Pc is running but no power to peripherals
Post Date: 2023-10-05
Viind View Drop Down
  Quote Viind Quote  Post ReplyReply bullet Topic: Pc is running but no power to peripherals
    Posted: 05 Oct 2023 at 7:23pm
I don’t know why this is happening but when I turn my pc on my mouse will flash on the turn off instantly same with my keyboard. My monitor also has no display. Fans are running, led in pc is on everything is working.
What I have tried
- Turning PC on with no gpu ( still happens )
- Taken out my RAM cleaned it with eraser put it back in ( still happens )
- Taken out my CMOS for 5 minutes put it back in ( still happens )
Specs
Processor: AMD Ryzen 9 5900X (12-Core) 4.8 GHz Turbo
Motherboard: ASUS PRIME X570-P / MSI X570-A Pro (Up to 2x PCI-E Devices) (No SLI Support)
Graphics Card(s): 1x GeForce RTX 3080 10GB (Performance Edition) (VR Ready)
Ordered/Stage 1- 12/07/2021
Stage 2- 02/01/2021
Stage 3- 02/01/2021
Stage 4- 02/02/2021
Stage 5- 02/13/2021
Stage 6- 2/15/2021
Stage 7- 2/15/2021
Shipped - 2/16/2021
Received - 2/19/2021
  Quote hoserator Quote  Post ReplyReply bullet Posted: 06 Oct 2023 at 9:45am
Try turning on with one RAM stick at a time. One might be bad and not letting the system boot.
Good luck.
  Quote Viind Quote  Post ReplyReply bullet Posted: 07 Oct 2023 at 11:20am
Good luck.
Tried that and still had problems I might take it to micro center because i need my pc asap
Stage 2- 02/01/2021
Stage 3- 02/01/2021
Stage 4- 02/02/2021
Stage 5- 02/13/2021
Stage 6- 2/15/2021
Stage 7- 2/15/2021
Shipped - 2/16/2021
  Quote hoserator Quote  Post ReplyReply bullet Posted: 08 Oct 2023 at 4:51pm
It could also be a failing psu and when the system requires more power on full boot, the psu is unable to provide it. Maybe!?
I still think it's hanging up on something during the boot process. Did you disconnect all the peripherals (keyboard, mouse, ext. HDD/SSDs, sound, etc) to see if it boots up to the Windows screen? And then add them one by one. I'm guessing now.
Sorry but I'm not the best at diagnostics.
Boakist View Drop Down
  Quote Boakist Quote  Post ReplyReply bullet Posted: 16 Oct 2023 at 11:12am
Try a different set of RAM sticks or test your RAM in another system to rule out memory issues.
This page was generated in 2.050781E-02 seconds.
