ODE noise levels and local pickup question.
Post Date: 2011-07-13
ZRX1200Rider View Drop Down
  Quote ZRX1200Rider Quote  Post ReplyReply bullet Topic: ODE noise levels and local pickup question.
    Posted: 13 Jul 2011 at 1:52pm
How noisy are they? Fans, cooling, etc....I'm mostly interested in the ODE level 3. Also, if I pick up a system in person, is there any other costs besides California sales tax? Any input would be appreciated. Thanks in advance.
  Quote Alex Quote  Post ReplyReply bullet Posted: 13 Jul 2011 at 2:55pm
It's a fairly quiet system. Yes, you can pick it up locally, you'll need to place your order online, select "Local Pickup" as the shipping method. Once your system is ready, we'll give you a call and arrange a time that works for you.
Jawa View Drop Down
  Quote Jawa Quote  Post ReplyReply bullet Posted: 13 Jul 2011 at 3:25pm
I've got my ODE L3 fan speed maxed out.
Can you hear the fans?  Yes.
But are they noisy?  No.
Proud owner of an ODE-3 (version 1).
  Quote ZRX1200Rider Quote  Post ReplyReply bullet Posted: 13 Jul 2011 at 3:44pm
Thanks guys, very useful information.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 13 Jul 2011 at 6:34pm
90% of your noise will come from the gpu's fan when under load, those little fans get loud when they go high.
unless you get fan upgrade then those fans are loud also, or if you use loud fans anywhere on the system.
the stock fans are normally not loud at all these days, specially those big fans (200mm) they can push lot of air with low noise.
