Options for a small buget
Post Date: 2009-05-14
Zurginator View Drop Down
  Quote Zurginator Quote  Post ReplyReply bullet Topic: Options for a small buget
    Posted: 14 May 2009 at 11:08am
So I finally decided it might be worth looking into DS, because I finally got a job and yeah. So my budget is a small $1000 Wink, although I might be able to push $1500 Smile .... If needed you can go without an OS, I've got some disks, but those are all XP.
Edit: Wow, I should have known to post this by now:
I run at 1440x900 right now.
I usually play Crysis, Warhead, and Oblivion.
I am a moder, however, so I do need some nice performance on Crysis. (I currently get 20fps on Very High, I'm wondering if I can upgrade to 30+)
Edited by Zurginator - 14 May 2009 at 11:14am
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 14 May 2009 at 3:54pm
honestly come back when you saved up 1800 to 2000 so we can show you a PC you can upgrade thru the years and keep powerful. otherwise we have to give you bare minimum and it won't cover what you are looking for.
unless you want to go with amd.
Edited by DST4ME - 14 May 2009 at 3:55pm
inferno23 View Drop Down
  Quote inferno23 Quote  Post ReplyReply bullet Posted: 14 May 2009 at 5:47pm
LOL
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 14 May 2009 at 8:07pm
actually I take that back, here the amd will only cost a couple of hundred less and in turn give you less ram and not the same OC, so here there isn't much difference, for that budget I think you might want to save more or build it yourself.
