PCIe Link State Power Managment
Post Date: 2010-12-13
OnBake Platinum View Drop Down
  Quote OnBake Platinum Quote  Post ReplyReply bullet Topic: PCIe Link State Power Managment
    Posted: 13 Dec 2010 at 7:26am
Hi friends.
I was looking through my power settings in windows 7 and found this option. I can change it to off, moderate, or maximum. Right now it's maximum.
Is this good or bad? Does it bottleneck the card? I have a GTX480 and want the best performance possible.
I also want to use the least amount of electricity possible (Since I pay the bill!) so I have it on the power saver plan (though I tweaked a few things). I have it hibernate after 1 hour and turn off the system whenever I sleep/go to work/leave the house.
  Quote !ender_ Quote  Post ReplyReply bullet Posted: 13 Dec 2010 at 8:05am
id leave it on max, when you system is hibernating its not going to draw power anyway
when you put your computer to 'sleep' does it go completely dark? all lights/fans off?
  Quote OnBake Platinum Quote  Post ReplyReply bullet Posted: 13 Dec 2010 at 8:11am
Stand by/sleep is buggy and sucks. Either my sound doesn't work, the mouse is stuck in permanent right click, the keyboard acts like the alt key is being pressed when it isn't, I can't delete files because it is "discovering" them forever, and other random problems.
I either hibernate after 1 hour of inactivity or just shut down when I leave. Never "sleep."
  Quote !ender_ Quote  Post ReplyReply bullet Posted: 13 Dec 2010 at 5:22pm
s1 or s3? im my exp s1 is terrible and s3 is great
ablahblah View Drop Down
  Quote ablahblah Quote  Post ReplyReply bullet Posted: 13 Dec 2010 at 5:32pm
s1 glitched up pretty bad sometimes on my original X58 board, wouldn't recover sometimes. S3 works wonders
R4D4RPR00F
Core i7 920 @ 3.9Ghz
Asus Sabertooth X58
EVGA GTX 570
Mushkin 6GB 1414Mhz
  Quote OnBake Platinum Quote  Post ReplyReply bullet Posted: 14 Dec 2010 at 9:50am
So what is this PCIe Link State Power thing anyways? Does it mean it only gives juice to the card when it needs it?
  Quote !ender_ Quote  Post ReplyReply bullet Posted: 14 Dec 2010 at 5:28pm
couldnt find any good info on it, but i would guess something like that. other things are pci powered too, so it makes sense to have it as a power option. but i wouldnt put anything on a pc less than max
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 14 Dec 2010 at 11:19pm
Basically yes, it regulates and power to the pci lanes, to save power, its part of power management.
