Overclocking Guide?
Post Date: 2010-10-05
Mr. View Drop Down
  Quote Mr. Quote  Post ReplyReply bullet Topic: Overclocking Guide?
    Posted: 05 Oct 2010 at 5:33pm
Hey just wondering if anyone has a site where theres a guide to ocing, wanna start learning up on that stuff.
Mr.
  Quote !ender_ Quote  Post ReplyReply bullet Posted: 05 Oct 2010 at 5:50pm
this is a pretty handy one to get started
there are lots and lots and lots and lots of guides to be found on this, i'd reccomend spending a solid week just reading about it. you will find lots of differing opinions, approaches, etc but there is no right answer. every chip is different and different mobos/ram will respond differently to different settings, so there is a lot of trial and error involved
Mr. View Drop Down
  Quote Mr. Quote  Post ReplyReply bullet Posted: 05 Oct 2010 at 5:55pm
yup intend to read bunches before doing it haha JW though if i further oc my system, does it void the warranty DS gives me?
Mr.
  Quote !ender_ Quote  Post ReplyReply bullet Posted: 05 Oct 2010 at 5:59pm
email alex on that one
id say if you overclock it past where they did and burn up the chip, that you are SOL, covering any damage that came from overclocking would be impossible
Mr. View Drop Down
  Quote Mr. Quote  Post ReplyReply bullet Posted: 05 Oct 2010 at 6:06pm
whats SOL?
Mr.
  Quote !ender_ Quote  Post ReplyReply bullet Posted: 05 Oct 2010 at 8:51pm
definition 1.
Edited by !ender_ - 05 Oct 2010 at 8:52pm
Mr. View Drop Down
  Quote Mr. Quote  Post ReplyReply bullet Posted: 05 Oct 2010 at 9:47pm
hmm, not rly planning on ocing it THAT much, its at 3.8 right now and idk if the gpu affected it but something was wrong with it before so i defaulted everything then found out had a defective gpu. if im gonna oc ill prolly oc it to only 4.0 and also oc the mem. i dont even know what speed the mem is running on right now
Mr.
AmbientChong11 View Drop Down
  Quote AmbientChong11 Quote  Post ReplyReply bullet Posted: 06 Oct 2010 at 1:03am
I was new to overclocking as well. After I became comfortable, I messed around with the OC several times and lowering the vcore. Before I started, I saved the profile and wrote on hard copy the original OC that was there, just in case.
When I ordered my DS, I went with the default 6GB RAM 1600mhz DS certified, but the BIOS listed as 1066mhz. I OC'd it but then the PC was unstable, not loading the OS. This was about last year, and I discovered that you need to update the EVGA x58 motherboard to take advantage of 1600mhz.
There are many guides so read them and YouTube helps also, but I wouldn't rely on one source too heavily. You build up self-confidence after a successful OC. I know I did.
Mr. View Drop Down
  Quote Mr. Quote  Post ReplyReply bullet Posted: 06 Oct 2010 at 1:11am
what do you mean update the mobo to take adv of the 1600mhz ram? i ordered the DS cert ram at 1600mhz as well. got the tech nps one, was hopin for mushkin or kingston but o well, cant complain there as long as it runs 1600. yea i think i saw low numbers on my ram too but wasnt too sure how to read em. can you elaborate on taht a bit?
Mr.
  Quote AmbientChong11 Quote  Post ReplyReply bullet Posted: 06 Oct 2010 at 1:26am
I received the Mushkin. I noticed that at BIOS it had the original OC to 3.75ghz (or around that) listed and then below it RAM 1066mhz listed instead of 1600mhz. I'm not comfortable to do this yet. Just recently I was browsing through TigerDirect and noticed EVGA motherboards says this (in red) ::
Note: A BIOS upgrade to version SZ1A may be required to use 1600MHz. The new BIOS, as well as upgrade instructions can be located on the EVGA website.
So a motherboard update is needed. Hopefully Alex will see this.
Edited by AmbientChong11 - 06 Oct 2010 at 1:27am
Mr. View Drop Down
  Quote Mr. Quote  Post ReplyReply bullet Posted: 06 Oct 2010 at 1:28am
ic ic thanks, gotta check what my ram is runnin on once i get the rig up n runnin. migh just speed up my ram and oc the cpu when i grab another fan for my noctua. tahts just an excuse to upgrade it later haha but it works for me
Mr.
  Quote AmbientChong11 Quote  Post ReplyReply bullet Posted: 06 Oct 2010 at 1:32am
Made a mistake. This is not on all EVGA motherboards. Some needs to be flashed to take advantage of 1600mhz and others not.
Mr. View Drop Down
  Quote Mr. Quote  Post ReplyReply bullet Posted: 06 Oct 2010 at 1:52am
mmmm well ill see what my speed is for ram first in a few days but thanks for the info!
Mr.
  Quote AmbientChong11 Quote  Post ReplyReply bullet Posted: 06 Oct 2010 at 2:01am
You're welcome.
  Quote Alex Quote  Post ReplyReply bullet Posted: 06 Oct 2010 at 3:44pm
Is the memory showing up as 1600MHz in Windows after you boot up? Use CPU-Z to verify the memory clock speed. When we overclock, the way the settings may be, they lower the memory ratio which later gets increased when the overclock gets applied.
Mr. View Drop Down
  Quote Mr. Quote  Post ReplyReply bullet Posted: 07 Oct 2010 at 12:45am
Ill get back to you on that one alex, gotta get my comp booting up before i can do that :P  Ill post up my cpuz n what not in a few days
Mr.
