Paint Color Advice
Post Date: 2019-12-11
Furio View Drop Down
  Quote Furio Quote  Post ReplyReply bullet Topic: Paint Color Advice
    Posted: 11 Dec 2019 at 11:39am
Thank you for all your help on my last question! I went with this build 2767035 and decided to treat myself and the new pc to an exotic paint color. Only selection they had available was Blue and White. I opted for the blue with white cabling inside. Figured most colors would look good with it. Part of me also is thinking I should have gone with the white. It is not too late to change the order, any suggestions from those that have seen these colors in person or not? Thanks!
Jordak24 View Drop Down
  Quote Jordak24 Quote  Post ReplyReply bullet Posted: 11 Dec 2019 at 12:11pm
Since that would be a personal preferance as I see, I too would have gone with the Blue or Black if that was an option. I just think any lights would pop a little more in a darker case. BUT again that is just my opinion based on my preferance.
ApC
  Quote Jordak24 Quote  Post ReplyReply bullet Posted: 11 Dec 2019 at 12:17pm
Also you may find some videos on youtube of some unboxings or of other builds to compare too that may help you make up your mind.
Edited by Jordak24 - 11 Dec 2019 at 6:42pm
ApC
