Opinion Help Plz
Post Date: 2009-10-09
Born2rade View Drop Down
  Quote Born2rade Quote  Post ReplyReply bullet Topic: Opinion Help Plz
    Posted: 09 Oct 2009 at 8:45pm
Hello Everyone. I will be purchasing and customizing my pc threw Digital Storm most deffinately in January. I have been browsing threw the DS forums and also various websites on what would be the best system for me. Basically i am looking for everyones opinion on the build that i will most likely be purchasing, perhaps better ideas?
The things i want to do with this computer are strickly gaming, Nothing else really. At the moment i have a 19 inch wide gateway monitor but plan on buying a 22 or 24 inch acer in the future, not sure which resolution yet.
The only changes that would probably be changed on this build by january rolls around will be the OS and the Video card, meaning Windows 7 Ultimate 64 bit and either the new ATI/Geforce card. So anyways here is the build so far. My budget is 3,600 MAX.
Total Price with Instant Savings: $3,585.00
Card Reader: - No Thanks
Video Card: 2x SLI Dual (NVIDIA GeForce GTX 275 896MB (Includes PhysX Technology)
Liquid Color:UV Blue: Medium Glowing Non-conductive Fluid (Requires H20: Stage 3 & UV Lighting)
Chassis Airflow: Upgrade Chassis With LED Performance Fans (Blue) (Up to 6 Fans)
Enhancements: LCD NZXT Sentry LX Temperature Display & Fan Controller (Requires Chassis Airflow Upgrade)
Boost Processor: Stage 2: Overclock the processor between 4.0GHz to 4.2GHz (Requires H20 Cooling Upgrade)
LCD Display: - No Thanks
Keyboard: Razer Tarantula Gaming Keyboard
Mouse: Razer DeathAdder Gaming Mouse (High-Speed Gaming Grade)
Warranty: 5 Year Platinum Care Extended Parts & Labor Warranty (Highly Recommended)
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 09 Oct 2009 at 10:27pm
ticket number please
  Quote Born2rade Quote  Post ReplyReply bullet Posted: 09 Oct 2009 at 10:55pm
Ops my bad :D
Ticket Number: 339098
ace View Drop Down
  Quote ace Quote  Post ReplyReply bullet Posted: 10 Oct 2009 at 6:42pm
Looks good to me! I have the tarantula right now, no complaints. I personally would upgrade to the corsair 1000w but digital storm certified should be fine. Also consider putting in a 80gb intel x25m g2 for your boot disk after you get it, should set you back around $250. Keep the 500gb HDD for the majority of your apps.
venom View Drop Down
  Quote venom Quote  Post ReplyReply bullet Posted: 10 Oct 2009 at 9:06pm
Definitely get a Corsair 1000w, but other than that the build looks good.
  Quote Born2rade Quote  Post ReplyReply bullet Posted: 10 Oct 2009 at 9:25pm
alright cool thx. corsair 1000W, ok.
I'm still waiting on DST4ME's reply
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 12 Oct 2009 at 4:32am
for gaming you don't need a 4.0GHz oc, you will not see any gain from it.
you don't need the led fans, they are loud.
and as venom said 1000w corsair
Here you go Ticket# 339673 --- Price: $3261 (To see this build click here) Price after current promotion $3011
  Quote Born2rade Quote  Post ReplyReply bullet Posted: 12 Oct 2009 at 1:56pm
Ahhh alright, thx. I deff like your build better. Ty for responding.
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 12 Oct 2009 at 2:18pm
that is not very true. There are way too many variables to say a blaket statement like that.
Depending on the game, the resolution, the GPU(s) Games can scale well past 5Ghz. if I had chips that I could test out higher than 5Ghz I would, but that is as fast as I have right now..  On the other hand, depending on the above variables, a game may not scale above 2.5 ghz..
Edited by justin.kerr - 12 Oct 2009 at 2:32pm
  Quote Born2rade Quote  Post ReplyReply bullet Posted: 12 Oct 2009 at 3:10pm
I have one more question about the Hard drive. Right now i chose the 500GB western digital, would it be necessary to have the velociraptor at all? Is there a big difference in performance between those two for it to be necessary?
I originally was going to pick the velociraptor but because of the huge price difference i went with the western digital.
Sodius View Drop Down
  Quote Sodius Quote  Post ReplyReply bullet Posted: 12 Oct 2009 at 5:25pm
If it were me I would go with a WD 1TB and drop the raptor and 500gig.
Edited by Sodius - 12 Oct 2009 at 5:26pm
  Quote Born2rade Quote  Post ReplyReply bullet Posted: 12 Oct 2009 at 5:30pm
Yeh i wasnt going to go with both, it was either one or the other :).
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 13 Oct 2009 at 12:06am
raptor is faster then the 1TB, best thing to do is put the os/apps/games on raptor and then store files on the 500GB, you don't want a 1TB HDD for your os HDD, its too big and can become a huge pain to manage.
justin how much of a difference do you see in games from a 3.7GHz to a 4.0GHz? cause I don't see any difference even in games like crysis that would be more then a a few fps maybe like 4 fps.
below is not even 1900 x 1200 res which oc will make less of a difference in, now even at 1600 x 1200 it makes little difference,. look at the difference between 920 @ 2.66GHz and 975 @ 3.33GHz, now at 1900 x 1200 and between 3.7GHz and 4.0GHz the difference is even much less:
Edited by DST4ME - 13 Oct 2009 at 12:20am
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 13 Oct 2009 at 12:20am
That is only a 10% difference in overclock so max you would see is a 10% gain in FPS in a game that was CPU bound. The min OC DS offers is 3.3 Ghz which would be around 20% possible gain to 4.0Ghz
  Quote Born2rade Quote  Post ReplyReply bullet Posted: 13 Oct 2009 at 12:35am
Yeah i'm probably gonna just stick with a WD 500GB, The Raptor brings the price a little to much at the moment, maybe things will get a tad cheaper by january...lol
Heres my build so far. This is what i will go with when January comes. Though we'll see how the new GT300's turn out.
LCD Display: Acer 22 inch (Widescreen) (Black) (High-Performance Gaming Display)
Edited by Born2rade - 13 Oct 2009 at 12:39am
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 13 Oct 2009 at 12:40am
. justin how much of a difference do you see in games from a 3.7GHz to a 4.0GHz? cause I don't see any difference even in games like crysis that would be more then a a few fps maybe like 4 fps.
so again we are talking about maybe 4fps which is not a big difference and not worth $200. also if the game is already getting 60fps then you will not see any difference in the game from 3.7GHz to 4.0GHz, and at 1900 x 1200 with 2 gpus you will not notice any difference from the 4.0GHz OC as I originally stated.
@Born2rade, that build looks good
Edited by DST4ME - 13 Oct 2009 at 12:41am
  Quote Born2rade Quote  Post ReplyReply bullet Posted: 13 Oct 2009 at 2:14am
Just wanna say thanks to everyone for the tips and a big thanks to DST4ME :).
With some of the minor adjustments that i made i will be able to purchase a 22 inch monitor with everything. Hopefully the prices of the GT300's wont be too extreme because i really like the green team :).
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 13 Oct 2009 at 8:23am
Our pleasure boss
