Overclocking a Q9550 system
Post Date: 2009-11-22
azace View Drop Down
  Quote azace Quote  Post ReplyReply bullet Topic: Overclocking a Q9550 system
    Posted: 22 Nov 2009 at 5:16am
Okay, so i recently built my own system and here are most of the specs that I recall right off the top of my head.
Q9550
GTX260 Superclocked Edition
8GB DDR2 @ 800MHz
750W Corsair PSU
XFX780i
Antec 900 2
I wanted to try and overclock this system some. Right now I have like 5 or 6 fans in the case and the CPU runs around 32-42 degrees Celsius when gaming. I have a stock cooling fan on the CPU. What is the temperature where I should start to worry?
Any recommendations on how far to overclock?
P.S.--->First time I am wanting to overclock a system, so really new to this.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 22 Nov 2009 at 5:25am
cpu temps need to be under 85c preferably 80c.
thats after running intelburn or running linx like 40 or 50 times.
  Quote azace Quote  Post ReplyReply bullet Posted: 22 Nov 2009 at 5:52am
Okay, and a good program to monitor temps is? I read some guides and RMClock doesn't want to work on Windows 7 64bit
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 22 Nov 2009 at 9:26am
you can try HWMonitor and realtemp, go by which ever one shows the higher number.
rmclock has limited ability on vista and win7 64bit.
Edited by DST4ME - 22 Nov 2009 at 9:27am
  Quote azace Quote  Post ReplyReply bullet Posted: 22 Nov 2009 at 9:57am
What about CoreTemp?
I ran Intel Burn on Stress Level: High
and Times to run: 5
Max temp reached was 75 Celsius. I have the heatsink that came with the processor and I know for a fact that I need to take it off and redo the thermal paste because I know there is too much on there.
Right now at idle the temp is averaging 39 Celsius.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 22 Nov 2009 at 5:09pm
between hwmonitor and realtemp you are covered.
