they can change the PS for you. Or you can return it to DS. Lots of options so I would not be worried about the PS supplied with the ODE-3.
DS warrants the ODE-3 PS for 5 years so they have confidence in it.
  Quote josephlee Quote  Post ReplyReply bullet Posted: 24 Feb 2012 at 6:37am
Thanks Frank, appreciate the insight.
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 24 Feb 2012 at 6:38am
The other option would be to have DS change to the 1050HX for example if it is a problem.. DS will change parts but charge for it because it's a pre-built.   The problem here is the extra cost of $134 for psu and $50 for any change to ODE, almost the cost of a brand new 1050HX from Newegg.
Like FrankW said, leave the 800W, it should be fine.  IF you need more down the road which is doubtful, change it then.  Not a bad job to do.
I wouldn't hesitate to make this purchase based on the psu.  The ODE 3 is a great value.
Have Fun Big%20Smile
