PC Build advice pleasePost Date: 2021-04-15 |
| Author | |
sbrasher
Joined: 12 Apr 2021 Online Status: Offline Posts: 7 |
Topic: PC Build advice pleasePosted: 15 Apr 2021 at 6:56am |
Hi all, I am building a PC that will be used mainly for 3D modeling and rendering. I've already gotten some advice on the CPU and graphics card, but I was wondering if I could get more feedback before I pull the trigger. Specifically, I'm wondering if the cooling / fans are sufficient. Could someone look this over and let me know if I'm missing something that will affect performance? I'm new to this.. Thanks so much!
Chassis Model: Digital Storm Velox Exterior Finish: - Standard Factory Finish Trim Accents: - Standard Factory Finish Processor: AMD Ryzen 9 5950X (16-Core) 4.9 GHz Turbo (BACKORDER ETA MAY) Motherboard: ASUS ROG Strix X570-E Gaming (Wi-Fi) (AMD X570 Chipset) (Up to 3x PCI-E Devices) System Memory: 64GB DDR4 3200MHz Digital Storm Performance Series Power Supply: 1000W Digital Storm Performance Series (Semi-Modular) (80 Plus Gold) Expansion Bay: - No Thanks Optical Drive: - No Thanks Storage Set 1: 1x SSD M.2 (1TB Samsung 970 EVO PLUS) (NVM Express) Storage Set 2: 1x SSD (1TB Samsung 860 EVO) Storage Set 3: - No Thanks RAID Config: - No Thanks RAID Card: - No Thanks Internet Access: High Speed Network Port (Supports High-Speed Cable / DSL / Network Connections) Graphics Card(s): 1x GeForce RTX 3080 10GB (Performance Edition) (VR Ready) Sound Card: Integrated Motherboard Audio Add On Card: - No Thanks Extreme Cooling: H20: Stage 2: Digital Storm Vortex Liquid CPU Cooler (Dual Fan) (Fully Sealed + No Maintenance) HydroLux Tubing Style: - Not Applicable, I do not have a custom HydroLux liquid cooling system selected HydroLux Fluid Color: - Not Applicable, I do not have a custom HydroLux liquid cooling system selected Cable Management: Premium Cable Management (Strategically Routed & Organized for Airflow) Chassis Fans: Standard Factory Chassis Fans Internal Lighting: Remote Controlled Advanced LED Lighting System (Multiple RGB Color Modes) Airflow Control: - No Thanks Chassis Mods: - No Thanks Noise Reduction: - No Thanks LaserMark: - No Thanks CPU Boost: Stock Factory Turbo Boost Advanced Automatic Overclocking Graphics: - No Thanks, Please do not overclock my video card(s) OS Boost: - No Thanks, Please do not tweak the services on the operating system Operating System: Microsoft Windows 10 Professional (64-Bit) Recovery Tools: USB Drive - Windows 10 Installation (Format and Clean Install) Virus Protection: Windows Defender Antivirus (Built-in to Windows 10) Office: - No Thanks Mouse Pad: - No Thanks Display: - No Thanks Surge Shield: - No Thanks Speakers: - No Thanks Keyboard: - No Thanks Mouse: - No Thanks Branded Gear: - No Thanks Priority Build: - No Thanks, Ship Within 30-35 Business Days After Order Is Successfully Processed Warranty: Life-time Expert Care with 3 Year Limited Warranty (3 Year Labor & 1 Year Part Replacement) Saved Ticket #: 3866200 Edited by sbrasher - 15 Apr 2021 at 7:04am |
Cretae
Joined: 22 Mar 2010 Online Status: Offline Posts: 7331 |
Posted: 16 Apr 2021 at 3:29am |
This is fine. The All-in-One CPU cooler sits right on top of the CPU and removes heat directly to a radiator that expels it via dual fans. the Velox case with standard fans is considered to be one of the most ventilated with very good air flow. As long as everything is functioning correctly, no worries.
sbrasher
Posted: 16 Apr 2021 at 11:02am |
Good to know, thank you!
Clay
Joined: 11 Apr 2009 Online Status: Offline Posts: 526 |
Posted: 16 Apr 2021 at 1:24pm |
Looks pretty sweet!!
I7 13700KF 5.4hz
ASUS Prime z790 MoBo ASUS Dual 4070 32g ram@5200 850 Gold PSU 1TB SSD 2TB SSD 27" ASUS Monitor 144hz Razer Ornata Chroma Keyboard Razer Basilisk V2 Mouse Nari Ultimate Headset |
Cretae
Posted: 17 Apr 2021 at 4:02am |
My pleasure.
