Overclock settings okay?
Post Date: 2011-10-14
sneaky George W View Drop Down
  Quote sneaky George W Quote  Post ReplyReply bullet Topic: Overclock settings okay?
    Posted: 14 Oct 2011 at 10:01am
Hello,
Being the proud owner of a Digital Storm System, I want to make sure I'm getting the best out of it, and will be for a long time. As such I wanted to make sure my Overclock settings were reasonable/optimal. I don't know very much about overclocking. My components are as follows:
2600K
Maximus IV Extreme
8GB DDR3 RAM
2x GTX 570's
I realize that every component is different, but they still live in the same ball park right?
I currently am OC'd to 4.5 at 1.375 volts (all settings below). My system is stable and the maximum load temp on my cpu is somewhere between 74'-79'C depending on room temp. Like I said, I just wanted to make sure these settings were reasonable/optimal. If anything I want to err on the side of having this system for a long time than frying it.
Here are the settings:
CPU Level Up: Auto
AI Overclock Tuner: Manual
BCLK/PCIE Frequency: 100
Turbo Ratio: All Cores Mode
Maximum Turbo Ratio: 45
Internal PLL Overvoltage: Auto
Memory Frequency: DDR3-1600MHz
Memory Bandwidth Booster: Disabled
EPU Power Saving Mode: Disabled
DRAM Timing Control
Primary Timings
    CAS# Latency: 9
    RAS# to CAS# Delay: 9
    RAS# Pre Time: 9
    RAS# ACT Time: 24
    DRAM Command Mode: Auto
All other Timings
   All values set to Auto
CPU Performance Settings
CPU Ratio: Auto
Enhanced Intel Speedstep Technology: Enabled
Turbo Mode: Enabled
   Turbo Mode Parameters
   Maximum Power: Disabled
   All other values set to auto
Digi+ VRM/Power Control
VCORE PWM Mode: T.Probe
VCORE MOS Volt Control: Auto
VCORE Loadline Calibration: Auto
VCORE Switching Frequency: Auto
VCORE Phase Control: Extreme
VCORE Overcurrent Protection: 100%
VCORE EMI Reduction: Disabled
VRM Overcurrent protection: Enabled
   VDRAM, VCCSA, VCCIO
    Overcurrent protection is Disabled for all
Extreme OV: Disabled
CPU Voltage: Manual Mode
CPU Manual Voltage: 1.375
DRAM Voltage: 1.65000
Thank you for your help!
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 14 Oct 2011 at 3:04pm
IF your vcore is below 1.4, temps are below 85c and system is stable, your oc is good to go. if there was a problem you would have stability issues or heat issues.
lol
Edited by DST4ME - 14 Oct 2011 at 8:26pm
  Quote RiceEatin2000GT Quote  Post ReplyReply bullet Posted: 14 Oct 2011 at 4:28pm
  Quote sneaky George W Quote  Post ReplyReply bullet Posted: 15 Oct 2011 at 3:48am
Okay, thanks for checking! I'm just paranoid... :)
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 15 Oct 2011 at 3:55am
NP Our pleasure and good luck
