Operating system question.
Post Date: 2009-02-16
NovaVenta View Drop Down
  Quote NovaVenta Quote  Post ReplyReply bullet Topic: Operating system question.
    Posted: 16 Feb 2009 at 6:09pm
I have been having lots of trouble trying to figure out which would be better Windows vista 64 bit or Windows XP. I was reading up on the threads about them did not seem to help. Two of my friend's have Vista and they say its not worth it and has lots of problems with compatibility issue's with exe's etc Wink. Also if I get a dual boot windows xp and vista 64 bit would that fix the compatibility issues? Would some one be kind enough to shed some light on this. I am also worried that there will be problems with vista Ying%20Yang Thanks Ouch
Edited by NovaVenta - 16 Feb 2009 at 6:17pm
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 16 Feb 2009 at 6:24pm
What problems? most things work with vista 64bit.
and its very well worth it cause you can't use more then 4Gb of ram total with 32bit, this includes your ram sticks and ram from your GPU.
  Quote NovaVenta Quote  Post ReplyReply bullet Posted: 16 Feb 2009 at 6:26pm
my build has 6 gb of ram and only vista 64 bit will use it to the fullest?
theyhm View Drop Down
  Quote theyhm Quote  Post ReplyReply bullet Posted: 16 Feb 2009 at 6:29pm
Yes, 32bit will only recognize 4GB. You might as well throw the other 2GB in the garbage if you buy 32bit.
  Quote NovaVenta Quote  Post ReplyReply bullet Posted: 16 Feb 2009 at 6:35pm
Right then I was just talking to my friend who has vista ultimate and says that there is more compatibility problems with newer games and also with other things. Is this true? This is really what I am worried about.
Edited by NovaVenta - 16 Feb 2009 at 6:36pm
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 16 Feb 2009 at 6:45pm
You sure your friend has vista? most people here have vista 64 and playing games just fine, the only issues we have seen have been with drivers and or the GPU itself, which both have to do with Nvidia and nothing to do with vista.
all of these run in vista
Far Cry 2
Dead Space
Fallout 3
Call of Duty 5: World at War
Crysis WARHEAD
Brothers in Arms Hell's Highway
Left 4 Dead
FEAR
I don't think your friends know their way around vista
Edited by DST4ME - 16 Feb 2009 at 6:46pm
  Quote NovaVenta Quote  Post ReplyReply bullet Posted: 16 Feb 2009 at 6:50pm
Alright thanks for the answers guys Ouch
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 16 Feb 2009 at 6:52pm
No problem, we are here also if you have any problems running anything so if you need help or have other questions, don't hesitate
good luck
  Quote NovaVenta Quote  Post ReplyReply bullet Posted: 16 Feb 2009 at 6:57pm
Yeah. Well hopefully I will be able to order my comp soon looking forward to it Smile
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 16 Feb 2009 at 7:08pm
lets hope so, be sure to let us help you config one when you are ready
pwcorgi View Drop Down
  Quote pwcorgi Quote  Post ReplyReply bullet Posted: 21 Feb 2009 at 11:22am
While we're on the subject of OS, is it possible for you to put Windows as the base OS and also add Linux?
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 21 Feb 2009 at 4:40pm
with vmwareor apps like it, you can do that.
with vmware you can have multiple OS running off of a base OS.
for example you have vista as your main OS then you install vmware on it and then the new OSes get installed in vmware, then from vmware you can run linux, windows 7, what ever you like.
for example here is linux as the base os and xp as the guest os running in vmware
Edited by DST4ME - 21 Feb 2009 at 4:43pm
This page was generated in 0.1152344 seconds.
