Once more, a other question:
Post Date: 2011-12-31
CalebODEman View Drop Down
  Quote CalebODEman Quote  Post ReplyReply bullet Topic: Once more, a other question:
    Posted: 31 Dec 2011 at 7:57pm
Okay, so I have my ODE Level 1 now, and I got these monitors for free, but are they good?
Link to the monitors: http://accessories.us.dell.com/sna/PopupProductDetail.aspx?cs=19&l=en&c=us&sku=320-4113
I have a ODE Level 1 and two of those monitors, but are they fine?
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 31 Dec 2011 at 8:26pm
1. response time is a bs number, its there to fool you and does not represent the true response time of the monitor, there is no real way of truly finding what response time is, the closest to it is white to white but you don't see that, you see grey to grey or black to black cause they give small numbers to fool users but they don't mean anything, there are different methods to get these numbers also, and each will give a different number as results, therefore you can even compare one to the other, cause we don't know what method was used for which, and even if we did, still GTG or BTB don't mean anything.
2. contrast ratio is also bs number.
those are tn panels but they are free, the free part is very attractive, what I don't like about them is the res:
1280 x 1024
I recommend around 1900 x 1200 res, the higher the better everything looks but you also need more gpu power.
but if you are happy with them is what counts, I'm not playing on them you are, if you are happy then they are great till you upgrade in the future.
