Pc component swap but fail. Help please
Post Date: 2008-10-02
Bouke285 View Drop Down
  Quote Bouke285 Quote  Post ReplyReply bullet Topic: Pc component swap but fail. Help please
    Posted: 02 Oct 2008 at 9:50pm
I just got my second antec 900 from DS due to my first one being bent in shipping. I have been using my pc for around 2 weeks works perfectly so yesterday I decided to do the hardware swap myself. I have never attempted this before so it was a learning experience for me. I just finished or I thought i did putting in the last plug and fired it up I even added 2 of the old fans out of my old case for some extra cooling, but I got this message in the start up:
"Warning! the system case did open Please check the system!"
I hit F1 to continue and get this message.
"PXE-E61 Media test failure Please check cable"
Exiting Nvidia Boot Agent.
and Bootup disk failure please enter system disk and press enter"
My questions are.
What does this warning message mean and what is not hooked up right. Is it the Hard drive?
Thanks for the help
I know the plans I have for you, declares the Lord, plans to prosper you and not to harm you, plans to give you hope and a future." (Jeremiah 29:11)
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 02 Oct 2008 at 10:06pm
eihter one of your drives are not connected properly, dvd drives, flopy, hdd andy drive.
or your bios is not setup right.
or your HDD1 is has got no recognizable boot files on it.
btw you sure your pc case is closed right?
Edited by DST4ME - 02 Oct 2008 at 10:15pm
  Quote Bouke285 Quote  Post ReplyReply bullet Posted: 02 Oct 2008 at 10:19pm
Yah it's closed right I checked all of the fans they all work fine. Is there any way to  tell which drive is not hooked up right all I have are 1 hard drive and 1 dvd drive.
  Quote Bouke285 Quote  Post ReplyReply bullet Posted: 02 Oct 2008 at 10:26pm
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 02 Oct 2008 at 10:30pm
B2, that spot is for the jumpers, which sata does not use.
double check your dvd and hdd again, so you got no media card reader, or any other drives?
you updated your bios?
  Quote Bouke285 Quote  Post ReplyReply bullet Posted: 02 Oct 2008 at 10:32pm
Will I still have to update my bios even though I had already been running my hard drive before on the pc?
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 02 Oct 2008 at 10:35pm
you don't have anything in the dvd drive now do you?
can you log into bios?
Edited by DST4ME - 02 Oct 2008 at 10:36pm
  Quote Bouke285 Quote  Post ReplyReply bullet Posted: 02 Oct 2008 at 10:36pm
I just saw on the start up screen it is detecting my DVD drive but none of the SATA's I may have plugged the mother board end of the SATA into th wrong one because there are two
I did go into bios and tried to detect the hard drive but it came up with nothing
Edited by Bouke285 - 02 Oct 2008 at 10:37pm
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 02 Oct 2008 at 10:38pm
if you have a port with the number zero then use that one, if you don't have a zero then use the one with number 1
sorry about the bios update question earlier, I keep thinking new build system, no bios update is not needed in this case.
Edited by DST4ME - 02 Oct 2008 at 10:38pm
  Quote Bouke285 Quote  Post ReplyReply bullet Posted: 02 Oct 2008 at 10:42pm
Edited by Bouke285 - 02 Oct 2008 at 10:51pm
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 02 Oct 2008 at 10:44pm
your pic is too small I can't see
what board is that? 780i? or 790i?
  Quote Bouke285 Quote  Post ReplyReply bullet Posted: 02 Oct 2008 at 10:45pm
750 i
Edited by Bouke285 - 02 Oct 2008 at 10:49pm
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 02 Oct 2008 at 10:49pm
no it does not, its been rescaled
  Quote Bouke285 Quote  Post ReplyReply bullet Posted: 02 Oct 2008 at 10:50pm
Oh sorry the place doesn't let me host any bigger images but there is an SATA on top and one on bottom should either of them work? The top one is hard to get to so I didn't plug back in to that one
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 02 Oct 2008 at 10:52pm
one of them has a number zero or one next to it, it should be that one.
  Quote Bouke285 Quote  Post ReplyReply bullet Posted: 02 Oct 2008 at 10:53pm
ok i'll look
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 02 Oct 2008 at 10:57pm
one of these:
  Quote Bouke285 Quote  Post ReplyReply bullet Posted: 02 Oct 2008 at 11:12pm
I don't have those on my board I only have the 2 90 degree ones I moved my SATA to the first one and took out an extra fan it's still doing the same thing
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 02 Oct 2008 at 11:39pm
damn you are right that is a 780i.
B2 can you upload your pic here and then post the link for it here please. skip step 2 there.
Edited by DST4ME - 02 Oct 2008 at 11:40pm
  Quote Bouke285 Quote  Post ReplyReply bullet Posted: 03 Oct 2008 at 5:24pm
Sorry for the late reply, I had to get off because of school in the morning, but I realized I never tried to swap the SATA power cord so I did this and it fired right up other then the Case Has Opened error message which I cant figure out. I've re arranged my fan pluggins like 30 times and even took one fan out, Oh well I can live with hitting F1 each boot up.
Thanks a lot DST4ME you helped me think through my first pc build.
Edited by Bouke285 - 03 Oct 2008 at 6:18pm
  Quote Bouke285 Quote  Post ReplyReply bullet Posted: 03 Oct 2008 at 6:21pm
I put the other windowd side pannel on the side that is usually solid. It looks cool, but I was wondering If I cut a small design in the plate that holdes the motherboard so you can see the back of the chip would it work fine do you think?
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 04 Oct 2008 at 3:13pm
sorry boss just saw this, glad you got it working.
not sure about cutting the whole part, I think it should be ok but I'm not sure you want to expose the cpu like that.
